Go Back   NASIOC > NASIOC Classifieds > Vendor Announcements
Old 07-06-2010, 12:47 AM   #1
flat4motorsports1
Vendor
Vendor Sales Rating: (1)
Member#: 246331
Default Flat4 Is Your New Go Fast Bits Headquarters
flat4 is your new source for go fast bits - we just added 2 new sections to our website- Go Fast Bits and White Line f
WE HAVE A FULL SELECTION OF GO FAST BITS FROM BOOST CONTROLS TO BLOW OFF VALVES
http://www.flat4motorsports.net
THE GO FAST BITS ATOMIC - MANUAL BOOST CONTROL
__________________
flat4motorsports1 is offline   Reply With Quote
Old 07-07-2010, 01:22 AM   #2
flat4motorsports1
Vendor
Member#: 246331
__________________
Old 07-07-2010, 11:20 AM   #3
flat4motorsports1
Vendor
Member#: 246331
__________________
Old 07-07-2010, 01:30 PM   #4
flat4motorsports1
Vendor
Member#: 246331
we have a full line of white line flat out products also. from sway bars to end links these are the same parts used by professional rally teams all over the world
__________________
Old 07-08-2010, 11:13 PM   #5
flat4motorsports1
Vendor
Member#: 246331
white line and go fast bits are going fast
__________________
Old 07-12-2010, 01:47 AM   #6
flat4motorsports1
Vendor
Member#: 246331
__________________
Old 07-14-2010, 11:59 AM   #7
flat4motorsports1
Vendor
Member#: 246331
we just got our go fast bits - dealer kit. we now have flanges and install kits for all makes all models
__________________
Old 07-25-2010, 03:20 PM   #8
flat4motorsports1
Vendor
Member#: 246331
full recirc blow off valve ,50 50 recirc o2 blow off valve , full o2 blow off valve - all in one blow off valve
__________________
Old 07-29-2010, 11:51 AM   #9
flat4motorsports1
Vendor
Member#: 246331
every one with a turbo impreza should come down and check out the go fast bits blow off valves- fully adjustable blow off valve - go from full recirc to full atmosphere . no more rough idle
__________________
Old 07-29-2010, 08:04 PM   #10
flat4motorsports1
Vendor
Member#: 246331
__________________
Old 07-30-2010, 01:47 PM   #11
flat4motorsports1
Vendor
Member#: 246331
http://denver.craigslist.org/pts/1870678234.html
1.8 subaru motor and transmission - this is a complete ej18 - intake manifold,dual port heads,throttle body and transmission
complete motor + transmission runs just need a new clutch
i pulled this out of a car that we bought for parts .i bought the car for the steering rack and suspension . the motor ran fine just needs a clutch. perfect for a replacement . i have the wiring harness and ecu so you could complete the swap. this would be perfect for a 2 wheel drive swap. turn a 2 wheel drive subaru into an awd subaru just bolt in. i also have some extras i will throw in for free, if you pull a motor at a junk yard it is going to cost at least $250.00 for just the bottom short block this way you save $$$. this motor has dual port heads just perfect for a turbo build up!!
__________________
Old 07-31-2010, 02:29 PM   #12
flat4motorsports1
Vendor
Member#: 246331
we also have the full line of suspension parts from whit line
__________________
Old 08-09-2010, 02:31 PM   #13
flat4motorsports1
Vendor
Member#: 246331
sorry if you came by the store we were out racing and out at leadfoot were home now
__________________
Brand new Go Fast Bits Mach 1 bov God NWIC Private Classifieds 11 03-15-2010 03:50 AM
fs: NEW Blue Go Fast Bits GFB underdrive PULLEY KIT with new belts. fastwrx25 Engine/Power/Exhaust 13 01-21-2007 06:27 PM
Need pics of your GO FAST BITS BOV FatCatTurbo Member's Car Gallery 13 11-11-2003 11:36 AM
Message Board Statistics All times are GMT -4. The time now is 01:18 PM.
