Old 06-29-2010, 10:57 PM   #1
biv343
Member#: 246476
2006 Impreza WRX
Gray
Default Microfiber cloth/Mechanix gloves cleaning
Anyone know the best way to clean off a microfiber cloth and Mechanix gloves? Gloves got a bunch of oil on them, cloth just has the usual dirt and grime from cleaning.
Thanks!
biv343 is offline   Reply With Quote
Old 06-30-2010, 01:17 PM   #2
jefmcc
Member#: 42303
2004 WRX
Rally Blue
http://forums.nasioc.com/forums/show...ght=microfiber
If it's not a really good one, I just toss it in the trash. If you have a Costco near you, you can buy the cheapo kind in bulk.
jefmcc is offline   Reply With Quote
Old 07-01-2010, 12:41 AM   #3
jxkim
Member#: 239150
2003 WRX Sedan
i dont know about the gloves. but i always clean my microfibers separately.
1. wash in regular cycle in HOT water using any normal detergent. DO NOT add bleach or fabric softener.
2. then throw in dryer. DO NOT use dryer sheets. just heat. will come out feeling like new.
3. take out, fold, and store somewhere dust free. i just put them in a shopping bag and tie it closed.
main reason you dont wanna use things like dryer sheets is because anything will cling to microfiber, which is the appeal of it when it comes to drying/cleaning your car. the chemicals will adhere to the microfibers rendering them useless. (or so i hear) i have used the above process many times. so far no need to buy any expensive cleaning agents
i think best mechanic gloves are those thick latex ones i see, usually blue. use em once and throw it out
jxkim is offline   Reply With Quote
Old 07-02-2010, 09:43 AM   #4
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
Those are good for most work. However, when working with some of the heatshielding and in very tight areas I value my Mechanix gloves. Saved me a few times now....
OrbitalEllipses is online now   Reply With Quote
Old 07-02-2010, 09:52 AM   #5
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
^soak the gloves in the sink with some soap.
Psychoreo is online now   Reply With Quote
Old 07-03-2010, 12:41 PM   #6
Noek
Member#: 206316
2009 STI StageII
My microfiber towels get a delicate wash in the machine, then hang dry.
Noek is offline   Reply With Quote
Old 07-03-2010, 01:37 PM   #7
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
....this is what I do. Something like dishwashing detergent or an APC will help cut the grease/grime. I then rinse them out and hang dry. I use nitrile gloves (the blue latex-like gloves) for oil changes and other mechanical work but still have Mechanix gloves for the reasons OE mentioned. ....I use plain latex for detailing (and other gloves for certain chemicals when the need arises).
As for microfiber towels, I wash them based on their task so I reduce the risk of cross-contamination. Heavier soiled items get placed in a 5gal bucket with APC/MF cleaner to soak first. In the washer I use Micro Restore detergent and wash in hot or warm on regular cycle. The idea is to use a clean rinsing soap that won't leave residue in the MF material. I then place them in the dryer on low. They don't need much time since they typically dry very rapidly.
I like to use the dryer for two reasons.... 1) I don't like hang drying MF towels that will be used on my paint. This exposes them to dust/debris that may be floating in the air and is really unnecessary. The dryer will not harm them on low. 2) I simply don't have enough room to hang all of the towels I have in a load. ....and I have a lot of them. IME/IMO MF towels are generally much more resilient than some might think.
Kean is offline   Reply With Quote
Old 07-08-2010, 08:59 AM   #8
slipper
Member#: 165449
I would recommend spot scrubbing the microfibers with regular dish washing liquid. If you have a lot of microfibers, wash them all at once with vinegar in the rinse cycle and stick them in the dryer. Avoid combining microfibers with cotton clothes and towels because they will pick up all the lint and fibers.
slipper is offline   Reply With Quote
Old 07-12-2010, 11:32 AM   #9
GoRabbit
Member#: 251854
2013 WRX
the mechanix gloves are annoying. I agree they are useful but they are also expensive and the fingertips always seem to tear. I have found that motocross gloves are cheaper, last longer, and are more condusive to cleaning. But yeah as far as cleaning them. Fill a bucket with warm soapy water and drop them in. Let them sit for a bit and then ring them out a couple of times repeating the soaking. Once they seem to be clean rinse them with water and hang dry them.
GoRabbit is offline   Reply With Quote
Old 07-13-2010, 03:09 PM   #10
Brian610
Member#: 161477
"Griots Garage" sells a micro fiber cleaner which is an additive to normal detergent. It works great, be sure to never use fabric softener wash them with other micro fiber only and hang drying is best. If they get really nasty soak them in the micro fiber cleaner.
Brian610 is offline   Reply With Quote
Old 07-14-2010, 10:09 PM   #11
Jackie leggs
Member#: 249794
02 WRX wagon
atomic orange pearl
I actually just cleaned my Mechanix gloves about a week or so ago, found out that they should not be used for oil changes . What I did was I filled a bucket with a 50/50 mix of purple power (any household degreaser should work) and hot water. Put the gloves in the mix and let sit for about 20 or so mins. Empty the dirty mix and repeat for another 20 mins (depending on how nasty they are you might need to do this a few more times, your call). Just hang them up to dry somewhere and when they are all dry, they will feel like new!
Jackie leggs is offline   Reply With Quote
Old 07-15-2010, 09:59 AM   #12
adam_m_mcinerney
Member#: 74700
'06 WRX
CGM
Listen to Jackie leggs (nice kangaroo jack reference). Some degreaser and then rinse them well. hang dry.
adam_m_mcinerney is offline   Reply With Quote
Microfiber cloth melt to exhaust. What to do? 04ImprezaWRX Car Care & Detailing 9 05-05-2009 11:12 PM
how to clean a microfiber towel? [27] Off-Topic 16 02-10-2009 11:43 AM
Where to get Mechanix gloves codemunky Southern California Impreza Club Forum -- SCIC 21 12-09-2005 07:20 PM
Mechanix gloves? Fyrfytr Mid Atlantic Impreza Club -- MAIC 11 10-23-2003 03:23 PM
Mechanix glove lost during spring install Aspen_2.5RS South East Region Forum 11 09-16-2002 06:12 PM
