Old 06-30-2010, 12:57 AM   #1
RuskeR
Member#: 5824
2005 STi Aspen White
1990 240sx "SR20"
Default How to properly correct paint on hoodscoop, mirrors, etc.
My hood scoop is getting dull on my AW STi. I notice the mirrors, and rear bumper is starting to look a little dull as well, although not as bad as the hood scoop. Is the paint just oxidizing?
I'm currently going over the car with Mequires 205. I did hit the hood scoop with the 205, and it did make a difference, but it's not back to normal. Should I try a more aggressive pad, or will I need to step it up to something like 105?
RuskeR is offline   Reply With Quote
Old 06-30-2010, 01:51 AM   #2
REVNU
Member#: 82147
2005 WRX Sedan
Try 105 on a Polishing Pad, usually works on my AW WRX. If that doesn't do the trick, then 105 on a light cutting pad (orange), followed by 205 + polishing pad. If that still doesn't give you the desired results then try a 3 step. 105 + Orange, 105 + white, 205 + white.
I know, sounds like a lot of work, but that combo works great on my car. It comes down to how anal you are about your paint and how much work you want put into it. Work from the least aggressive to the most aggressive one I outlined until you get the desired results.
REVNU is offline   Reply With Quote
Old 06-30-2010, 10:16 AM   #3
jefmcc
Member#: 42303
2004 WRX
Rally Blue
Can you post a picture of the hood scoop? The paint failed on mine. Not only on the leading edge, but on the main surface as well. On the leading edge it just chipped and flaked off. On the top and back surface the clear coat became pitted and worn. There are a few in the parking lot at work too, and every one looks the same.
I bought another scoop (used) to practice painting on. Not having a spray booth, I bought several rattle cans and everything else needed from paintscratch.com. I spent a lot of money, time, and trial and error. I ran out of paint, and patience. I called the body shop that my Subaru dealer uses and was quoted $100 bucks to have it done professionally.
As it is now, I have the half assed one I did on the car, and I'm going to take the other one to the shop and have them do it.
It was a fun learning expierence, and I think I could do better, if not perfect, if I was to do it all over again.
So, you can either buy all the materials yourself and give it a go, or pay $100 and just be done with it. I spent over $100 in material alone.
jefmcc is offline   Reply With Quote
Old 06-30-2010, 11:57 AM   #4
Dave_zok
Member#: 225034
2006 STI
same way you corrct paint anywhere else, you can get this for a cordless drill
http://www.adamspolishes.com/p-430-a...ffing-kit.aspx
I just use my standard 6.5" pad with my flex, there is some overspray sometimes but i do those spots in the beginning before the pad gets saturated.
Dave_zok is offline   Reply With Quote
Old 06-30-2010, 01:41 PM   #5
RuskeR
Member#: 5824
1990 240sx "SR20"
I don't have a picture right now, but it just looks hazy. It's hard to tell because it's white, but when it's your own car you will see things others cannot.
I don't have any 105 right now, and would have to order it online as no one around here carries it. I'll try 205, and an orange pad and see what kind of results I get. When I used the white pad, and some 205, I was able to get some of the shine back. It wasn't perfect, but I only did a test area with minimal pressure.
One other question I had was do you guys leave the scoop on the car? As you know the PC vibrates like mad, and it seems to really shake the scoop more than I'd like. The problem is if I took it off the car to polish it, how would I keep it in place? Any ideas?
Old 06-30-2010, 01:42 PM   #6
RuskeR
Member#: 5824
1990 240sx "SR20"
.. in any case I can't believe all the hours I've wasted in my life hand waxing anything.
Old 06-30-2010, 02:37 PM   #7
REVNU
Member#: 82147
2005 WRX Sedan
I leave it on the car. I usually use my 4" pads on the scoop area and it's fine. I've used 6.5" pads also and had no problems with leaving the scoop on the car. Just be careful around the edges...
Old 06-30-2010, 02:44 PM   #8
RuskeR
Member#: 5824
1990 240sx "SR20"
I currently use the 6.5 pads to give me some extra insurance on the edges of the backing plate.
Old 06-30-2010, 06:12 PM   #9
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
....Meguiars Ultimate Compound should be readily available through your local auto part retailer. The formulation is the same SMAT technology as M105 and M205. UC is essentially the consumer version of M105 and is not quite as aggressive. Ö.itís a good OTC solution that may just give you the added bite you need.
Kean is offline   Reply With Quote
Old 06-30-2010, 06:15 PM   #10
RuskeR
Member#: 5824
1990 240sx "SR20"
I didn't know this. I guess I'll pick up a bottle.
Old 07-02-2010, 09:27 AM   #11
scoobywagon06
Member#: 216459
14 f150 FX4
This thread just saved my life hahah
scoobywagon06 is offline   Reply With Quote
Old 07-06-2010, 12:38 PM   #12
RuskeR
Member#: 5824
1990 240sx "SR20"
Let's hear the details on this.
Of course after I made this thread, I had the flexible backing plate on my DA shear off. So, I'm waiting on a new one to arrive in the mail today.
Old 07-12-2010, 05:00 PM   #13
Brian610
Member#: 161477
Bring your car to my house and we'll fix everything, my random orbital is better than yours I know it.
Brian610 is offline   Reply With Quote
Old 07-13-2010, 12:17 PM   #14
RuskeR
Member#: 5824
1990 240sx "SR20"
I may just take you up on that offer. I hit it with the 205, and a very mild pad, and it did improve it, but not fix it like I had hoped. I would guess an orange pad with 105 would do the trick.... or just bring it up to you.
Old 07-13-2010, 01:09 PM   #15
Brian610
Member#: 161477
Just bring it up already. Stop by next time your in Olympia.
How to properly prep rusted steel before painting? scoobydrew06 Car Care & Detailing 6 05-01-2010 11:20 AM
Tips on how to properly throw your golf club -=C=- Off-Topic 7 07-10-2008 10:28 AM
How to properly remove silicon glue without damaging the paint? pacepace Car Care & Detailing 3 06-29-2008 10:24 AM
how to properly paint house Caddy Daddy Off-Topic 13 08-18-2004 12:38 PM
How to properly paint Calipers? Jasno999 Interior & Exterior Modification 17 08-09-2002 12:17 PM
