Old 07-05-2010, 05:55 PM   #1
98legwag
Member#: 160325
98 Legacy
DSP
Default Need help-No a/c and car overheats
On my way home today our 2000 Outback started to overheat. For awhile now the a/c hasn't worked right. It only blows cold air when the car is moving. Now the temp gauge goes past normal to 2/3 of the way up the temp scale. Any ideas as to what could be causing this? I have to drive it till my car is done at the body shop later this week and tomorrow and Weds should be 100+ here.
Thanks.
98legwag is offline   Reply With Quote
Old 07-05-2010, 06:30 PM   #2
98legwag
Member#: 160325
98 Legacy
DSP
Went back out and ran it without a/c and with a/c for about 3 mins each and the radiator fans never kicked on.
Old 07-05-2010, 06:37 PM   #3
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
make sure both fans are plugged in and are working.
Old 07-05-2010, 11:41 PM   #4
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Is the radiator topped off? Is the coolant overflow bottle filled to the appropriate level?
The fact that the fans didn't kick on when you turned on the A/C is definitely a problem. Check the fuses or relays for the fans.
Pat Olsen
I need help NO SPARK!!! AFAP_Nor_CA Newbies & FAQs 0 01-20-2010 10:56 PM
Need help!!! Intercooler came off and need to know if car is ok pjung1 Factory 2.0L Turbo Powertrain 7 12-09-2008 01:40 PM
Desperately need help - no compression BrianU Service & Maintenance 12 06-29-2006 01:57 PM
Need help on a Non Subaru car =) supersuck Vancouver Impreza Club Forum -- VIC 6 01-30-2001 12:08 AM
Please someone freakin reply !!! need HELP !! no one ever does every time i post!!! DarkLite Technical Forum Archive 15 08-24-2000 04:12 PM
Message Board Statistics All times are GMT -4. The time now is 07:37 AM.
