Old 06-24-2010, 03:38 PM   #1
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Question diy turbo inlet
I have been thinking how I can make a turbo inlet with the help of local shops. As $200 seems to be to much for making this part. Any thoughts?
Old 07-01-2010, 01:57 AM   #2
tobylazur
Member#: 150289
2006 SV650N
1972 Travelall
I'd guess it would be a pain in the ass as you'd have to remove and re-install the intake manifold a bunch of times to check for fitment. Also, if you're making a metal one, I know the one I have on my car has a crazy silicon connector that reduces as well as sorta jogs over and down.
tobylazur is offline   Reply With Quote
Old 07-02-2010, 01:57 AM   #3
teiva-boy
Member#: 22825
The up front time and expense to make some initial prototypes far exceeds the cost of just buying a premade unit...
teiva-boy is offline   Reply With Quote
Old 07-02-2010, 06:57 PM   #4
Badler
Member#: 133597
$90hr minimums will start to add up faster than you think.
Badler is offline   Reply With Quote
Old 08-04-2010, 04:18 AM   #5
NWSTi-wa
Member#: 245786
BUT, what about for someone who already has the motor out? Seems to me it wouldn't be too much of a hassle. Im going to try and do it myself as im already in the process of an engine build. I'll post the results when im done.
NWSTi-wa is offline   Reply With Quote
Old 08-08-2010, 09:20 AM   #6
Autoxsi
Member#: 221315
2008 STi Hatchback
Any other company other than APS makes the metal one?
Autoxsi is offline   Reply With Quote
Old 08-08-2010, 03:31 PM   #7
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
^ agency power does but generally frowned on.
Old 08-08-2010, 05:28 PM   #8
yarbles
Member#: 152702
Made my own, keeping the intake manifold routing but using a custom up-pipe/downpipe to allow a straight shot 3" coupler. The 3" offset couplers make me angry, I see no reason to run a 3" turbo inlet with such an abrupt transition. The 2.4 is better. This pile of aluminum took me approximately 6 hours, but I can install/remove it without pulling my intake manifold! Just pull the PS pump.
yarbles is offline   Reply With Quote
Old 08-08-2010, 05:43 PM   #9
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Hmm interesting
Old 08-08-2010, 05:56 PM   #10
davisw
Member#: 245211
More power to you. Can't wait to see it.
davisw is offline   Reply With Quote
Old 08-10-2010, 02:41 PM   #11
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Why did you add the front lift? From pics I have found of the aps and the agency power are straight with a cut out. Guessing the cut out is for the power steering.
Old 08-10-2010, 02:54 PM   #12
yarbles
Member#: 152702
I have the front lifted up a bit to allow a larger radius bend, and help it dive under the manifold. The cutout at the back was a little overkill, but I wasn't really going for anything spectacular. It allows the inlet to sit as close to the TGV housing as possible, since I didn't care to grind down the TGV.
This is for a custom setup though, and wouldn't work with the stock turbo/uppipe/downpipe combo. If staying with that, you're better off buying the APS 2.4" inlet and calling it a day. Even better, run a silicone inlet and avoid the headache.
Old 08-10-2010, 03:19 PM   #13
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
I have the early version of the perrin inlet but don't really like it. Was interested in a black painted aps inlet. I have to many flashy things under my hood. Trying to reduce the flashy look. Been looking at the aps inlet pretty hard.
Old 08-10-2010, 05:31 PM   #14
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
Good luck finding an APS inlet...
OrbitalEllipses is offline   Reply With Quote
Old 08-20-2010, 08:14 PM   #15
NWSTi-wa
Member#: 245786
Just go here: Importimageracing.com
They have everything for the best deals.
APS turbo inlet Vs. Samco turbo inlet STi-JDM Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 01-04-2007 03:53 PM
DIY turbo inlet hose. Version 2. 2phless Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 01-13-2006 01:00 AM
diy turbo inlet pipe? brettedmonds Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 01-03-2006 01:11 PM
WTT: Perrin red Turbo Inlet hose for blue Perrin/Samco Turbo Inlet Hose TROLL Private 'For Sale' Classifieds 4 12-22-2005 02:39 AM
Perrin turbo inlet hose vs. GP Moto turbo inlet hose Silver on Blacks Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 34 11-14-2005 12:02 PM
