Old 06-25-2010, 10:32 AM   #1
feint05
Member#: 152984
2004 jewbaru
jewbuilt, polish tuned
Default help: car starts then dies, where do i start
car
1998 subaru forester
2.5 phase 1 engine, recently rebuilt for the classic hg (no warranty)
completely stock
i just recently bought the car so this is inconvenient to say the least
its been feeling a little sluggish around town and i assumed i needed to go through everything and make sure maintenance was up to par
yesterday it shuddered coming out of a stop light a couple times, felt like a momentary miss.
Now last night i checked the maf and spark plug wires, applied a little dielectric grease and restarted it, ran fine. Then later that night when i went to start it it would start but as soon as the rpms dropped to around 1k that car would shut off completely. The lights all still work fine so i assume its not a battery or alternator problem.
Thank you for your time and suggestions
Ryan
feint05 is offline   Reply With Quote
Old 06-25-2010, 12:06 PM   #2
PhilSine
Member#: 130489
02 WRX Wagon (WRB)
98 OBS-T, 91 Legacy SS
Any CEL's?
PhilSine is offline   Reply With Quote
Old 06-25-2010, 12:13 PM   #3
Burnout
Member#: 4721
2002 2.5 RS
1997 Brighton
Check to make sure the big Vacuum hose is still connected to the intake tube, It connect right after the maf on the bottom side of the tube.
Burnout is offline   Reply With Quote
Old 06-25-2010, 02:23 PM   #4
flightwatch
Member#: 231058
2015 F-150
^^^+1
Sounds like a vacuum leak
flightwatch is offline   Reply With Quote
Old 06-25-2010, 02:35 PM   #5
snoopyone8
Member#: 42970
1998 2.5RS BlkDmdPrl
2000 2.5RS SilverthornMet
Make sure the MAF plug is completely plugged in/has good contact.
snoopyone8 is offline   Reply With Quote
Old 06-25-2010, 05:22 PM   #6
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
check our your fuel pump. has the filter been serviced recently?
Old 06-25-2010, 06:27 PM   #7
feint05
Member#: 152984
2004 jewbaru
burnout, that sounds like the one cause i did take a look at the filter,
ill be checking Tps sensor and maf
i have new spark plugs and a new fuel filter ready to install
fuel pumps usually work or they dont but i have my old stock wrx one lying around too
no CEL's but i have a code reader and will check for pending codes
Old 06-26-2010, 09:28 PM   #8
ocddad
Member#: 250445
Full disclosure, I drive a '99 328i, but my son just got an Impreza with maybe some issues...so I have to post three times to be able to post first thread...am fulfilling that req!
Anyway, the bmws have similar stalling issues at times...many related to air leaks aft of the MAF...in particular, one boot going to the idle control valve frequently cracks...so much air, engine doesn't have enough fuel measured to combust properly...so air leak seems good guess as suggested.
But, the other thing is that we clean our MAFs all the time...so a MAF cleaner...don't touch wires...just spray...be gentle with it you know...and let it dry.
Also, you can 'smoke' the engine to isolate location of possible air leak...spray carb cleaner around and if engine sputters (while running normally, of course) then you've gotten closer.
Finally, my favorite...a 4' hose about 1" in diameter to listen around the engine (if you don't have mech's stethoscope)...can often hear things not sounding right.
Of course, I'm assuming all the rest of car is in okay shape...filters, fluids, etc.
HTH
Doug
ocddad is offline   Reply With Quote
Old 06-26-2010, 11:25 PM   #9
ocddad
Member#: 250445
Sorry...should've also said...don't 'assume' it's not battery coz the lights are on.
Cars need a lot more power to run than that powering lights...battery and/or alt could be issue.
Test voltage on bat...s/b about 12V with car off...about 14v with car on...make sure connections are clean and firm...try to pull cables off...they shouldn't come off, of course!
HTH
Doug
Old 06-27-2010, 01:09 AM   #10
Wrencher86
Member#: 250463
2010 Impreza 2.5i
Given the previous symptoms, an air leak sounds like a good place to start looking. Before you start going gung-ho on the testing though, make sure you don't have a security light flashing on the dash or maybe try another key if you have one.
I got ahead of myself one time and got trying to figure out a no start on a Fit. Some cars will start and die others just plain old won't start.
In regards to cleaning the MAF sensor, you have to be careful with that. Some manufacturers (like BMW and MB) have sensors that you can clean, while others will be ruined by any kind of solvent. I have no idea which catergory Subaru falls into.
Wrencher86 is offline   Reply With Quote
Old 06-27-2010, 01:36 PM   #11
feint05
Member#: 152984
2004 jewbaru
OOPS UPDATE
Burnout was right, at night i checked my air filter and couldn't see that i disconnected that vaccum hose on the underside of the intake, but i also checked compression, changed spark plugs and the fuel filter while i was in there.
compression at 5 cranks is 180 on all four, im pretty happy about it
Thanks guys
car starts then dies after 10 sec raceckr Service & Maintenance 4 04-23-2010 09:41 PM
Front 02 sensor wire soldered,car started then died,won't start anymore! Help please greddy18 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 06-29-2009 09:43 PM
new hydra, car starts then dies. kharris4 Other Engine Management 12 10-01-2006 06:52 PM
Car starts then DIES....Vacuum gedwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 08-22-2005 03:28 PM
Swap Done, Started then DIED.. HELP! Z0rr0 Subaru Conversions 2 12-21-2004 03:32 PM
