Old 07-06-2010, 10:24 PM   #1
flightwatch
Member#: 231058
2015 F-150
Default smelling grease
I just got done with a 1400 mile rt in my '06 2.5i and during stops, there was this very potent smell of grease that was coming from the front end. The trip was driven at speeds of 70-80mph for long periods of time. The temps ranged from 50-110, and elevations of 2,000ft-9,000ft. Also, I drove the car from FL-NV 4 months ago, and didn't have this smell.
I recently installed the Rallitek front and rear sway bars which called for generous amounts of grease to be put on the bushings, so I'm thinking that maybe some of the grease may have slung off of the bushings onto the exhaust, but is there anything else I should look at?
flightwatch is offline   Reply With Quote
Old 07-06-2010, 10:53 PM   #2
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
CV boots. See if they're torn
Psychoreo is offline   Reply With Quote
Old 07-06-2010, 10:55 PM   #3
cmiovino
Member#: 134005
2004 WRX Premium
Check that (swaybar grease), or check your front CV boots. Remember, a total of four on the front. With a torn boot, that smell on the exhaust may be what you're smelling.
My inner passenger side one was recently torn clear off and the grease went all over the hot cat.
Old 07-07-2010, 12:07 AM   #4
kewlboxer2
Member#: 161322
06 2.5i
Regal Blue
My front right is slowly oozing grease in between the boot and axle it self. Might want to check that out.
kewlboxer2 is offline   Reply With Quote
Old 07-07-2010, 02:22 PM   #5
flightwatch
Member#: 231058
2015 F-150
Ok, I checked the cv boots. There is the slightest bit of seepage on the passenger inner boot, but none of them are torn and none of them are slinging grease. however, I did notice that the tranny gasket looks to be leaking a little bit and I'm pretty sure that is where the smell is coming from. I wish I had taken a picture of it, but I didn't. It is just in front of the tranny oil pan and has a small gold bleed screw on it.
Old 07-07-2010, 03:12 PM   #6
flightwatch
Member#: 231058
2015 F-150
To add a little bit more: The leak is coming from in between the transmission case and converter case. It's more of a seepage than a leak, but irregardless, I'm taking it to a mechanic to see if this is as big of a deal as I think it is.
Old 07-18-2010, 05:27 PM   #7
flightwatch
Member#: 231058
2015 F-150
Update:
I took it to a transmission shop where they looked at it for free. The owner of the shop saw what I was talking about and said that everything looked great underneath the car, and that I shouldn't worry about the seepage because it's normal.
First off, I think that he is full of ****. It is not normal for any car to leak tranny fluid or differential oil. It's been 2 weeks since then and I am quite worried about this. I've checked both the ATF and diff. oil, and both appear to be full. The last thing I want is to have my tranny or diff. crap out.
Old 07-18-2010, 05:48 PM   #8
Psychoreo
Member#: 79643
2015 WRX STI
If the guy at the tranny shop said it's normal and didn't try to get work out of you, why are you worried about it? He didn't make any money from looking at it and isn't going to make any by saying it's normal.
Old 07-18-2010, 06:41 PM   #9
flightwatch
Member#: 231058
2015 F-150
I thought about that too, and I honestly don't know what to think. All that I know is that it is not normal for a car to smell like burning grease...or to leak fluids. I'm going to get a 2nd opinion regardless
Old 07-19-2010, 11:42 PM   #10
flightwatch
Member#: 231058
2015 F-150
Ok, so I got it fixed. Turns out that the crush washer on the the front diff drain plug failed. I'm glad that I got it looked at because the front diff was practically dry. A new crush washer and some Amsoil 75w 140 fixed it all.
Does burning CV grease smell like burning coolant? Jard Off-Topic 13 10-27-2014 03:15 PM
heavy grease smell flightwatch Brakes, Steering & Suspension 5 07-07-2010 03:29 PM
I smell like bacon grease. BacDoc Off-Topic 15 04-02-2010 01:58 AM
To grease or not to grease (sway bar) blackbok Brakes, Steering & Suspension 13 06-09-2002 02:24 AM
('93-'01) Where do I buy graphite grease? Is lithium grease a good second option? Hyudra Impreza Forum 7 10-20-2001 11:09 PM
