Old 07-06-2010, 01:09 PM   #1
rollertoaster
Member#: 242850
2010 wrx
blue
Default homemade adjustable short shifter
My buddy owed me a favor so I put him to work.... The lower ball is turned from Delrin plastic and threaded onto a tool steel shaft. The lower shaft is attached to the aluminum block by a pinch bolt and the distance to the lower ball is adjustable. The aluminum center section houses a delrin bushing and steel sleeve for linkage attachment. The shaft is longer than stock and uses the same 12x 1.25 thread on both ends and is locktited into the aluminum block. It also has a 12mm wrench flat machined into it in case it needs to be removed.
I'm pleased with the outcome. the shift knob sits about an inch higher but the throw is reduced by 30-40%. Shifts feel more solid now and with the taller know I no longer elbow the center console. I prefer the knob to be close to the wheel so I don't have to reach far in an emergency. The whole project cost me exactly $0.
rollertoaster is offline   Reply With Quote
Old 07-07-2010, 08:37 PM   #2
fastwrx25
Member#: 126441
03 bugeye
does your friend want to make me one? if so pm me thanks.
also I think for the bottom ball you don't need a flat spot like the factory. It might make for better feel. iirc the kartboy one is a complete sphere
fastwrx25 is offline   Reply With Quote
Old 07-07-2010, 09:40 PM   #3
Member#: 67
1999 Outlasting
the competition.
Depends on the year. 97-07 WRX are a full sphere. 08+ is a larger ball and has a flatspot.
Old 07-08-2010, 12:39 PM   #4
HillbillyLes
Member#: 178340
2002 WRX Speedwagon
Platinum Silver Metallic
That's great. You should think about marketing it if it holds up well...
Since the shaft is longer, how about a pistol grip version ala '70 Dodge Hemi Charger complete with the shaft bent to place the pistol grip closer to the driver...ahh, the memories that would bring back...LOL
HillbillyLes is offline   Reply With Quote
Old 07-08-2010, 02:56 PM   #5
jarencibia
Member#: 187021
2004 WRX Sedan
Sweet setup. How much height adjustment do you get from it?
jarencibia is offline   Reply With Quote
Old 07-12-2010, 11:43 AM   #6
ScoobieSnatch
Member#: 251848
way cool idea, clean job, this gives me some inspiration now. lol
ScoobieSnatch is offline   Reply With Quote
Old 07-14-2010, 07:48 PM   #7
rollertoaster
Member#: 242850
2010 wrx
blue
The ball does need a flatspot due to the depth of the socket. The shorter the throw adjustment the taller the shifter, plus with the use of a jamnut on the shaft you could have some more adjustment there. I was going to make a curved shaft for it but after driving the car I don't want to change a thing.
I'm sure he would be interested in making more, and there would be further refinements to the design.
Old 07-31-2010, 01:18 AM   #8
sha-d
Member#: 253098
adjustable short shift FTW!
sha-d is offline   Reply With Quote
Old 08-13-2010, 09:36 AM   #9
GeorgeGG
Member#: 254740
GeorgeGG is offline   Reply With Quote
Old 09-04-2010, 08:30 PM   #10
subaru_steve
Member#: 219426
2004 Subaru WRX
WRB Stage II
I just started my major in Automated Machining Engineering. Is there any generic specs that would be universal between the 2010 and a 2004? I would love to get some dimensions from you.
subaru_steve is offline   Reply With Quote
Old 10-18-2010, 10:14 PM   #11
Subikid90
Member#: 239233
1998 LGT
That is sweet. I want one lol
Subikid90 is offline   Reply With Quote
Old 10-20-2010, 05:41 AM   #12
greddy90
Member#: 147065
I'd want one if you can make it like the MODE racing one. Adjustable throw and adjustable height =D
greddy90 is offline   Reply With Quote
COBB double adjustable short shifter WRX norseone Private 'For Sale' Classifieds 2 08-30-2004 06:09 PM
FS: Cobb Double Adjustable Short Shifter heffergm Private 'For Sale' Classifieds 7 04-07-2004 10:00 PM
FS double adjustable short shifter eyehate Private 'For Sale' Classifieds 8 02-15-2004 12:06 PM
Perrin adjust short shifter method2madness Transmission (AT/MT) & Driveline 7 12-29-2003 03:33 AM
Cobb dual-adjustable short-shifter Brahmzy Transmission (AT/MT) & Driveline 6 05-07-2003 09:30 AM
