Old 06-26-2010, 11:14 AM   #1
Odin2347
Member#: 244027
2010 WRX
Default 2010 WRX crazy noise after clutch install
Hey I had my clutch replaced under warranty by the dealer on my 2010 4 dr(7k miles) they said it was a faulty clutch. I got the car back from the dealer and today I notice when I start building boost at around 3-4k rpms I hear the turbo alot louder and then a loud whining/screeching/whooshing noise that sounds like air leaking rapidly and the car seems to pull rather sluggishly. I have no clue what could have happened. any ideas? I think it could be an exhaust leak. Do they touch the exhaust during a clutch install?
Odin2347 is offline   Reply With Quote
Old 06-26-2010, 02:23 PM   #2
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
get back to the dealer asap. the car is new and they just worked on it.
424wrx is offline   Reply With Quote
Old 06-26-2010, 05:59 PM   #3
Odin2347
Member#: 244027
2010 WRX
I plan on taking it on monday. Do you think it's OK to drive in the meantime?
Old 06-26-2010, 06:03 PM   #4
stikid2005
Member#: 76228
2005 STI (sold)
OBP Seibon carbon
your uppipe is prob leaking. they most likly took it off during the the clutch job and didnt tighten it back up.
if you dont have to drive it dont. if you do stay out of boost till you can get it to the dealer
stikid2005 is offline   Reply With Quote
Old 06-26-2010, 06:09 PM   #5
Odin2347
Member#: 244027
2010 WRX
Would it be possible for me to tighten it myself if that is the issue? that would save alot of gas and toll $$$ as the dealer is over the bridge from me in brooklyn
Old 06-26-2010, 06:43 PM   #6
stikid2005
Member#: 76228
2005 STI (sold)
OBP Seibon carbon
well... i would check it, however... i would still take it to the dealer. spec if it happend because of somthing the dealer did. Also to cover yourself in case somthing goes wrong with it. you have a warrenty, use it! haha i wish i had one!
Old 06-27-2010, 01:42 AM   #7
kickniteasy
Member#: 201661
2013 STI
2002 Forester
definitely take it to the dealer....you try something yourself and mess it up you could end up voiding your warranty. It's a free fix and while it may be a PITA to get there it'll be worth it just to say it's their fault.
kickniteasy is offline   Reply With Quote
Crude Transmission Deceleration and Acceleration Noise after Clutch/Flywheel Install caterpill Transmission (AT/MT) & Driveline 271 05-20-2015 05:36 AM
2010 WRX Sedan System After Market Install (Alpine) Help! qronos Car Audio, Video & Security 3 04-25-2010 10:53 AM
CRAZY noise after coilover install g00dhum0r Brakes, Steering & Suspension 14 07-28-2008 12:56 AM
Seeking Input: Bad noise after clutch install mx_9 Transmission (AT/MT) & Driveline 3 06-04-2007 02:13 PM
Crazy noise after Uppipe install??? swilson Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 06-11-2004 04:27 AM
