Old 07-05-2010, 12:13 PM   #26
eg33GC
Member#: 206851
56 Belair
Pro Street
Originally Posted by madmax718 View Post
# 100% CO2 -Lowest price, generally greatest penetration, and higher levels of spatter. Limited to short circuit and globular transfer.
# 75% Argon - 25% CO2 -Higher price, most commonly used by home hobbyist and light fabricator, lower levels of spatter and flatter weld bead than 100% CO2. Limited to short circuit and globular transfer.
# 85% Argon - 15% CO2-Higher price, most commonly used by fabricators, with a good combination of lower spatter levels and excellent penetration for heavier plate applications and with steels that have more mill scale. Can be used in short circuit, globular, pulse and spray transfer.
# 90% Argon - 10% CO2- Higher price, most commonly used by fabricators, with a good combination of lower spatter levels and good penetration for a wide variety of steel plate applications. Can be used in short circuit, globular, pulse and spray transfer.
This is all for MIG.
For Tig, you don't want to use c02 generally.
90/10 works great, but 100% Ar is the way to go.
eg33GC is offline   Reply With Quote
Old 07-15-2010, 11:42 AM   #27
wisconsinsubaru
Member#: 232342
At our (Large) Fab shop we always use 75/25 for MIG
100% Argon for TIG
wisconsinsubaru is offline   Reply With Quote
Old 08-15-2010, 03:19 PM   #28
Burnman
Member#: 218087
95 Legacy
That ugly 'spruce' green.
Originally Posted by Hoo View Post
As for sharpening the tungsten the only thing you really need to pay attention too is that the grind marks should be running parallel with length of the tungsten. This will help to focus the arc and help make the point last longer. Most people use bench grinders, I have a coarse and a fine wheel at the shop, use the coarse wheel to rough it out and finish it on the fine wheel. They also make dedicated sharpeners but you dont need one of those.
Our welding shop at work doesn't have a dedicated sharpening machine, but they do have a dedicated bench grinder with a different wheel that is only for tungstens. Reduces contamination.
Burnman is offline   Reply With Quote
Need shop that has stainless steel pipe & welds with tig? si12j12 Southern California Impreza Club Forum -- SCIC 1 01-10-2009 07:19 PM
North NJ Exhaust Shop with Tig Welding Experience!! CoBB_tHiS! Tri-State Area Forum 6 12-12-2008 05:45 PM
Where to get exhaust welded up in Portland? Flowmastered87GL North West Impreza Club Forum -- NWIC 1 04-13-2004 11:59 AM
SS exhaust welding in LIC,Queens area? xfrickx Tri-State Area Forum 1 07-15-2003 10:46 AM
I need to have my exhaust welded...any good shops in NJ?? SoLiDbReAkZ Tri-State Area Forum 8 08-16-2002 06:17 PM
