Notices
Old 06-30-2010, 08:08 PM   #1
kirbykirb
Member#: 183596
2005 WRX/9-2x
Obsedian Black Pearl
Default Oil change? Engine is knocking when startup *no I did not fully start it*!!!
Alright, was doing an oil change.
Castrol 10W-40.
New oil filter.
pull off old filter, do drain plug and drain oil. nasty nasty deep black color, ugly.
Clean off pan bolt, reapply it. put on oil filter with no oil in it.
Fill it up with a whole 5 quart bottle of 10w-40, made it drink every last drop.
Check oil level 4 times, its at the good range (so happy)
go start car slowly (ready to stop igniton at second) hear knocking, metal on metal CONTACT!
go oh **** oh **** oh ****, let it start only for one turn of the engine.
waited a few minutes more, like 5-10 mins. did it again, one 1st/2nd spin I hear some knocking immediatley turn it off.
take off cars oil filter, filled it up with oil and placed some oil around the metal contact inside the o-ring, hand torqued it.
When i took the filter off; there was really no oil in it, just a dab here and there if that.
Went to start car, let it go for 2-3 rotations, and heard metal on metal contact, turned car off immediatley, and now I'm here; sad.
kirbykirb is offline   Reply With Quote
Old 06-30-2010, 08:10 PM   #2
thescooby05
Member#: 191563
2005 STI Protuned
that sucks... dont know what it would be tho... didnt do it before?
thescooby05 is offline   Reply With Quote
Old 06-30-2010, 08:21 PM   #3
kirbykirb
Member#: 183596
2005 WRX/9-2x
nope...
going to pull the fuel pump fuse and see if I get lucky. I'm just scared so badly right now due to my lil subie feeling pain. :'(
Old 06-30-2010, 09:10 PM   #4
kirbykirb
Member#: 183596
2005 WRX/9-2x
*cry*
Old 06-30-2010, 09:36 PM   #5
ReubenH
Member#: 172522
1998 Legacy GTB Ltd.
Never had that happen.
Check engine bay thoroughly. Drain the oil again. Start it, and the moment it's running, floor it for about 5 mins, or till a piston flies out the engine bay. Inspect engine again.
If engine nuked itself, turbo conversion.
Forced upgrades are the best kind of upgrades.
ReubenH is offline   Reply With Quote
Old 06-30-2010, 09:58 PM   #6
kirbykirb
Member#: 183596
2005 WRX/9-2x
Did that already, even took it on the highway.
Drove it up to 60, it was okay no real noise except when the car turns on (turning over) and when it's at a stop and sudden pressure on the thottle.) and over 4500/5000 RPM.
So in otherwords, its dead. *sigh* I killed a subie, my best friend. D: all in my hands. I did it.
Old 07-01-2010, 12:04 AM   #7
jamal
Member#: 71875
98 Legacy GT
my wheels fit
Not that I would recommend it, but putting on a dry filter will not kill your engine. there's enough oil on everything and in the passages for it to idle for two seconds before everything is filled. I hear a lot of times at the dealership they don't even bother priming a new motor.
jamal is online now   Reply With Quote
Old 07-01-2010, 09:03 PM   #8
kirbykirb
Member#: 183596
2005 WRX/9-2x
Old 07-01-2010, 09:09 PM   #9
biv343
Member#: 246476
2006 Impreza WRX
Gray
Damn... Only thing I saw in your process that is unusual was not priming the filter. Not sure what else it could be. Is 10W-40 the standard oil? Did you warm the engine up before draining it? Was your previous grade of oil also 10W-40?
biv343 is offline   Reply With Quote
Old 07-01-2010, 09:14 PM   #10
kirbykirb
Member#: 183596
2005 WRX/9-2x
Yes engine was warmed up, and sat for 10 mins before I went to do it. Primed the filter a tiny bit on the top, but didn't fill it.
http://tinyurl.com/sadsubie2
youtube vids. D:
Old 07-03-2010, 07:43 AM   #11
ReubenH
Member#: 172522
I've heard allot of blown big end bearings, and not a one sounded like that. That sounds more like something else has broken... Almost soulds like a rod or piston, but it looks like it's running on 4 fine.
Oh well, guess we'll just have to wait and see. Crack it open ol chap! (And stick a dual port 22 in there to replace it)
Old 07-03-2010, 12:55 PM   #12
kirbykirb
Member#: 183596
2005 WRX/9-2x
I found an EJ22 that can fit inside.. hehehehe.
As for cracking it open, I shall I shall! Mid july fun oh yeah!
Old 07-07-2010, 01:45 PM   #13
ben g
Member#: 227843
I wasn't able to click on any of those links do to being at work but it sounds like you have some piston slap.
ben g is offline   Reply With Quote
engine is knocking on my 03 WRX :( 1WRX0003 Service & Maintenance 16 03-09-2009 12:38 PM
nOOb Question... YES, ive read the manifesto, NO i did not get a concrete answer... litowrx Newbies & FAQs 14 07-03-2008 01:58 AM
How do you know if your engin is knocking? Soob02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 34 05-09-2005 09:21 PM
New TMIC and now engine is knocking tke308 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 02-25-2005 04:54 PM
I think my engine is knocking or something... JGard Normally Aspirated Powertrain 13 12-22-2000 12:45 AM
