Old 06-27-2010, 03:35 PM   #1
1thirteen3
Member#: 207069
99 Gc8 Ver8 sti
stb matte black
Default having mass air flow wiring problem on my gc8!!!!
was driving down the street and all of a sudden when i went to accelerate my car wanted to bog out, i pulled over and pin pointed out that a wire was starting to fray and the back end of the plug that plugs into the mass flow sensor. got the car home took apart the clip to re-wire it back into the plug, got that done and plugged back into my mass flow sensor and disconnected my battery to reset my ecu etc, re-connected the battery and wont start up!!!!!! soooooooo does any one please have any troubleshooting tips for me???? can post em up on here or email me them as i will prob get them sooner by email, thanks alot [email protected]
1thirteen3 is offline   Reply With Quote
Old 06-27-2010, 08:55 PM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
Are you sure you wired it correctly? Will it start/run with the sensor completely unplugged? Check all fuses. In engine compartment and under dash. Also, search on not starting, there are MANY threads on it. Could yield some good ideas.
Old 06-28-2010, 09:51 AM   #3
dstan
Member#: 120386
2000 BRP 2.5RS Coupe
Wow the 89 Civic is fast
Gm6
dstan is offline   Reply With Quote
Old 06-29-2010, 06:10 PM   #4
1thirteen3
Member#: 207069
99 Gc8 Ver8 sti
stb matte black
ya its wired in correctly, ive checked all fuses and they are all good. ive taken the terminals off the battery and pumped the brake to rest the ecu, and have also tried starting it without the sensor plugged to bypass it but still wont go, it wants to start but just no jam? thanks for the info ill check that out!
Old 06-29-2010, 06:43 PM   #5
vrusso
Member#: 207074
2015 STI
You know you're jealous
Sounds like there is another issue other than that plug
vrusso is offline   Reply With Quote
Old 06-29-2010, 07:34 PM   #6
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
Time to inspect for spark and fuel delivery. I would start with fuel since the problem first started when you asked for more of it. If you know anyone with the same MAF you could try swapping a known good one in to rule it out completely.
Old 06-29-2010, 07:39 PM   #7
dcleal
Member#: 178135
2006 Impreza 2.5i
did you turn the car off when you pulled over or leave it running?
dcleal is offline   Reply With Quote
Old 06-30-2010, 05:00 PM   #8
PhilSine
Member#: 130489
02 WRX Wagon (WRB)
98 OBS-T, 91 Legacy SS
My bet is a cam sensor.
PhilSine is offline   Reply With Quote
Old 07-02-2010, 01:57 PM   #9
1thirteen3
Member#: 207069
99 Gc8 Ver8 sti
stb matte black
when i pulled over i left it running to look under the hood and when i was looking for throttle problems next i checked the intake system and when i move my cold air, my engine started to idle down, put the intake down back on its brackets and it ran fine after that. started checking th wiring on the intake and my engine stalled out!?
Old 07-02-2010, 02:02 PM   #10
1thirteen3
Member#: 207069
99 Gc8 Ver8 sti
stb matte black
ive checked the plugs already and they are fine but havnt checked fuel delivery yet, tryin to get it donew hen i am workin 16 hour days so its hard to get time for her, but ive also heard of the cam sensor problem, does anyone know exactly where the black wires are, under drivers side that will give you sequenes flashes on your dash so you can figure out the coding on what the problem is?
thanx guys!!
I need help please! Mass Air Flow Plug problem! 1st_1_down Newbies & FAQs 0 08-29-2007 09:12 PM
Mass Air Flow Sensor problem temtiv Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 13 08-23-2007 04:48 PM
Mass Air Flow Sensor problem temtiv Normally Aspirated Powertrain 1 08-22-2007 02:29 PM
resetting my Mass air flow sensor? Woofy Normally Aspirated Powertrain 1 02-09-2006 10:43 PM
Mass Air Flow senser problem Constantinos Normally Aspirated Powertrain 5 04-14-2002 05:39 AM
