Old 06-15-2002, 07:31 PM   #1
JST
Member#: 5808
1999 RS-T/Legacy
sylver/black
Default Trany vs HP
I read the thred on the torque vs trany but i can't find the max HP and torque a stock 2.5 RS-t trany can take on a drag track.
Plaese help me???
JST is offline   Reply With Quote
Old 06-15-2002, 07:33 PM   #2
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
I'd say 7psi is about the max I've seen that the tranny is able to handle
kastle is offline   Reply With Quote
Old 06-15-2002, 11:07 PM   #3
STiTuner
Member#: 5778
09 135i
Jet Black
270ish ft/lbs of torque I do believe maybe that number is a little off but then I'm sure it would depend on your Clutch too... use a clutch with a softer engagement maybe that would help out our tranny problems.
Brad
STiTuner is offline   Reply With Quote
Old 06-16-2002, 07:14 AM   #4
KillerTHC
Member#: 4942
01 SRP 2.5 RS-T
Ludespeed Stage 3 Link'd
its all about how you drive. i know people who ran 12 psi multiple times at the track.
KillerTHC is offline   Reply With Quote
Old 06-16-2002, 11:13 PM   #5
mastervic27
Member#: 557
1999 Impreza 2.5RS
Vishnu Turbo
If you have around 270 ft-lbs of torque on a stock tranny don't dump the clutch at 3000+rpm.
mastervic27 is offline   Reply With Quote
Old 06-17-2002, 12:54 AM   #6
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
It's a matter of how you drive, not how much power is there. If you shock the trans all the time, it will break. If you drive easy, it will stay together.
I broke mine on 2psi of boost. KC_TopDog broke his NA. I knew a guy who had a stuck wastegate and didn't realize it, and ran 14psi and didn't break his.
Old 06-17-2002, 11:44 AM   #7
Ethan
Member#: 246
Yea I had my car at 12psi once, didn't break Just take it easy when driving!
Ethan is offline   Reply With Quote
IC vs Cu. In. vs HP OB2 Built Motor Discussion 6 03-05-2008 07:44 PM
V39 vs v30, spool up vs HP & torque manxaru Built Motor Discussion 4 02-20-2008 11:12 AM
My 98 OBS tranny VS. RS tranny. Ru fan Transmission (AT/MT) & Driveline 0 08-10-2001 04:26 PM
WRX Tranny vs 2.5RS Tranny Timmay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 05-15-2001 12:21 AM
Auto Tranny vs Manual Tranny DaveV Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 36 04-10-2001 08:50 PM
