Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 07-05-2010, 03:10 PM   #1
93SubieImpreza
Member#: 121337
1993 GC Sedan AWD
Aegean Blue
Default oil pump or bearing?
ok, I'm kind of a newb to subarus even though I've owned my impreza for 2 1/2 yrs now (love it). I do all the maintenance to it. Recently I've heard a knocking but a suction sound like it's having trouble moving fluid coming from inside my engine between the ps pump and alternator I'm at a loss right now bc it's my only car to drive at the time I'm thinking it's my oil pump about to go, so I called the dealership just to see what they had to say and the tech said I shouldn't have to replace the oil pump, that it usually means the engine is about to go. Has neone ever had this before. It doesn't leak oil. it does burn oil, but very little. Prob have to top off with 1/8 of a qrt once a month or so. I was also thinking it may be a bad timing belt tensioner pulley going bad also. If neone can give their thoughts it would be highly appreciated I don't have the funds to replace engine right now. I've planned on it for the yr to come, just not now
thans in advance,
kevin
93SubieImpreza is offline   Reply With Quote
Old 07-05-2010, 04:29 PM   #2
feint05
Member#: 152984
2004 jewbaru
jewbuilt, polish tuned
thats difficult to diagnose from the description, what part of the engine bay is it in
feint05 is offline   Reply With Quote
Old 07-05-2010, 04:30 PM   #3
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
post a sound clip. You can also remove your PS/alt belt and run engine for a min or so to see if the sound is still present.
Old 07-05-2010, 06:19 PM   #4
93SubieImpreza
Member#: 121337
1993 GC Sedan AWD
Aegean Blue
it's coming from right behind powersteering pump a little to the right, near oil pressure sensor at engine code Facing middle of engine it's right between ps pump and alternator.
Will try to post sound clip soon I'm using my phone all I can do right now is post on youtube stupid palm pre doesn't have sound recorder.
Old 07-05-2010, 06:34 PM   #5
93SubieImpreza
Member#: 121337
1993 GC Sedan AWD
Aegean Blue
http://www.youtube.com/results?search_query=934WDriven
this is all I can do for now as far as clips go click on engine shot? video
Old 07-05-2010, 11:19 PM   #6
Jaren1
Member#: 195061
1997 \_(ツ)
Green
sounds odd. Does the noise increase in sound or frequency as you give it gas? Does it always do this ore does it go away after warming up
Jaren1 is offline   Reply With Quote
Old 07-06-2010, 07:39 AM   #7
93SubieImpreza
Member#: 121337
1993 GC Sedan AWD
Aegean Blue
it does increase but only til I hit around 1700-2000 rpm then it goes away. When the engine is first started it doesn't make the noise until the rpm drop to normal after engine is warm
Old 07-06-2010, 11:23 AM   #8
feint05
Member#: 152984
2004 jewbaru
check the idler pully on the ac
Old 07-07-2010, 04:53 PM   #9
93SubieImpreza
Member#: 121337
1993 GC Sedan AWD
Aegean Blue
are you talking about the visible pulley that the ac belt is on or one of the pulleys behind the timing belt cover?
Old 07-07-2010, 07:37 PM   #10
GrundleJuice
Member#: 165749
does the engine make the same amount of power as it did before the sound occurred?
Old 07-07-2010, 08:06 PM   #11
93SubieImpreza
Member#: 121337
1993 GC Sedan AWD
Aegean Blue
yea it makes the same power that I can tell, I don't know for sure though. It pulls as much as it could before which wasn't much. My oil level hasn't changed since berfore this occurred I plan on changing my oil this weekend. I thinking of taking the belts off to check under my timing belt cover.
Oil Pump or ??? TJCrenshaw Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 33 10-13-2009 02:49 PM
WTB: CP pistons standard bore, subaru gasket kit, oil pump water pump, bearings sti charles Private 'Wanted' Classifieds 35 04-07-2009 10:28 PM
WTB: STi Oil Pump or Better rdodger Private 'Wanted' Classifieds 3 06-30-2008 06:48 PM
08 STI 11mm oil pump or JDM 12mm oil pump? Davenow Built Motor Discussion 82 06-28-2008 12:33 AM
WTB: RA oil pump or Cosworth Oil Pump. cegpcola Private 'Wanted' Classifieds 1 12-04-2006 04:54 PM
