Old 06-27-2010, 11:41 AM   #1
4subaru
Member#: 129895
Default DOHC 2.5 injector upgrade???
I'm looking for a small upgrade for my DOHC 2.5 red top injectors. I have searched but have not found anything clear about if there is anything that will fit into my fuel rails and is in the 400 to low 500 cc range. Sorry if this has been covered before, just trying to get some solid info.
4subaru is offline   Reply With Quote
Old 06-27-2010, 08:59 PM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
Are you getting more air than usual? What are the current mods? Unless you have quite a wild build, you won't need bigger injectors. Fill out your profile.
Old 06-28-2010, 04:34 PM   #3
4subaru
Member#: 129895
Running this in a circle track stock car. Started off as 95 Impreza, but it is mixed and matched parts from different models and years. Running 97 Dohc 2.5 in it with a 5 speed. Trying to tune my car using a AFR gauge, i'm finding that the car is running about 15.1. I have after market electric fuel pump coming from a fuel cell, so that is not limiting me. I figured going with next size up injectors will bring me back into the lower 14s on the AFR gauge.
Old 06-28-2010, 07:38 PM   #4
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Sumthin' ain't right with your combo of parts. Even with ported heads, reground cams, etc etc, my '97 DOHC EJ25 still ran rich. As I recall I had to pull 15% or so with the S-AFC at the top end. The engine made 50% more power than stock at redline, yet was still rich using a completely stock fuel system.
Pat Olsen
WTB : wrx/dohc 2.5 Oil Filler Neck 2ez4me Private 'Wanted' Classifieds 2 06-27-2010 10:55 AM
95' 2.2 w/ 98' DOHC 2.5 heads? downshift1 Normally Aspirated Powertrain 6 04-20-2007 11:54 AM
1997 Dohc 2.5 with 1997 2.2 Heads? narib2001 Normally Aspirated Powertrain 3 01-23-2007 01:01 AM
('93-'01) DOHC 2.5 owners w/ oil consumption probs, pls reply cakagan Impreza Forum 7 06-28-2001 02:14 PM
SOHC or DOHC 2.5 power difference? MK1ofMnM Normally Aspirated Powertrain 6 05-31-2001 11:17 AM
