Old 07-06-2010, 10:15 PM   #1
Crazy_pilot
Member#: 164242
1992 SVX
2008 Spec B
Default Range of EG33 Lash Adjusters
Hey folks. I put this question to the SVX forum, but since NASIOC has infinitely more experience with this sort of thing...
Doing the head gaskets on the SVX soon and refurbishing the heads while they're off. Found out that Supertech has a valve set for the EG33, SS intake and inconel exhaust (Overkill for an stock engine, I know). Link to Ebay. I've contacted Supertech to confirm the specs on the valves.
The question: These valves are 2mm longer overall than the stockers. Can Subaru hydraulic lash adjusters take up an extra 2mm of valve length?
Crazy_pilot is offline   Reply With Quote
Old 07-06-2010, 10:24 PM   #2
eg33GC
Member#: 206851
56 Belair
Pro Street
Your valvetrain will now be an interference setup.
I'm assuming you're taking .020 off the head?
I would call Supertech and ask them if the decking and bigger valves will be a problem.
Realistically, don't waste your money on valves. Get some stock ones, or re use your old ones.
Spend your money on a set of cams!!
(If you need valves in great shape, contact me.)
eg33GC is offline   Reply With Quote
Old 07-06-2010, 10:28 PM   #3
eg33GC
Member#: 206851
56 Belair
Pro Street
And to answer, yes, 2mm is not much to take on stock setup.
Old 07-06-2010, 11:02 PM   #4
Crazy_pilot
Member#: 164242
1992 SVX
2008 Spec B
Cool. So skip the valves, clean and re-use the old ones, save money, buy some cams. Got it.
My spare set of heads will be sent to the machine shop and shaved as needed. I'm not looking to take much off and raise compression though. They'll also be grinding the valve seats (the exhaust seats have some pitting).
Old 07-06-2010, 11:33 PM   #5
eg33GC
Member#: 206851
56 Belair
Pro Street
.020 is the limit for shaving.
Port those sad heads out...
The runner of a 20k head, with the top of a 22e. Super good combo.
Old 08-01-2010, 10:45 PM   #6
NeedForSpeed
Member#: 123178
I believe those valves were designed for reduced base-circle cams
NeedForSpeed is offline   Reply With Quote
Hydraulic Lash Adjusters Kizo Service & Maintenance 3 07-16-2004 04:39 AM
Hydraulic lash adjuster help needed Speedwagon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 04-24-2004 06:31 AM
Adjustment range of Perrin/Progress rear sways? BruceC Brakes, Steering & Suspension 13 04-02-2003 01:24 PM
Replacing Hydrolic Valve Lash Adjusters, any experience? ciper Legacy Forum 0 03-04-2003 07:23 PM
Lash adjusters? ColinL Normally Aspirated Powertrain 15 06-05-2001 05:33 AM
