Welcome to the North American Subaru Impreza Owners Club Wednesday May 27, 2015
Old 07-08-2010, 01:43 PM   #1
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Aspen White / Silver
Default Welding on OEM Intake manifolds
Possibly going to modify a OEM intake manifold to reposition the throttle body and wondering how well the Cast manifold does being welded too? Is it pretty dirty? I was going to have it media blasted before hand to clean it up.
Token-Negro is online now   Reply With Quote
Old 07-08-2010, 02:11 PM   #2
Crawford Performance
Member#: 42075
They weld very good as long as there is no oil inside them. Be careful with media blasting as this can impregnate its self into the manifold causing the issues you are trying to avoid
Crawford Performance is offline   Reply With Quote
Old 07-08-2010, 04:09 PM   #3
PERRIN_Jarid
Member#: 214449
Would walnut blasting solve this problem?
PERRIN_Jarid is offline   Reply With Quote
Old 07-08-2010, 04:31 PM   #4
Member#: 42075
Walnut blasting is safe when it comes to welding aluminum. It's prety safe on sheet metal as well!
Old 07-08-2010, 06:56 PM   #5
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Yeah i think ill just buy a new SS wire wheel and wire wheel the paint off that way, should get me a clean surface.
Old 07-09-2010, 11:53 AM   #6
Member#: 42075
That will work.
Old 07-09-2010, 01:14 PM   #7
25rsti
Member#: 166324
3 turbos &n NA
@DBlockSTi
Does anyone have first hand experience with welding an oem manifold? Opinions? I need to weld two spots on one and want some background info before hand. Thanks
Old 07-09-2010, 02:47 PM   #8
scubydrew
Member#: 32609
2005 saab 9-2x
rhd ej20tt sold...
I weld alot of cast parts and if you want my opinion I'm gonna tell you it's not a big deal. I hear everyone saying get it blasted but in my experience it's not necessary. As long as it's prepped properly there shouldn't be any problems getting it to seal.
scubydrew is offline   Reply With Quote
Old 07-09-2010, 07:26 PM   #9
25rsti
Member#: 166324
3 turbos &n NA
@DBlockSTi
My main concern is that I have two holes on the runners and the wall thickness is thin. After it's welded though, I want to smooth it out flush.
Old 07-09-2010, 07:34 PM   #10
Member#: 42075
Have at it, the intake manifolds weld great if they are clean!
Old 07-09-2010, 07:41 PM   #11
25rsti
Member#: 166324
3 turbos &n NA
@DBlockSTi
Alright, thanks. I'll report back with a follow up.
Old 07-09-2010, 07:43 PM   #12
Member#: 42075
If you pre-heat the manifold it will weld much nicer
Old 07-09-2010, 11:10 PM   #13
Web Foot STi
Member#: 39086
2004 STi
Just a swag, but it is probably real close to 356 Al. I'd try using settings and rod for 356. It's going to be a little different as it will be Japanese alloy.
Web Foot STi is offline   Reply With Quote
Old 07-11-2010, 09:43 PM   #14
Hoo
Member#: 250324
Blasting aluminum with any media as a pre-cleaning to welding is going to do more harm than good. It may look nice, but the blasting just embeds dirt further into the casting. It probably wont make much of a difference with walnut media on a clean casting, but using sand or oxide media on dirty castings will make getting a good weld almost impossible.
Really all you should ever need is a clean SS wire brush and acetone/alcohol.
Hoo is offline   Reply With Quote
Old 10-14-2010, 03:35 PM   #15
25rsti
Member#: 166324
3 turbos &n NA
@DBlockSTi
I got the hole on the right runner welded now. I'm in the process of sanding it down to make it look like there never was a hole. Hopefully it'll come out that way.
wrx oem intake manifold, tgvs, throttle body, etc. anthonyrb98 Engine/Power/Exhaust 54 07-12-2007 06:58 PM
FS- 2004 WRX oem intake manifold, low miles, mint coolblue05 Engine/Power/Exhaust 6 06-13-2007 04:12 PM
FS- 2004 WRX oem intake manifold, low miles... coolblue05 MWSOC Private Classifieds 6 06-13-2007 09:58 AM
FS: STI OEM Intake Manifold torres600sti Engine/Power/Exhaust 4 10-05-2006 11:27 PM
WRX OEM Intake Manifold -- Great Condition ejh25 Engine/Power/Exhaust 24 09-20-2006 01:05 PM
