Welcome to the North American Subaru Impreza Owners Club Friday March 27, 2015
Old 07-07-2010, 08:26 PM   #1
mygreatgc8
Member#: 230513
2001 rs/wrx/sti swap
black
Impreza GC8 boost problems on my frankenstin
i have an 01 rs with a 06 wrx swap,ver 1 trans, header, up pipe, down pipe, and catback,. shorty ram intake, 3 core radiator, and a manual boost controller. now i put the boost controller on and it ran @ .90 bar, then i put an turboxs hybrid 50/50 bov, then my boost dropped to .65-.70, i put washers in i to make the spring tension higher to see if the boost change it didnt, so i put the stock one back on and still doing the same thing. any ideas? i get it tuned with an accessport on aug 2nd
mygreatgc8 is offline   Reply With Quote
Old 07-08-2010, 10:53 AM   #2
suberdave
Member#: 101865
88 GL-10 STi
i had a turboxs bov. it would not hold more than 12PSI without leaking. put an APS one on and have not had a problem since...
-=Suberdave=-
suberdave is offline   Reply With Quote
Old 07-08-2010, 01:36 PM   #3
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Use an OEM BPV. If you would like.. run a better TMIC with silicone hoses oppose to the '06 WRX. Run OEM BPV. Also make sure ALL hoses and clamps are tight from turbo to the throttle body. Make sure all vacuum hoses are tight and not ripped. If anything run an OEM airbox. You get cooler air than the short ram and you're not maxing out the OEM MAF housing yet.
If you're still on the FACTORY turbo and factory ECU mapping, it doesn't boost high. The '06 WRX doesn't boost high like the EJ205.
FuJi K is online now   Reply With Quote
Old 07-08-2010, 07:20 PM   #4
mygreatgc8
Member#: 230513
black
now im right at .7-.73 ish, i got a cx racing intercooler, and installing my invidia divorced downpipe tomorrow, now im getting rid of my turboxs bov --100 shipped
Boost problem on 2.0GT WGTimpreza Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-24-2009 01:11 PM
Boost problem on 04 WRX cbbwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 09-03-2009 10:34 PM
Boost problems on SZ49 KRZNQWK Mid Atlantic Impreza Club -- MAIC 18 11-20-2007 09:15 AM
Severe Boosting problems on SZ49 Sjerzey05sti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 22 03-19-2006 03:40 AM
Boost Problems on stock motor - help! Kickz107 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-21-2003 09:47 PM
