Welcome to the North American Subaru Impreza Owners Club Wednesday June 1, 2016
Old 06-30-2010, 07:27 PM   #1
PitwrkzZ1
Member#: 94316
Default Hoodscoop painting help
I just finished up spraying my JDM STi hoodscoop WRB. I put 3 coats each of the base coat and a clear coat. Now, I've heard a couple different things form this point forward. I'm thinking I should wetsand with 1200 grit to get rid of the orange peal, then polish it with a polishing compound, then finally wax it. Good idea?
PitwrkzZ1 is offline   Reply With Quote
Old 06-30-2010, 07:34 PM   #2
metros
Member#: 111343
To make it perfect you'll need to do more polishing than just compound. I would also imagine you'll need to step to a finer grit for wet sanding as well. I'll let the people with more experience answer that.
Compound to wax will not look good though. Compound - polish - finishing polish-wax/sealant
metros is offline   Reply With Quote
Old 06-30-2010, 08:31 PM   #3
jefmcc
Member#: 42303
2004 WRX
Rally Blue
I just spent a lot of time experimenting with this. Here's my two cents:
Use a proper sanding block for wet-sanding. Do not just use your hand.
Be very very careful not to sand through the clear coat back down to the base coat.
Be very careful around the corners and edges. In fact, you may not even need to sand some of the corners.
Patience patience patience.
Call local Subaru dealer and ask who they use for paint work. Get quote and cry. Mine says they will do it for $100. Don't know what you spent on time and material, but I put way more than $100 bucks into it.
jefmcc is offline   Reply With Quote
Old 06-30-2010, 09:25 PM   #4
cmk82600
Member#: 248305
97 OBS
my custom mixed silver
1500 or 2000 grit sandpaper and lots of water, when you think you are using enough water add more, and make sure to use a sanding block of some sort. and The most important part, take your time, or you will be respraying.
cmk82600 is offline   Reply With Quote
Old 06-30-2010, 09:42 PM   #5
2point0
Member#: 150248
'13 BRZ Ltd WRB
'67 Mustang
This sounds familiar! I'm painting an STi scoop & splitters with a paint gun, but I started out using spray cans from a local paint shop. Nothing I could do would make the paint come out of the cans in a way that didn't produce a heavy orange peel, except for laying it on REALLY wet. Problem with that was the can sprayed so poorly that I would get drips from the nozzle. For one of my splitters, I just toughed it out with the can, spraying fairly heavy then wet-sanded with 1000 and 2000 and loaded up on clear. With this kind of paint, it's hard to get anywhere with super-fine sandpaper. It's got clearcoat mixed in and ends up being fairly durable. Except for corners/edges like stated above. I think I'll take the advice and leave those alone next round.
For the scoop, trying to sand it smooth was a PITA. I ended up using like 220 or so to get rid of the texture completely, then went progressively smoother and primed/sanded/etc. Now I'm using a spray gun and it goes on SUPER glossy. Just a bit of a learning curve, though.
2point0 is offline   Reply With Quote
Old 06-30-2010, 10:21 PM   #6
down_for_the_scooby
Member#: 78314
04 PSM WRX
Audi mask the right way
Couple tweaks. After the clear has seasoned, (dried for a week or two), use a 1200-1500 grit and wet sand smooth. Then use a rubbing compound then the polishing compound. I would stay away from anything more than hand and cloth polishing as you don't have enough paint down to chance machine help otherwise good luck.
down_for_the_scooby is offline   Reply With Quote
FS: New STi Hoodscoop, painted Obsidian Black Pearl Construct Private 'For Sale' Classifieds 5 08-13-2004 03:54 AM
FS: Genuine STI Hoodscoop painted MBP LimeyWRX Private 'For Sale' Classifieds 3 09-19-2003 10:14 PM
Hoodscoop paint process? S-1 Interior & Exterior Modification 4 03-28-2003 09:26 PM
FS: STi hoodscoop painted black fimotorsports Mid West Subaru Owners Club Forum -- MWSOC 3 02-12-2003 01:59 AM
Paint help chuckpfl New England Impreza Club Forum -- NESIC 1 08-30-2000 10:28 AM
