Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 06-13-2002, 09:18 PM   #1
Jasno999
Member#: 9262
2002 WRX Sedan
Blaze Yellow
Default 2002 WRX parking light bulbs?
I have changed out all the headlight bulbs to super-whites except for the darn parking light. I was wondering what size bulb this was and where I could purchase it. Also how do I remove it?
Jasno999 is offline   Reply With Quote
Old 06-13-2002, 11:16 PM   #2
klt599
Member#: 17529
Default Bulbs
They are W5W size
you ahev to take the headlights out to replace them its really easy though.
make sure you get some good ones phillips blue vision did nothing on mine they need to be really white to match the hyperwhites.
Hope this helps
klt599 is offline   Reply With Quote
Old 06-14-2002, 07:29 AM   #3
Jasno999
Member#: 9262
2002 WRX Sedan
Blaze Yellow
So what are good bulbs to purchase and where can I get them from?
Old 06-14-2002, 08:26 AM   #4
rupteur7000
Member#: 11585
02 2.5RS
i am also not a p****
i haven't found some nice looking replacements yet. on the other hand you don't have to take the headlight outto change those just twist the plug and pull it out.
rupteur7000 is offline   Reply With Quote
Old 06-14-2002, 01:26 PM   #5
Jasno999
Member#: 9262
2002 WRX Sedan
Blaze Yellow
Where can you find any W5W bulbs?
Old 06-16-2002, 09:44 PM   #6
Jasno999
Member#: 9262
2002 WRX Sedan
Blaze Yellow
Really where can you find a W5W bulb?
Old 06-16-2002, 11:16 PM   #7
jlee27
Member#: 10244
2002 2002 Bugeye
Lightbulb
I'm using krypton 194's, a little on the blue side, but I bought 4 and have clear side-markers so the parking lights and side-markers are for show and the headlights are running PIAA Xtreme Whites, not a bad setup
Anyhow, the parking lights are 194's or 168's, they both fit, haven't heard of W5W's
-jxl
jlee27 is offline   Reply With Quote
Old 06-17-2002, 05:03 PM   #8
Kartoffel
Member#: 12976
grocery getter
The front parking lights are 194s. Just do a search, there are a gazillion different things you can stick in those sockets.
Kartoffel is offline   Reply With Quote
Old 06-17-2002, 11:09 PM   #9
V REX
Member#: 11102
02 WRX,05STi sold
B5 WB Nogaro S4
Look in your manual, it's in there....I think they are 168 though. I'm using polarg's but their a little on the blue side.
V REX is offline   Reply With Quote
Old 06-18-2002, 02:49 AM   #10
ScoobyBoy
Member#: 6418
replacing those parking lights was a pain. had to take everything apart. it took forever cuz i was extremely careful, and i wasnt very sure what i was doing.
im using cuzo 12v 5w bulbs. they are hyper white, but they dont exactly match my headlights and foglights. (ive change the headlights and foglights too) they're close but still a little off. any 12v 5w bulb will work. its the same one for the license plate lights.
ScoobyBoy is offline   Reply With Quote
Old 06-18-2002, 01:48 PM   #11
ATX25RS
Member#: 4597
2011 Mitsu Outlander
Sport (Ex-Suby owner X3)
PIAA plasma wedges, or whatever they are called.....LiquidIQ has them, you might want to pm him for the exact name..they match very well with his sylvania silverstars.....they are pricey though./..
Andres
ATX25RS is offline   Reply With Quote
Old 06-18-2002, 02:44 PM   #12
Jasno999
Member#: 9262
2002 WRX Sedan
Blaze Yellow
Can you guys list some websites I can get bulbs from. I have a set of 194 that are very blue in color. Is that legal to put in as my parking lights?
I do want to get a set of supper whites. I have a set in my side markers but I forget where I got them. THey are quite bright. If I find my old receit I will post where I got them.
Old 06-19-2002, 09:17 PM   #13
Jasno999
Member#: 9262
2002 WRX Sedan
Blaze Yellow
Yo guys websites????
Old 06-19-2002, 11:34 PM   #14
phatfil
Member#: 15956
13 XV Crosstrek
13 FR-S Asphalt
Default forget all that
i know the perfect match. i got them off of e-bay. get ultra white LED 194 bulbs. I like the 4 bulb set up better. very bright. terrshop is the e-bay seller. I currently have blue 194 bulbs w/ the 4 led set up. Like these
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1836142901
or these
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1837349462
phatfil is offline   Reply With Quote
Old 06-20-2002, 12:54 AM   #15
ATX25RS
Member#: 4597
we tried thos on LiquidIQ's wagon, and were not impressed...since the led's are directional they look silly.....like i said try the PIAA's.....BTW terra's shop site is http://www.terrshop.com/ ...try searching ebay for the PIAA's
Andres
Old 06-20-2002, 07:56 AM   #16
Jasno999
Member#: 9262
2002 WRX Sedan
Blaze Yellow
YOu guys are aware I am not talking about the side markers here but the parking light that turns on inside the headlight.
Are those 194 bulbs also?
Old 06-20-2002, 10:37 AM   #17
ATX25RS
Member#: 4597
yep...i know.,......
Old 06-20-2002, 10:41 AM   #18
Moses
Member#: 19148
Default Everything you need to know, Jasno99!!!
Jasno99,
I am going to give you everything you need to know and put an end to this...
'02 RS/WRX:
Headlights: 9007
Foglights: H3
Parking lights: 168/194 (they are the same size)
Side markers: 168/194 (see above)
License plate: 168/194 (see above)
Two brands of bulbs I used:
PIAA Xtreme White - a bit blue, but not bad, I like'em
Showoff Krypton series Xenon bulb - these things are so white and SO bright
In the past two weeks, I have changed out all of the above lights.
side markers: installed clear markers with the PIAAs
license plate: 2 bulbs - installed PIAAs
foglights: remove lights, unplug, and replaced with Showoffs
headlights and parking lights: remove grill, remove bugeyes, unplug, replaced heads with Showoffs, unplug parking lights, replaced with PIAAs (yes, you have to take out your bugeyes to get at the parking lights - check your owners manual, it says it in there).
Is there anything that I missed...I don't think so!
Let me know if you need more info.
Moses
Moses is offline   Reply With Quote
Old 06-20-2002, 11:03 AM   #19
davearm
Member#: 18926
2002 WRX wagon
Great post moses, thanks for the info.
Do you see the blueness of the PIAAs you put in the parking lights during the daytime when the lights are OFF? I put Philips Bluevisions in the side markers and you can't really see the blue when they're off, but the parking light housing seems like it's more transparent than the sides. I was going to experiment with switching the Bluevisions to the parking lights but don't want to pull everything apart if I don't have to.
davearm is offline   Reply With Quote
Old 06-20-2002, 12:18 PM   #20
Moses
Member#: 19148
Davearm,
Yes, I do see the blueness of the PIAAs in both the side markers and the parking lights when the lights are off.
I went with PIAAs because in many circles they are known as the best and I liked the slight blue tint from them...my car is Blue Ridge Pearl. Plus, PIAAs have a good warranty. I did not put PIAAs in the head and fog lights because they are just TOO expensive for me...I didn't want to think about blowing a $80-$100 pair of bulbs after the warranty runs up. The PIAA 168s only cost me $16 a pair.
I went with Showoff bulbs for both the head and fog lights because they came highly rated and they were fairly inexpensive. Plus, I heard things like "Showoffs are made by the same people that make PIAA" or "Showoffs are made in the same building as PIAAs". With those statements I felt pretty safe on my decision.
Yeah, I'll be the first one to admit that the two different types of bulbs (Showoff and PIAA) are different shades. But it doesn't really bother me. I can drive around during the day shagging with my side markers and parking lights on. During the night, I turn on all bulbs and they just blend in together.
Last night I did the foglight mod. With the foglights on with the side and parking lights it looks a bit ackward because of the two shades of light. But hey, I didn't really do the mod to drive around with the fogs on. I did it to have the fogs on with the high beams and to have the ability to turn off the headlights and just use fogs on foggy nights. I did have one question about the mod, but I will ask that in a new thread.
Now that most of my "cosmetic" changes are done (debadge, new lights, foglight mod) next comes my Cobb and various other perf purchases. First one - STi short throw and STi trans mount.
Moses
Old 06-20-2002, 04:54 PM   #21
Julio
Member#: 6363
10 Sec. Club
Element - Crawford
OK, so I used Sylvania's Silverstars for the headlights...didn't see any increase at all except it is whiter, but not brighter...that's ok...Now I need better fog lights, BRIGHTER, andwhiter if possible...that will not melt my harness. Any suggestions?
I REALLY need the fog lights to back me up in many long dark places I have to drive daily..
Julio is offline   Reply With Quote
Old 06-25-2002, 08:16 AM   #22
Jasno999
Member#: 9262
2002 WRX Sedan
Blaze Yellow
Foglights-
Go with the PIAA bulbs. They have a nice tint and will work with your factory harness without problem. HID is to expensive and complicated to install if you don't really want them. The PIAA bulbs are pretty easy to install and I like how they look. They light the road up well.
Old 06-25-2002, 09:18 AM   #23
Julio
Member#: 6363
10 Sec. Club
Element - Crawford
Any specific wattage?
Old 06-26-2002, 07:33 AM   #24
Jasno999
Member#: 9262
2002 WRX Sedan
Blaze Yellow
I think it is 55-80W
Old 10-07-2012, 06:41 AM   #25
Daddy_Digital
Member#: 274205
2002 WRX Sport Wagon
World Rally Blue
Subscribed.
Daddy_Digital is offline   Reply With Quote
04 WRX parking light bulb? Jay04WRX Electrical & Lighting 7 06-15-2010 08:56 PM
2002 WRX fog light bulb size mhwrx02 Electrical & Lighting 1 06-18-2008 10:06 PM
quick question about buying new turn signal bulbs/ parking light bulbs SoareS Newbies & FAQs 1 10-08-2005 07:43 PM
How do you change the WRX parking light bulbs? YeeHa Interior & Exterior Modification 5 02-03-2002 05:06 AM
danger of high wattage? or What parking light bulb? technix Interior & Exterior Modification 2 09-27-2001 11:38 AM
