Old 06-30-2010, 07:10 AM   #1
2ez4me
Member#: 237228
Default delete please
please delete, dont need anymore.
2ez4me is offline   Reply With Quote
Old 06-30-2010, 10:14 AM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
I'm confused. Is the DOHC EJ25 in the car and running? Or are you trying to figure out if you can install it in place of the original engine? Which engine is "running on 2 cylinders at idle or when you go into drive it stumbles on 2 cylinders but cleans up when your [sic] going"?
You're basically trying to put a DOHC engine into a car with a stock SOHC engine. The intake manifolds are similar, but different bolt patterns and runner spacing at the heads, so they're not interchangeable. The ECUs and engine wiring harnesses are different. Apparently almost all the sensor wiring is interchangeable, but the IACs are completely different, and that's the major stumbling block.
Old 06-30-2010, 06:27 PM   #3
2ez4me
Member#: 237228
yeah it runs and drives, it idles little high and just started to lobe a slight bit but runs good under normal load, Its the DOHC that seems to run on 2 cylinders at idles, gonna swap plugs out tonight.
Old 07-02-2010, 08:17 AM   #4
2ez4me
Member#: 237228
figured it out
Old 07-09-2010, 10:43 PM   #5
2ez4me
Member#: 237228
It works, ill figure it out from here
02 Legacy Outback Diagnostics port issue 2ez4me Electrical & Lighting 7 07-12-2010 08:45 PM
JDM EJ25 DOHC swap with pics trinistyles Legacy Forum 2 03-25-2009 04:36 PM
'97-99 Legacy/Outback N/A DOHC EJ25D valve covers Patrick Olsen Private 'Wanted' Classifieds 1 08-02-2008 09:00 PM
Help! Blown engine 97 Legacy Outback 2.5 DOHC MorallyBass New England Impreza Club Forum -- NESIC 25 02-08-2007 03:46 PM
ej25 DOHC swap to STI SekndKlasoutback Subaru Conversions 5 06-06-2004 04:08 PM
