Old 07-03-2010, 12:49 AM   #1
RS2580401
Member#: 149568
2001 Turboed OBS
Default Oil Return Line Discussion
I discovered that my oil return line is cracked and needs to be replaced. It is a custom return line so an OEM part will not really solve the problem. I was previously using some conduit like material that ran off the turbo and was clamped into the return spout attached to the oil pan. What would make my life a lot easier is if there was a rubber line that could withstand that heat. Is there such a thing? It would need to be about 3/4" hose. If not, what are my options for materials so that I can get a return line hooked back up.
RS2580401 is offline   Reply With Quote
Old 07-03-2010, 02:07 AM   #2
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
I would imagine braided stainless steel, same as an aftermarket oil feed line.
OrbitalEllipses is offline   Reply With Quote
Old 07-03-2010, 04:47 PM   #3
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
wrx and sti's just have a rubber hose on the return line. id just get some good quality hose. if it gets that hot buy a 6" peice of thermal sock and that should take car of it. Other then that, as said before stainless...
rexworx is offline   Reply With Quote
Old 07-03-2010, 09:18 PM   #4
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
The problem lies with tightening the hose with almost any clamps.
Old 07-04-2010, 10:59 AM   #5
madmax718
Member#: 172501
Wha?
Rubber hose should be fine. Why do you have a custom one in the first place?
if you want to do steel, do a more ductile steel- the heat and vibration will be more likely to cause some steels to crack.
madmax718 is offline   Reply With Quote
Old 07-04-2010, 02:59 PM   #6
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
You have me confused with the original poster. I was simply making a comment on the potential problems.
Old 07-06-2010, 09:45 AM   #7
RS2580401
Member#: 149568
2001 Turboed OBS
Sounds great. Thank you.
At the time we were doing the turbo, the stock assembly would have taken 4-5 days to get to me. I needed to get it done since I was borrowing a car at the time. We fabbed up our own return line. It held for a year and finally gave out.
Does anyone know the Part # for the stock return line assembly?
turbo oil return line - OK to add oil cooler? manxaru Built Motor Discussion 6 05-22-2008 08:54 PM
How much pressure of oil going out the oil return line? albie1kanobi Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 11-15-2007 03:52 PM
WTB: Oil return line, and power steering lines....HELP! RS_to_WRX_swap North West Impreza Club Forum -- NWIC 6 09-01-2005 01:55 AM
Oil Return Line Next To Header Okay? the Dabbler Normally Aspirated with bolt-on Forced Induction Powertrain 19 10-03-2001 12:03 PM
what size is my oil return line? kid22 Technical Forum Archive 0 07-19-2000 08:09 AM
