Welcome to the North American Subaru Impreza Owners Club Sunday September 21, 2014
Old 06-29-2010, 10:54 AM   #1
smurray346
Member#: 237215
Default 2008 OB running rough
Hi, I have a stock base level 2008 outback 2.5 automatic. The car has been great to me until having recently returned from a 3000 mile drive. The problem occurs mostly at start up and only intermittently so far. I go to start it cold and the engine sounds/feels like it drops a cylinder. It begins to stutter and vibrates more noticeably. I thought at first maby an engine or trans mount had went south but there is definitely a sputter from the engine accompanied by a loss in power. It hadnt thrown a CEL at me until yesterday. I started it cold again and the problem persisted longer than usual. I drove it for a few miles and during that time it sputtered often and the CEL flashed briefly then went away.
Until then i had only noticed it during the first few seconds of starting the car. It would stumble for a second or two, i would give it a little gas, and the problem seemed to clear itself.
Ive changed my oil in the last 100 miles, and it went in for its 60k service at the dealership just 10k-15k ago. The car has 75k on it.
Im guessing that since it threw a CEL I should just go get it read and find out whats wrong for sure, but does anyone have a clue as to what could be causing this? I imagine its something to do with spark or fuel, most likely a bad plug or something. If so im not in any immediate danger of causing damage while driving it, correct?
Thanks for any advice.
SMurray
smurray346 is offline   Reply With Quote
Old 06-29-2010, 11:31 AM   #2
doubledribble
Member#: 42912
2003 Outback Sport
bird **** & door dings
how many miles are on your car? are you due for 30k maint? fuel filter, plugs...etc.
doubledribble is offline   Reply With Quote
Old 06-29-2010, 12:22 PM   #3
PhilSine
Member#: 130489
02 WRX Wagon (WRB)
98 OBS-T, 91 Legacy SS
When the CEL comes on and stays on, have it read. Let us know what it is and we'll go from there.
Could be a bad plug, bad wire, vacuum leak, or a host of other things.
PhilSine is offline   Reply With Quote
Old 06-30-2010, 09:05 AM   #4
smurray346
Member#: 237215
The car has about 75K on it, just went in for its 60K a couple months ago.
For what its worth I went for a short drive yesterday and the car ran without an issue. Very confusing....
The code that threw the CEL isnt stored in the ecm?
Old 06-30-2010, 10:59 PM   #5
cmiovino
Member#: 134005
2004 WRX Premium
Just try to get to Autozone or Advance Auto when it's on so you can read to code. If it clears, you can't read it (I think?).
Anyway, if you're getting a flashing CEL like I think you are, that means a misfire, and it does match up to the symptoms you're saying you have. When I had misfires in my old subie, it flashed, but then stayed on and waited for me to clear the code, even after turning it off and on.
Some simple things you can do is just check your plugs and wires. Could be something very simple like that.
Old 07-05-2010, 02:30 AM   #6
razrielle
Member#: 205698
Also fill out your profile, you might be lucky and have a subaru guy near you with a code reader, I know that Mine has come in handy a couple times with my friends who didnt feel comfortable driving to autozone with a CEL
razrielle is offline   Reply With Quote
Mass: 2008 OB and 98 Firebird smurray346 Private Vehicle 'For Sale' Classifieds 0 04-14-2010 11:24 PM
2008 2.5i rough starts oZeven600rr Normally Aspirated Powertrain 4 03-15-2009 02:11 AM
('93-'01) car is running rough!....help, quick! nav Impreza Forum 10 04-14-2001 08:20 PM
car running rough...help quick nav Normally Aspirated Powertrain 3 04-14-2001 04:14 PM
