Old 07-05-2010, 09:43 PM   #1
HQuakers
Member#: 233454
1984 Shoe Leather
Default Howto: Floor Mat Retainer Clip for Under $1.00
So like many of you my floor mat retainer clip is a useless piece of plastic:
Instead of shelling out $10 for another one that will enevitably become another useless piece of plastic (especially since the hole is getting stretched out), I decided to think about a more heavy-duty alternative.
I went to the hardware store and got the following items:
1- 1/4" x 20 1"-long hex screw
2- 1.25" diameter fender washer
1- 1/4" washer
2- split lock washer
1- 1/4" x 20 nut
1- 1/4" x 20 wing nut
Total for the above items came to $0.98.
My theory was to have a way to attach the clip to the carpet, and not just have it being retained by the hole. I also wanted a way for it to be easy to remove when vacuuming out my car (which I didn't do before taking these pictures, I know, haha).
Tools needed:
1 opened-ended wrench
1 socket wrench
The size of the head on your hex screw will determine what size of the above you need. I had a deep 11mm socket and 11mm open-ended wrench that fit pretty well on mine, so that's what I used:
Hole in my dirty carpet:
Notice how the floormat is pushed way up under the petals...very annoying.
HQuakers is offline   Reply With Quote
Old 07-05-2010, 09:43 PM   #2
HQuakers
Member#: 233454
1984 Shoe Leather
First, stick the screw through the center of one of the fender washers:
I was able to slide this into the hole sideways:
Next, put the second fender washer onto the screw on the top side of the carpet:
Next, put one of the split lock washers on:
Now, put the nut on top of the lock washer. There was a little space between the fender washers and the carpet where they didn't completely cover, so I slipped the open-ended wrench in there on the hex bolt head:
I put the socket wrench on the hex nut and went to work torqing it down. The purpose of putting the nut on here is to sandwich the carpet between the two fender washers, accomplishing a way to attach the clip to the carpet, and not just have it being retained by the hole:
Old 07-05-2010, 09:43 PM   #3
HQuakers
Member#: 233454
1984 Shoe Leather
Torqued down. This puppy aint comin' off:
Next I put the floor mat hole over the protruding screw threads:
Next I put on the regular sized 1/4" washer and then the split lock washer:
Wing nut, torqued down by hand:
Voila:
Old 07-05-2010, 09:49 PM   #4
xjustinx
Member#: 196920
03 Wrx
So simple. Im doing it!
xjustinx is offline   Reply With Quote
Old 07-05-2010, 09:54 PM   #5
Terrible Juan
Member#: 208296
2012 Chrysler 300
2015 Jeep Grand Cherokee
Another great creative solution! I love creating quick fixes using random pieces of hardware. Luckily the 08+ has what appears to be a permanently mounted metal piece that holds it in place. It uses a small flared end at the top instead of a fastener.
Might I suggest using a female threaded knob such as this one. They are available in all sorts of shapes and sizes and I'm pretty sure you can get them from the hardware store you got your other pieces at. I know Ace has them.
Terrible Juan is offline   Reply With Quote
Old 07-05-2010, 11:49 PM   #6
anonamoose
Member#: 244620
2005 RS wagon
nice im doing it. i hate my lil plastic one spinning and falling off all the time, my floor mat always slides up and like to sometimes catch the clutch, its super annoying def doin this
+1
anonamoose is offline   Reply With Quote
Old 07-06-2010, 12:53 AM   #7
MCXL
Member#: 234076
2003 WRX
15$?????
They are 1.30$ at my local dealer.
MCXL is offline   Reply With Quote
Old 07-06-2010, 01:12 AM   #8
Stanyer89
Member#: 239854
2002 Stg2 WRX
I wonder if someone could just sew Velcro onto the bottom of the floor mat instead...
Stanyer89 is offline   Reply With Quote
Old 07-08-2010, 01:09 PM   #9
HQuakers
Member#: 233454
1984 Shoe Leather
Yes, definitely a possibility. I just used the wing nut cause it was $0.10.
Originally Posted by MCXL View Post
15$?????
Sorry, updated my original post. I was quoted $4.76 for the one piece and $5.26 for the second piece.
Of course anyone could, but it wouldn't cost less than $1.00
Old 07-08-2010, 01:14 PM   #10
HQuakers
Member#: 233454
1984 Shoe Leather
Also, you can avoid using the nut + lock washer and the wing nut + lock washer by purchasing some nuts/wing nuts with nylon inserts.
Old 07-15-2010, 08:53 PM   #11
jgardner9000
Member#: 219549
2009 STi
Been looking to do something like this for a while, my carpet is driving me insane. Great write up, thank you sir!
jgardner9000 is offline   Reply With Quote
Old 07-15-2010, 10:22 PM   #12
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
+12345 I can finally fix my carpet! It's been pissing me off for so long.
OrbitalEllipses is offline   Reply With Quote
Old 07-15-2010, 10:26 PM   #13
remotehuman
Member#: 201995
2000 Forester
you are my hero. my floor mat is in my back seat right now because of this issue. <3<3 for you.
remotehuman is offline   Reply With Quote
Old 07-15-2010, 10:31 PM   #14
Byzantium
Member#: 207826
85k 2002 WRX
Correct Fitment Crew #034
Subaru has had a fix for this for quite some time that involves something very similar.
Byzantium is offline   Reply With Quote
Old 07-16-2010, 12:00 AM   #15
bbun
Member#: 184554
02 ghettoFABness
bugeye rolling.
i have a hole in the exact same spot.... maybe the previous owner ran amp wires through there, or did this need to check all weather floor mat for drilled hole
bbun is offline   Reply With Quote
Old 07-16-2010, 01:01 AM   #16
Murphdog
Member#: 75414
2004 STi
Its the Blue one
I did something similiar but I drilled a small hole through the top of the bolt and put a Hair Pin Cotter Pin through it. But I defiantly dig the wing nut.
Murphdog is offline   Reply With Quote
Old 07-16-2010, 09:30 AM   #17
Ernest
Member#: 45076
2004 Stg2 Wagon 4eat
My plastic holder broke 5 years ago - just put some duct tape under carpet - works for awhile until you vacuum than replace. carpet never moves and you can't see the duct tape under the carpet so who cares. I love duct tape.
Ernest is offline   Reply With Quote
Old 07-17-2010, 11:52 AM   #18
Steeldon
Member#: 248219
2004 WRX 68HTA+HFS6
1- 1/4" washer
1- 1/4" x 20 nut
You got ripped off. I bought the same things and it came to $0.59 . No but for real awesome idea.
Steeldon is offline   Reply With Quote
Old 07-17-2010, 12:20 PM   #19
Brother EddieJ.
Member#: 181617
2004 wrx
6speed/ 330whp/ 300wtq
Thanks for this. I was able to do it with all the random nuts, bolts, washers I had laying around. Plus I was able to torque it all down by hand. Thank God for retarded strong hands. Literally took me all of 3 minutes. I actually feel stupid for not thinking of it first.
Brother EddieJ. is offline   Reply With Quote
Old 07-17-2010, 05:47 PM   #20
2002-Blue-WRX
Member#: 251976
Brilliant stuff. Just bought my 2002 WRX last week and noticed this little problem. I'll be heading out to the hardware store here in a few minutes!
2002-Blue-WRX is offline   Reply With Quote
Old 07-17-2010, 07:22 PM   #21
100_Percent_Juice
Member#: 126042
2004 W Ŕ X
This thread if full of win. Thank you
100_Percent_Juice is offline   Reply With Quote
Old 07-17-2010, 08:05 PM   #22
polish steve
Member#: 193861
2006 impreza 2.5i sd
obp
brilliant!! I'm doing it. I'm surprized I never thought of doing something similar like this before. Any way u can attach the bolt to the floor and not the carpet? Does it hold it good?
polish steve is offline   Reply With Quote
Old 07-17-2010, 09:59 PM   #23
MGigantelli44
Member#: 234591
2004 STI
I followed your instructions exactly. It was so simple and works like a charm.
Thanks for sharing!
MGigantelli44 is offline   Reply With Quote
Old 07-17-2010, 10:07 PM   #24
sagvr4
Member#: 170718
04 WRX
i put a ziptie through the little plastic piece that holds it now so the carpet cant come off of it. easy to just fold back any side and vacuum under it too.
sagvr4 is offline   Reply With Quote
Old 07-17-2010, 10:52 PM   #25
HQuakers
Member#: 233454
1984 Shoe Leather
Good idea.
I'm not sure what's under the carpet, so I guess it's possible. If you torque the nut down with the lock washer underneath it won't come off. It's been on there for some time and it won't come off unless I get out some tools.
Also, if anyone has any suggestions on improvements or anything, feel free to post them up. This is why we're all here...help each other out
FS : Subaru All-Season Floor Mats fattie92 MWSOC Private Classifieds 5 07-31-2010 10:47 AM
FS : 08 STI BBS Black Powder Coated OEM tires with TPMS For Sale jay_barton Wheels/Tires 53 07-31-2010 07:24 AM
Does anyone know if I can use these parts for my 99 impreza sport 2.2 patshan Newbies & FAQs 0 07-05-2010 11:15 AM
P/N for JDM V7/V8 STI TMIC Gorge Private 'Wanted' Classifieds 7 07-05-2010 10:57 AM
Who is attending HIN (Hot import nights) -$5 for nasioc members shaggy-with scoobi South East Region Forum 0 07-03-2010 07:24 PM
