Old 06-26-2010, 10:39 PM   #1
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
Default 03 H6 Outback stalled, no codes
On a coupla rare occasions in the past, my wife's Outback has set the CEL and I've only read misfire codes. She never reported poor running. The car has fairly low miles - 55K and is fairly well maintained. purchased new, never wrecked.
Recently, the car stalled after moving about 2 blocks or so from being parked, then it restarted. No CEL and no codes were stored. No poor running conditions. This is very disconcerting.
Is there a known issue like this? Some kinda relay dropping out or something?
thanx for any help.
1 Lucky Texan is offline   Reply With Quote
Old 06-29-2010, 12:01 PM   #2
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
so, perhaps this was a one-off event since no one has responded.
My middle daughter once owned a 90 maxima that would stall. It was a 'motor control relay' IIRC that was intermittent. Just wondering how a no code stall could happen in my wife's Outback and if there was 'pre-emptive strike' I could take to help prevent it happening again.
anyone?
Old 06-29-2010, 12:57 PM   #3
vrusso
Member#: 207074
2015 STI
You know you're jealous
Automatic, Manual? How does the stall occur? Is it while under gas or while coasting to a stop?
vrusso is offline   Reply With Quote
Old 06-29-2010, 02:12 PM   #4
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
4eat, happened once when my wife was driving. Evidently after pulling out from a parking lot onto a secondary street approaching a light so, low-moderate throttle. I don't have specifics since I wasn't in the car. She said it re-started normally.
Old 06-29-2010, 02:33 PM   #5
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
I agree that it's a bit disconcerting, but a single event with no (reported, at least) abnormal indications before or after and no CEL is going to be awfully hard to troubleshoot. Have you had the codes read? Even if the CEL hasn't been triggered there can be pending codes in the memory that might tell you something.
Pat Olsen
Old 06-29-2010, 02:44 PM   #6
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
Pat Olsen
I checked with my innova - no codes or 'freeze frame' w'ever.
yeah, intermittent stuff is bad. Worse when it's your wife's car lol!
Old 06-29-2010, 03:00 PM   #7
vrusso
Member#: 207074
2015 STI
Notice any leaks when it sits in its normal parking spot? Whats the transmission fluid level? Though a completly different vehicle I have a coworker that drives a late 90's jeep and it leaks auto trans fluild and when low it stalls out.
Old 06-29-2010, 03:17 PM   #8
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
No leaks but I will check the fluid level - it's been ah - since April- since I checked.
Old 07-01-2010, 11:40 AM   #9
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
further interrogation reveals the car was at idle at a light when it stalled. It appears it had also been running for 20 minutes or so and the a/c was on. I'd say that means it was at operating temp too. (not a 'cold' engine)
Old 07-01-2010, 11:50 AM   #10
vrusso
Member#: 207074
2015 STI
I am not sure about this because of the differences in trans. however my car (01 OBS) had a TPS go bad and it did not report any codes until a complete failure of the sensor. As it started to go bad every time I put the clutch in my engine would die if I did not give it a little bit of gas. Eventually it returned a code and I was able to determine the fault.
Old 07-01-2010, 12:06 PM   #11
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
good post - I'm gonna keep this in mind if it happens again. How many miles on you OBS when the TPS failed?
Old 07-01-2010, 02:46 PM   #12
vrusso
Member#: 207074
2015 STI
Around 140,000
No spin-on ATF filter on 2002 4EAT H6 Outback (at least not on tranny...) rjp98outlook Transmission (AT/MT) & Driveline 1 06-18-2009 01:21 AM
93 1.8 Impreza, stalling/engine codes??? 84cj Normally Aspirated Powertrain 11 11-20-2008 07:49 PM
Rough Idle, stalling, P0172 code, please help msdss Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 06-23-2006 12:08 AM
AutoWeek report on the new H6 Outback gtguy Legacy Forum 1 08-24-2000 03:41 PM
Anyone know pricing on the H6 Outbacks? Paisan Legacy Forum 0 05-16-2000 11:14 AM
