Vancouver Impreza Club
Old 06-27-2010, 03:19 PM   #1
J_ride008
Member#: 216669
2002 Impreza WRX
Default Are these headlights legal?
Are these Headlights legal in canada?
[IMG][/IMG]
J_ride008 is offline   Reply With Quote
Old 06-27-2010, 03:54 PM   #2
Irish2ner
Member#: 249324
04 WRX
Im not sure but those are sweet!! I really like that look
Irish2ner is offline   Reply With Quote
Old 06-27-2010, 03:55 PM   #3
J-Chow
Member#: 104722
2006 2.5i - SOLD
Gray
i don't see why it would be illegal ...
J-Chow is offline   Reply With Quote
Old 06-27-2010, 04:23 PM   #4
lummer shawn
Member#: 71484
02 2.5 RS
BRP
Are they DOT/SAE approved? That would be a good place to start.
Then look at the BC Laws for headlamps.
http://www.bclaws.ca/EPLibraries/bcl...eside/96318_00
lummer shawn is offline   Reply With Quote
Old 06-27-2010, 10:12 PM   #5
keifun
Member#: 176100
03 Bugeye WRX
oh morettes headlights...
I'm sure they're fine if they're DOT approved..
keifun is offline   Reply With Quote
Old 06-28-2010, 02:57 AM   #6
tora
Member#: 5851
09 Forester XT
+ NA Miata
As long as they have DRL's and are either DOT/SAE or whatever approved.
tora is offline   Reply With Quote
Old 06-28-2010, 07:03 PM   #7
J_ride008
Member#: 216669
2002 Impreza WRX
I found this on the motor vehicle act regulations. I put it in bold writing and it was in chart form. Does anyone understand it? Heres a link to the chart http://www.bclaws.ca/EPLibraries/bcl...eside/26_58_01
Schedule
Table 1 Standards for Approval of a Motor Vehicle Headlamp
and Other Illuminating Lamps Aiming Requirements
[en. B.C. Reg. 476/98, s. 2.]
Visual aim based in millimetres at 7.62 metres
Headlamps Beams to be Used When Aimed or Inspected Area of High Intensity Zone to be Aimed or Inspected Lateral Aim Lateral Inspection Tolerance Vertical Aim Vertical Inspection Tolerance
146 mm Type 1 sealed beam Upper Centre At V 150 mm left to
150 mm right of V 13 mm up from H 125 mm up to
100 mm down
from H
146 mm and 178 mm Type 2 sealed beam Lower Left Edge
Top Edge 25 mm right of V 100 mm left to
150 mm right of V 60 mm up from H 175 mm up to
50 mm down from H
178 mm sealed beam not marked Type 2 Upper Centre At V 150 mm left to
100 mm down
from H
European headlamps marked "E" and beam lamps marked "R" or "HR" Upper Centre At V 125 mm left to
125 mm right of V At H At H to 115 mm below
Low beam lamps marked "C" or "HC" Lower Junction of horizontal and sloped cut off
Top edge of horizontal cut off At V 125 mm left to
125 mm right of V
100 mm below H 75 mm below to
190 mm below H
Dual beam lamps marked "CR" or
"HCR" Lower and Upper Top edge of horizontal cut off
125 mm right of V 100 mm below H 75 mm below to
190 mm below H
Fog lamps symmetrical Centre
Top edge At V 150 mm left to
150 mm right of V 100 mm below H At H or below
Fog lamps asymmetrical Left edge
Top edge 25 mm right of V 100 mm left to
100 mm right of V 60 mm above V 175 mm above to
50 mm below H
Auxiliary passing lamp Left edge
100 mm right of V 60 mm above H 175 mm below to
50 mm below H
Auxiliary driving lamp Centre At V 150 mm left to
150 mm
100 mm
down from H
Motor vehicle minimum beam candela: Upper beam, 10 000; lower beam, 7 000.
Motorcycle minimum beam candela: Upper beam, 5 000; lower beam, 3 500.
This standard is based on S.A.E. standardLighting Inspection Code and recommended headlamp tolerances for E.C.E. lamps
supplied by the Road and Motor Vehicles Safety Section, Transport Canada.
Abbreviations: V=vertical centreline straight ahead of lamp centre. H=horizontal centreline at level of lamp centre.
Contents | Division 1-4 | Division 5 | Division 6 | Division 7-9 | Division 10-18 | Division 19-23 | Division 24-25 | Division 26-28 | Division 29 | Division 30-34 | Division 35-36 | Division 37-40 | Division 40A-42 | Division 43 | Division 44-47
They are marked "E" on them. So I'm thinking as long as I get them within the limits of the beam of light.
Old 06-28-2010, 07:30 PM   #8
talsnic
Member#: 163097
as much as we want to get all technical, it doesn't matter. As long as its DOT or similar, it should be fine.
Most law enforcement will not even pull over guys with PnP HIDs, let alone cars with aftermarket headlights.
talsnic is offline   Reply With Quote
Old 06-28-2010, 10:22 PM   #9
Loomin
Member#: 118113
98' Stagea 260RS
Autech Ver.
they didnt like my buddies yellow bulbs haha. id say as long as your not blinding the **** out of people or running 12,000k HID's nobody will even notice.
Loomin is offline   Reply With Quote
Old 06-29-2010, 12:25 AM   #10
jameseshepherd
Member#: 39766
2006 WRX
SGM
Hell, these are legal (properly covered - only two of them allowed to be uncovered except for "off road") per BC regulations
jameseshepherd is offline   Reply With Quote
Old 06-30-2010, 02:54 AM   #11
hipower
Member#: 155756
369 tribeca 7 pass
vf34wrx,06 sti,08cbr600rr
I used to have those lights on my bugeye for 5 years and never had a problem with police
hipower is offline   Reply With Quote
Old 07-05-2010, 12:25 PM   #12
raska
Member#: 175595
2008 STi
When it comes to lights, most things you see out there are ILLEGAL. Basically no light, or reflector changes are allowed, including tinting.
MVA section 4.02:
(2) A vehicle on a highway must be equipped with lamps equivalent to those provided by the original manufacturer in accordance with the requirements that applied under the Motor Vehicle Safety Act (Canada), or a predecessor to that Act, at the time of vehicle manufacture.
raska is offline   Reply With Quote
Old 07-05-2010, 01:25 PM   #13
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
Technicality says that you cannot mod your headlights period - however, anything labelled DOT or E Code (something like ECE) and properly adjusted, you won't get troubled
kgb is offline   Reply With Quote
Old 07-05-2010, 08:10 PM   #14
J_ride008
Member#: 216669
2002 Impreza WRX
The guy from morette said they have an E code. He didn't say in the email if they where DOT. I originally thought they made them for right hand drive only. But they do also make the for left hand drive as well.
Old 07-06-2010, 02:16 AM   #15
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
Canada will take E Code, other than the fact that it's not stock (which is all that is allowed when it comes to headlight) - as long as it's LHD and the key is properly adjusted
Old 07-06-2010, 04:24 AM   #16
2010 WRX Limited
Member#: 217458
1989 Mazda Miata
Classic Red
Who cares if it's legal. I get blinded by those retarded HID lights that everyone puts in thier regular lenses all the time. Doesn't seem to stop anyone.
2010 WRX Limited is offline   Reply With Quote
Old 07-07-2010, 03:45 AM   #17
Subaru_Salesman
Member#: 241382
Once you have SAE number on lens, it will be fine!!!
Subaru_Salesman is offline   Reply With Quote
Old 07-07-2010, 03:48 PM   #18
raska
Member#: 175595
2008 STi
All the codes in the world don't mean anything if you have a officer that is clear on the Motor Vehicle Act, and wishes to give you a hard time about them. If they aren't too crazy, or annoying, you may get lucky for a long time, but I've been in a car which was issued a VI, and tried to plead with the "but.. this certification code" excuse. Doesn't work every time.
Old 07-09-2010, 07:23 PM   #19
ralli-tart
Member#: 106125
06 OZ aw wagon
+ eleventybillion
i wish a terrible pox on those peoples
ralli-tart is offline   Reply With Quote
what are these headlights? FromEvoToRS37 Electrical & Lighting 1 08-15-2006 07:31 AM
Are these headlights decent? Phantron Electrical & Lighting 6 12-30-2005 11:01 PM
are these headlights legit... gtlegg Impreza Forum 5 12-21-2004 11:54 AM
Are these headlights different? baileypicks24 Interior & Exterior Modification 6 10-12-2004 10:41 PM
Are These Headlights Any Good? scrappy doo Electrical & Lighting 2 10-17-2003 12:39 PM
