Old 06-30-2010, 07:20 PM   #1
njdriver04
Member#: 248747
04' SG XT
Blk
Default 06-07 STi brakes on 00' GT Wagon
is it possible to keep my axles and swap in 06 or 07' sti brembos disc and rotors front and back.
njdriver04 is offline   Reply With Quote
Old 07-04-2010, 01:39 AM   #2
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
Yes, the front calipers will bolt right up. You will need adapter brackets in the rear to keep your same rear setup. You will need 04 STi rotors that are 5x100 bolt pattern or re-drill the 06-07 to 5x100.
Ben
Old 07-04-2010, 01:33 PM   #3
njdriver04
Member#: 248747
04' SG XT
Blk
if i have access to sti parts, and i plan on swapping in a sti suspension, i should be good with the 06-07 stuff, but for the time being i might redrill it.
Old 07-04-2010, 10:37 PM   #4
PHATsuby
Member#: 13617
2001 Legacy GT back
I am not even sure you can swap the STi rear subframe but I could be wrong as I am a bit out of touch on that. The BE/BH rear suspension is not the same as the wrx or the BD/BG which could swap over no problems.
I know the rear STi suspension will not work unless you can swap the entire subframe. Hence why the adapter brackets may be cheaper/easier.
Ben
Old 07-06-2010, 12:46 AM   #5
njdriver04
Member#: 248747
04' SG XT
Blk
http://forums.nasioc.com/forums/show....php?t=1102629 be/bh wrx swap,
yes, the plan is to get the entire subframe. entire suspension swap hopefully..
Old 07-06-2010, 02:30 AM   #6
PHATsuby
Member#: 13617
2001 Legacy GT back
I know he swapped an entire wrx motor over, did you have a specific post/page that he references the entire subframe being swapped? It's been a while since I read through there. If he did it then obviously its possible.
Ben
Old 07-06-2010, 02:57 PM   #7
marek968
Member#: 212643
04 STI
was thinking the same thing, i tried a few times to read through but was distracted by several of the posts and started to research other info. my buddy who is a mechanic who knows a **** ton about subarus says that i can't swap the rear,subframe so i was wrong, but i will research what the difference is that causes this to not be a option.
marek968 is offline   Reply With Quote
06/07 STi HID's on 06/07 WRX Lboogie Interior & Exterior Modification 20 06-07-2012 05:58 PM
06-07 STI Cluster on 07 WRX Ysidro Newbies & FAQs 7 04-21-2009 07:01 PM
TMZ: 06/07 STi crash on Mulholland SubieRon Southern California Impreza Club Forum -- SCIC 22 02-09-2008 04:57 PM
06-07 Sti Injectors on 02 WRX mistaanime Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-19-2007 05:12 AM
04 Sti Brakes on 03 WRX Wagon? Scooby1 Brakes, Steering & Suspension 7 09-16-2003 10:33 PM
