Vancouver Impreza Club
Old 07-03-2010, 03:16 AM   #1
Impact.blue
Member#: 226569
2013 WRX STi
World Rally Blue
Default check engine light on and fuel gauge reads E
hello everyone.
heres the the simple story, came home after a relax cruise and the as i was about to turn my car off my check engine light came on and my fuel gauge drop (it had 3/4 tank which is still in my car, therefore it didnt just leak away)
im guessing its a sensor? everything else works fine.
any opinion, suggestion and solution would be very helpful.
thanks for reading/helping.
Impact.blue is offline   Reply With Quote
Old 07-03-2010, 04:03 AM   #2
iht
Member#: 196742
2000 Impreza 2.5rs
time to go get a code reader and read whatever code was made. as long as you haven't reset the ECU yet you can see what code was made.
iht is offline   Reply With Quote
Old 07-03-2010, 08:18 AM   #3
bender
Member#: 1839
Originally Posted by Impact.blue View Post
hello everyone.
fuel sending unit. the code you are getting will probably be p0461
same thing happen to my car, and I've had a couple more that came into my shop with the same problem. I assume it's a common problem with the old school subies
bender is offline   Reply With Quote
Old 07-03-2010, 11:18 AM   #4
Loomin
Member#: 118113
98 Brights!
bingo.
Loomin is offline   Reply With Quote
Old 07-03-2010, 01:56 PM   #5
Impact.blue
Member#: 226569
2013 WRX STi
World Rally Blue
so what did you have to fix/replace to solve this problem? its not a headache is it?
also thanks everyone for your input. My mind is more at ease than last night
Old 07-03-2010, 03:30 PM   #6
semaj
Moderatour
Member#: 113533
2013 Leafs
Hatewagon
fuel sending unit.
You have to replace the fuel sending unit, as bender mentioned.
It's $65.84 USD on Subaru Genuine Parts
semaj is offline   Reply With Quote
Old 07-03-2010, 03:34 PM   #7
Impact.blue
Member#: 226569
2013 WRX STi
World Rally Blue
ah ok then.
thank you for your help
Check engine light on and cruise blinking? STIdrivr Electrical & Lighting 1 02-24-2007 08:38 PM
Check Engine light on and Weird Noise! AphexDouble Factory 2.0L Turbo Powertrain 2 01-10-2007 03:14 PM
check engine light on and cruise flashing catass Factory 2.5L Turbo Powertrain 23 07-08-2005 10:20 PM
Check engine light on and cruise control light flashing mpadovano Factory 2.5L Turbo Powertrain 6 01-23-2005 02:04 PM
('93-'01) check engine light on and....... watcher in the sky Impreza Forum 27 01-13-2002 04:21 PM
Message Board Statistics All times are GMT -4. The time now is 06:10 PM.
