Old 07-07-2010, 02:37 PM   #1
bugeyegrocerygettr
Member#: 238584
2002 WRX Wagon
Soon to be Utec'd
Default Tranny noise while stoped with clutch out, and while coastin while in gear.
So i noticed some noise coming from my tranny after a long trip to PA and back. I stoped about halfway back home late monday night to get some gas and i noticed some chattering coming from my car while stoped. At first i thought it was my engine knocking because it has 162k on it and im paranoid its going to blow up soon but its not the case, i push the clutch in and the noise goes away. I can also hear it when im coasting with the car in gear and there is a back load on the the tranny.........any ideas on what this could be if so how costly could it be to fix. Thanks for the help
bugeyegrocerygettr is offline   Reply With Quote
Old 07-08-2010, 12:04 AM   #2
afrojack
Member#: 238833
My legacy wagon does the same thing, i have about 160k on the car. I think it has something to do with the clutch as my car also has slipping issues under power. I would be interested to see if anyone has an idea of what this noise could be as well.
afrojack is offline   Reply With Quote
Old 07-08-2010, 07:00 AM   #3
Storm
Member#: 5218
96L Most Over-
Developed Beater
Throwout bearing would be my initial thought.....
Jay
Old 07-08-2010, 01:42 PM   #4
05uurx
Member#: 244141
If its not coming from your engine, get your tranny checked out. Take it to a tranny repair shop and try to get them to do a free diagnostic on it.
I had the same problem with my tranny and at first i thought it was my clutch also. After replacing the clutch, I experienced the same chattering noise soon after. I have pictures of my open transmission box in my other post. Good luck and I hope it's nothing major with the tranny.
05uurx is offline   Reply With Quote
Old 07-10-2010, 10:55 AM   #5
dan az
Member#: 120355
2004 wrx wagon 2.5
20g-xt, super slow
input shaft bearing
dan az is offline   Reply With Quote
Old 07-10-2010, 01:46 PM   #6
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Bad throw out bearing if when stopped with clutch out or neutral. Not input shaft bearing unless you hear a spun sound between shifts.
Old 07-11-2010, 09:24 PM   #7
jose
Member#: 106707
2002 wrx
white
My car does the same ting I tout it was the throw out bearing I replace it whit a new one along with pressure plate and flywheel And it still does the same noise. I took it to a transmission shop and the guy shed it was input shaft bearing
jose is offline   Reply With Quote
Old 07-11-2010, 09:55 PM   #8
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
The input bearing uses needle bearing. If it died it can grind into the input shaft. Causing damage that can't be fixed with out a new input shaft. So if you suspect this then you best have a professional take a look at it and make sure. Specially with aftermarket gears as it can get pricey really quick.
Old 07-12-2010, 01:13 AM   #9
jose
Member#: 106707
2002 wrx
white
^ Thats y im going with a 6sp
Old 07-12-2010, 07:28 PM   #10
bugeyegrocerygettr
Member#: 238584
2002 WRX Wagon
Soon to be Utec'd
yeah there is a problem with my tranny. About 2 weeks after i got the car i somehow managed to blow the syncro out of 4th gear (AWD newb) but if i double clutch it is is fine. so it needs a rebuild anyway but it has never made that sound before, and it seems to have gone away magically. I dont know im waiting for a total trans failure but i dont have the extra cash laying around to do a rebuild. Im not going to just put 4th gear in it im proably goin to go with a JDM STI gear set.
Starts with clutch out only wrcRabbit Transmission (AT/MT) & Driveline 2 06-23-2010 12:31 PM
2003 Wrx with sti swap and interior, zero sports, RA gears! turbo98 Private 'Wanted' Classifieds 84 09-08-2008 06:15 PM
Rattle at Idle with clutch out? Chuckaz Transmission (AT/MT) & Driveline 1 11-08-2007 10:53 PM
Quick questions while the engine is out and i'm replacing the clutch/flywheel Anhdalai Transmission (AT/MT) & Driveline 1 10-01-2007 12:11 PM
"Thump" and hard to get in gear ? clutch? wRxbeater11 Transmission (AT/MT) & Driveline 6 08-20-2005 12:04 AM
