Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Motorsports Specific Items
Old 06-29-2010, 11:08 PM   #1
pinkertonpunk
Member#: 62386
2008 Honda S2000
Chicane Silver
Default GTWORX GT2 (JRZ RS) Coilovers w/plates and springs, 5k miles
Up for sale are my GTWORX GT2 (JRZ RS) coilovers for 05-07 STIs. These are available immediately. These coilovers are great! Just installed them this year; I was one of the first people to get them from Myles at GTWORX. I am going to be selling the car and moving to a different class, so that is the only reason they will be for sale. They will also include the Vorshlag front and rear camber plates. These are the same exact camber plates that GTWORX sells. The springs installed on these right now are 13k (728lbs) front and 12k (672lbs) rear Swift springs with helper springs. These are the best springs available, they have less coils than other springs so they weigh less. With these spring rates I do daily drive the car. It is a bit rough but not too bad considering the spring rates. If you want to buy the coilovers and the camber plates alone I would sell them that way as well. These only have about 4k miles on them.
Here is some information a got from the thread Myles posted on these coilovers:
These are a 2 way adjustable, stainless steel damper designed with the vast engineering and chassis design experience of JRZ, available at a reasonable price from GTWORX. JRZ Suspension is one of the most advanced shock manufacturers in the world with wins in countless race series across the globe including ALMS, Grand Am, FIA GT, and more.
Swift Springs are used at rates from 350 lbs/in front and rear up to 850 lbs/in front and rear. The dampers utilize separate compression and rebound adjustments to help dial the shock in.
This suspension system can be considered a focused track day, time attack, or wheel to wheel set-up that offers outstanding performance with impressive ride quality on the street. Rather than sacrificing performance to maintain a livable ride quality, JRZ can engineer a shock to excel on a variety of surfaces and in a wide range of conditions.
These are perfect for time attack series where a 2 way adjustable shock is needed that does not use a remote reservoir and STILL has 200 psi of gas pressure.
Valving features:
• Adjustable orifices instead of a preloaded shim stack
• Two phase rebound valving
• Special attention paid to low-speed bump damping
• 200 psi of nitrogen pressure to prevent cavitation and provide “platform”
JRZ Suspension uses non-preloaded valve shims and adjustable orifices to control valving. Preloaded valve shims resist initial opening of the valves and build up force and result in a harsh feeling over bumps, which is undesirable in a street or race car.
Two phase rebound valving allows JRZ dampers to provide high levels of response from the piston without using preloaded valve shims. The primary valve stack consists of a main disc and supporting discs of decreasing diameters. This valve stack helps define low piston speed damping in conjunction with the adjustable orifices in the piston rod and is active in the initial opening of the valves. The secondary shim stack restricts the opening of the primary valve stack and controls mid and high velocity damping force
Compression/bump damping which provides "platform" for the car, normally recognized as a reduction in initial body roll, pitch, and dive. A blow-off valve is also present to reduce harshness during high piston velocity events.
Ample nitrogen pressure reduces cavitation and also helps provide "platform" to the car without directly increasing spring rate. Compression damping however does not rely on the gas charge like many other dampers.
I am asking $3300 for everything shipped. If you want to buy them without the springs I would sell them for $3150 shipped. This setup costs $4600 new. PM if interested, or email me at [email protected]
Here are some pictures from the install:
Thanks for looking everyone!
pinkertonpunk is offline   Reply With Quote
Old 06-30-2010, 03:45 PM   #2
Chin
Member#: 632
'12 Cayman R
'07 UGM WRX Wagon
05 STi...NOOOOOOOOO! Exactly what I am looking for, except the hub issue. Maybe I need to upgrade the hubs on the RS, yea that's it. GL with the sale.
Chin is offline   Reply With Quote
Old 06-30-2010, 03:49 PM   #3
pinkertonpunk
Member#: 62386
2008 Honda S2000
Chicane Silver
You should just upgrade to the newer hubs! These won't ship out till September, so you have plenty of time....
Old 07-12-2010, 12:11 AM   #4
pinkertonpunk
Member#: 62386
2008 Honda S2000
Chicane Silver
May consider selling these before September....
Old 08-06-2010, 08:21 PM   #5
pinkertonpunk
Member#: 62386
2008 Honda S2000
Chicane Silver
Bump it up for a price drop. These will be coming off the car in a little over a month. I would like to have them sold then so I can ship them out right away!
Old 08-11-2010, 10:23 PM   #6
pinkertonpunk
Member#: 62386
2008 Honda S2000
Chicane Silver
Bump it up. I am co-driving someone's car at Nationals so these are for sale immediately.
Old 08-14-2010, 02:17 PM   #7
BrianGT
Member#: 75339
Nice shocks. Best of luck with the sale! See you at Nats!
BrianGT is offline   Reply With Quote
Old 08-20-2010, 11:48 PM   #8
pinkertonpunk
Member#: 62386
2008 Honda S2000
Chicane Silver
Sold!
Old 08-30-2010, 02:40 PM   #9
2006stiguy
Member#: 105009
2006 STi
Colin-
I just sold my car and have the exact same set up for sale with only 300 miles on them!! Would you mind passing along my info if anyone is interested?? I am selling mine with a brand new/ never installed RCE front sway for $3800
Andy 220 SM
update sold the front sway!!!
$3650 for coilovers!!!
2006stiguy is offline   Reply With Quote
Old 08-31-2010, 12:28 PM   #10
2006stiguy
Member#: 105009
2006 STi
bump for another set of GT2 coilovers for sale
Old 09-02-2010, 11:32 PM   #11
2006stiguy
Member#: 105009
2006 STi
Ok need these sold asap! Steal them for $3200 plus shipping!!!! First pm wins--------
Old 09-04-2010, 11:08 AM   #12
2006stiguy
Member#: 105009
2006 STi
Labor Day weekend bump
Old 09-09-2010, 01:55 PM   #13
2006stiguy
Member#: 105009
2006 STi
bumpy
FS : GTWORX GT2 (JRZ RS) Coilovers w/plates and springs, 5k miles pinkertonpunk Suspension/Brakes/Handling 5 08-20-2010 11:48 PM
FS: Stock 05 WRX Sedan Springs 5K miles Mizle Suspension/Brakes/Handling 2 11-17-2008 09:45 PM
FS(nc) sti struts and springs 15K miles+ ground control coilovers balisti Suspension/Brakes/Handling 15 06-09-2008 08:18 AM
'05 sti clutch and flywheel 5k miles! White 2.5rs Private 'For Sale' Classifieds 9 06-03-2006 01:21 PM
oil cooler/sti clutch and flywheel 5k miles White 2.5rs NWIC Private Classifieds 4 04-11-2006 02:28 PM
