Old 07-08-2010, 01:28 AM   #1
AnointedDrummer
Member#: 165617
2007 sold:(STAGE2WRX
Blur of UrbanGreyMetallic
Default Yes, another weird issue. (2 actually :0)
Helped my wife's cousin buy an auto '99 Impreza (na). The carfax came back great. Looked all over it and it's in great condition. Only two or three previous owers. I test drove it; good. Now, two weeks later, the check engine light is on (intermittantly at first, now more constant) and its doing this: while ideling, if its in park or neutral it purrs perfectly; put it in drive or reverse and it idles realy rough for a few seconds then smooth..rough again then smooth. What's up??
PS: not only that, but the brakes (from day1) were sub-par. If you put it in drive and press the brake pedal to the floor (and it does go all the way to the floor), the little, old, non-turbo engine can almost move the car and actually did one time when it was warmed up and i was testing it. Is this common?? Fluid is up. Will check pads tomorrow. Anything else??
Thanks guys.
AnointedDrummer is offline   Reply With Quote
Old 07-08-2010, 01:31 AM   #2
Jaren1
Member#: 195061
1997 \_(ツ)
Green
save yourself the headache in the future and remember carfax is virtually worthless.
Get the car checked by a shop
Jaren1 is offline   Reply With Quote
Old 07-08-2010, 01:37 AM   #3
AnointedDrummer
Member#: 165617
Well, its a start; if there were issues listed I woulda just scraped it from the beginning. So you really have no idea then? Thanks for the suggestion anyway semi-neighbor (Have a couple friends in Bend, Im in LG)
Old 07-08-2010, 02:03 AM   #4
PhilSine
Member#: 130489
02 WRX Wagon (WRB)
98 OBS-T, 91 Legacy SS
Bleed the brakes and find the huge vacuum leak.
Also get the code read and post it and go from there.
There should be a sticky saying "If you have a CEL on get it read and post the results prior to asking for further advice."
I know that sounds like me being a jerk but in reality its more an effort to allow us to better help you. Knowing the error code greatly helps narrow down issues.
PhilSine is offline   Reply With Quote
Old 07-08-2010, 03:04 AM   #5
AnointedDrummer
Member#: 165617
No offence taken at all. I have a Cobb AP for my 07 wrx, wish it could work for her impreza. I'll try to get that done and post it here befor allowing a mechnic to dive in. Thanks PhilSine.
Old 07-08-2010, 05:53 PM   #6
kewlboxer2
Member#: 161322
06 2.5i
Regal Blue
Maybe spark plugs/wire/coil for the rough running.
kewlboxer2 is offline   Reply With Quote
Old 07-08-2010, 08:10 PM   #7
NaturallyAspirated
Member#: 64792
2001 Impreza L
BRP
The brakes aren't really the greatest, I'll agree with you there.
The front brakes are tiny little rotors matched up to single piston calipers. The rears are drums. Most people who own older generation Imprezas use stock WRX rotors, brackets, and 2 piston calipers for the front, and do a rear disc brake swap in the back.
NaturallyAspirated is offline   Reply With Quote
Old 07-09-2010, 12:36 AM   #8
AnointedDrummer
Member#: 165617
THANKS GUYS.
Owner of the used car shop where we bought it (old friend of mine) red the code and has agreed to give it a tune up, buy a knock sensor and install(?) it for $150 (woulda posted code here but I wasnt present during reading, sorry!) Have a clue if that will work? Knock sensor. Sounds like a tool, a problem detector not a problem fixer. Any info bout that?
As far as the brakes go, he decided to dismiss the last $250 of the downpayment she owed him so she could take it to a mech to inspect the brakes. He suggested bleeding the system and adjusting it up...something like that.
So...
U guys rock.
Old 07-09-2010, 12:54 AM   #9
Jaren1
Member#: 195061
1997 \_(ツ)
Green
well sounds like he is a cool guy and that you worked it all out.
Knock sensor is just what the car uses to determine if it is fully burning all the fuel. If its not then that sensor will tell the ecu to pull timing
Old 07-09-2010, 01:06 AM   #10
AnointedDrummer
Member#: 165617
So its actually something that is installed on the vehicle and not a tool?
I know I sound ignorant. I am about some things. Sometimes it's better that way.
Old 07-10-2010, 02:54 AM   #11
PhilSine
Member#: 130489
02 WRX Wagon (WRB)
Knock sensor is located on the top rear of the engine on the driver's side slightly under the intake manifold. Its a little donut looking thing with a bolt through it and a wire with a two pin connector. Easy to change on NA cars and could be the culprit. They are prone to failures on Subarus.
Old 07-10-2010, 02:58 AM   #12
AnointedDrummer
Member#: 165617
Hmmm. Ok then. I'll report back later how its doin when I find out. Been at work 4 hours, 14 hrs to go..... :-(
Old 07-15-2010, 03:52 AM   #13
AnointedDrummer
Member#: 165617
UPDATE: Havnt taken it to mechanic yet about brakes. But I guess the "tune up" was done. It fixed the intermittant harsh ideling...for about a day or 2. Now its right back to the same thing. If the code was saying 'knock' and the knock sensor didnt fix it...now what?
Yes, Another UEL header 2.5i question. l00key! subadub07 Newbies & FAQs 7 02-03-2009 09:38 PM
head gasket issue. and yes, another misfire problem. rathead Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 10-29-2007 12:41 PM
YES another help choose my plates thread 2.0edition SQ3.0dotJP Off-Topic 16 09-27-2007 07:30 PM
OT PC Nuts: Yes another Mobo/HD Issue! Help! Krmnnghia01 Off-Topic 9 01-15-2007 08:18 PM
Why yes! ANOTHER sighting!! (CA-2 around noonish) Neaners Southern California Impreza Club Forum -- SCIC 5 08-28-2003 07:00 AM
