Old 07-07-2010, 04:09 PM   #1
TubeDriver
Member#: 14987
Default 91 Legacy uses the same filter as 2006 STI?
Because that is what the parts guy at the local Suby dealership says.
A 2.2 NA uses the same filter as a 2.5L Turbo engine?
TubeDriver is offline   Reply With Quote
Old 07-08-2010, 10:20 AM   #2
sqc151
Member#: 51432
what filter u talking about. air, oil, fuel??
if u wann check urself. go to autozone.com and type in the parts and year ur looking for and compare.
the air filters are the same.
the oil filters are the same.
the fuel filters my be different due to one being na and one being turbo.
sqc151 is offline   Reply With Quote
Old 07-08-2010, 10:36 AM   #3
TubeDriver
Member#: 14987
Oil filter.
Part numbers for K&N oil filters are different. Someone working at the a Suby dealership should be correct right? except this is the same place where the last time my wife asked for a STI oil filter, the parts dude asked 4cyl or the 6 cyl STI?
Old 07-08-2010, 01:44 PM   #4
98legwag
Member#: 160325
09 Legacy 3.0R
I can tell you my K&N air filter came out of my brother's 05 STI. I have a 98 Legacy with 2.2l.
98legwag is offline   Reply With Quote
Old 07-08-2010, 01:52 PM   #5
TubeDriver
Member#: 14987
It looks like Subaru now uses a single oil filter for ALL 1990 4 cyl turbo and non-turbo cars.
Old 07-08-2010, 01:52 PM   #6
sqc151
Member#: 51432
i checked, oil filters have different part numbers. (i can only assume because one is turbo and one is NA)
Old 07-08-2010, 01:56 PM   #7
TubeDriver
Member#: 14987
So the Subaru dealership is wrong?
Do you happen to have the part numbers?
Old 07-08-2010, 02:06 PM   #8
sqc151
Member#: 51432
i dont have dealer part numbers. (just what autozone comes up with) on a side note. go to the dealer, ask for both oil filters u wanna check out. if the center of the gaskets are the same i dont see why it wouldnt work. basically, butt each oil filter together face to face, if they match up, either should work. but in all honesty, i would just run the stock oil filter for ur 91 legacy. << judging by ur post i guess thats what u have?
Old 07-13-2010, 09:40 AM   #9
ReubenH
Member#: 172522
1998 Legacy GTB Ltd.
.... A subie oil filter is a subie oil filter.
ReubenH is offline   Reply With Quote
Old 07-14-2010, 11:42 PM   #10
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
4 or 5 years ago (or maybe all the way back in '02 when the first modern turbo cars showed up) the turbo cars came with a smaller filter than the N/A cars. Eventually, Subaru transitioned to all the cars using the same small filter.
It really shouldn't matter - the filters should be interchangeable.
Old 07-15-2010, 09:48 AM   #11
TubeDriver
Member#: 14987
Thanks. That is what I started to figure out. I also got a Mobil 1 filter as part of a oil/filter discount deal and it is the same small size as the Subaru filter.
Is JDM forester 2.5 STI version using the same block as USDM impreza STI? skyline31 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 07-05-2007 11:46 PM
Does the 1st gen legacy use the same ABS sensor as a WRX? bobturismo Brakes, Steering & Suspension 1 05-25-2007 12:56 PM
Do the 02-03 imprezas use the same bulbs as the 04 imprezas? SinhCredible Interior & Exterior Modification 2 02-23-2004 03:28 PM
Does the Forester XT use the same Turbo as the WRX? BrysImpreza Forester Forum 11 02-22-2003 12:17 AM
Does WRX head unit use the same plug as other cars? mca Car Audio, Video & Security 2 01-21-2002 08:27 PM
