Old 06-28-2010, 06:16 PM   #1
DreadyRider
Member#: 233060
Default No spark
I have a 95 subaru imprezza l 1.8L. One day may car was running and then it stopped and wouldn't start. I replaced the coil pack and still none of the plugs are getting spark. I would greatly appreciate some help with this, as it is my daily driver.
DreadyRider is offline   Reply With Quote
Old 07-02-2010, 12:12 PM   #2
Jessekrs123
Member#: 236927
2015 BRZ, 93 Legacy,
1984 BRAT
You could have bought a bad coil pack. Check you igniter, make sure that it is getting power. Make sure your wires are in good condition also. If everything checks out OK, then you might have a bad ground somewhere. Bad grounds are such a joy to find.
Jessekrs123 is offline   Reply With Quote
Old 07-02-2010, 12:26 PM   #3
PhilSine
Member#: 130489
02 WRX Wagon (WRB)
98 OBS-T, 91 Legacy SS
Ignitor, cam position sensor, crank position sensor. The three most common culprits to no spark issues.
Check voltages and grounds from there.
PhilSine is offline   Reply With Quote
Old 07-02-2010, 12:55 PM   #4
flstffxe
Member#: 155358
2008 Forester
Steel Silver
^^ this
flstffxe is offline   Reply With Quote
Old 07-02-2010, 02:11 PM   #5
Luckyduck919
Member#: 107430
1993 Impreza
Seafoam
Did you check the timing belt?
Also, if you can, pull the trouble codes. To do this you connect the two green connectors under the driver side dash, then the CEL should start flashing. Long flashes are a 10 and short flashes are a 1.
So long, short, short would be 12 and long, long, short would be 21.
Luckyduck919 is offline   Reply With Quote
96 brighton 1.8l impreza 1-2 spark 3-4 no spark WRXR1A10 Normally Aspirated Powertrain 6 12-28-2007 02:52 PM
Ignition Issues - No spark, no timing? Logannz Electrical & Lighting 0 03-13-2007 05:37 PM
EJ22 Swap - No Spark... no ground for fuel pump relay?? Subarutex Subaru Conversions 5 01-22-2007 12:14 PM
There's just no spark... no electricity... Hypernoodle Off-Topic 32 07-06-2006 02:14 PM
no spark & no fuel = no start Annoying Eric Normally Aspirated Powertrain 7 08-30-2005 08:58 AM
