Old 06-29-2010, 03:44 AM   #1
feint05
Member#: 152984
2004 jewbaru
jewbuilt, polish tuned
Default help: cooling system this car is kicking my ass
car 1998 forester 2.5na phase 1
the previous mechanic drilled holes in the stock thermostat to "keep it cool"
so i bought a new failsafe thermostat and gasket as well as bypassing the throttle body deicer, installed them and now
i did my best to burp the cooling system
the system doesnt have any leaks but wont fully pressurize
the coolant temp sender never moves, it just stays at the bottom
so what do you think, air pocket at the top?
FOUND IT theres a one wire connector to the right of the coolant temp sender, it is part of the sensor and once it was rehooked it was fixed
feint05 is offline   Reply With Quote
Old 06-29-2010, 04:01 AM   #2
Henry H
Member#: 184330
2008 Impreza 2.5i
Dark Grey Metallic
That makes my head hurt.
Thermostat either doesn't work or isn't hooked up properly. You might want to check for voltage levels while getting the car warmed up. If you feel there might still be pockets of air then try this.
The the front end as high as you can (uphill, jack it up, combo of both with GREAT CHOCKS)
Uncap your radiator (engine cold)
Turn on heater full blast
Turn on car
Wait for more burping
You know the rest
Henry H is offline   Reply With Quote
Old 06-29-2010, 09:04 AM   #3
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
It's entirely possible that the coolant temp sender is dead, which would explain the gauge never moving.
On my '97 and '99 2.5GTs, which is the same engine, the radiator has a vent plug on the top on the passenger side (opposite end from the radiator cap). Did you remove that while filling? That definitely helps get air out of the system as you top off the radiator. I've never had to resort to any sort of tricks to get the system full. Well, I guess that's not entirely true. I'll remove the vent plug and radiator cap, fill the system, then reinstall the vent plug and squeeze the upper radiator hose a few times. That usually forces a bit of air out and the level drops slighly at the fill neck. I then remove the vent plug again, top off the radiator, and reinstall the vent plug and radiator cap.
Concur!
Not sure what you're thinking of here, but the thermostat isn't "hooked up" to anything, and certainly doesn't have any voltage going to it! Maybe you meant to say the coolant temp sending unit?
Old 06-29-2010, 03:21 PM   #4
feint05
Member#: 152984
2004 jewbaru
the coolant temperature sender was working yesterday before hand, i kind thought maybe i have an air pocket that leads up to it.
keep in mind im not making any pressure which is a bad sign, gonna do this all over again today
Old 06-29-2010, 03:26 PM   #5
Henry H
Member#: 184330
2008 Impreza 2.5i
Dark Grey Metallic
Oops, changed thermostat on house last night. But yes.^^
Subaru Cooling System Conditioner - What IS this stuff? jac04 Service & Maintenance 51 10-17-2007 09:54 AM
This toddler will kick your ass ktnndal Off-Topic 26 05-31-2007 04:53 PM
So I drove KC's car and it kicked my ass. ratt_finkel Motorsports 14 03-29-2007 08:24 PM
So, my roommate wants to kick my ass TheRex Off-Topic 36 01-18-2005 01:11 AM
this intranet worm is kicking my ass *help* Johnny Knoxville Off-Topic 13 08-17-2003 07:43 PM
