Old 07-09-2010, 02:01 PM   #1
berdugo
Member#: 163108
07 EuroDM STi 2.5L
Question Thinking of putting the battery at the trunk, what wire gauge to use?
I'm thinking of putting my battery at the trunk area so I can put something on it's place, what wire size do you suggest?
Are 2 AWG 10 in parallel good enough for the +12V of the battery? thanks in advance
berdugo is offline   Reply With Quote
Old 07-09-2010, 04:00 PM   #2
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
Rotated BW S256 6speed
I went to a welding supply strore and bought welding cable in single 0 size. It was pretty expensive, but I chose to run the ground all the way up to the engine block to avoid having ground issues, so this doubled the amount I needed. I think it was $160 for the cable, but the stuff is big, fine strand copper, really flexible which makes routing so much easier, and it has a thick rubber exterior. It's made to carry large amounts of juice for welding, so it has very low resistance with battery voltage.
I did a bunch of OHMS test on all my chassis grounds and it is very low. Like I said I ran the ground all the way to the block and then the old battery cable ground from the block to the chassis. Put an Optima Red Top in a battery box bolted down in the trunk, and everything works awesome. I figure if your going to do it, spend a little extra and do it right the first time. The last thing you want is ground problems on a turbo motor with lots of electronics.
Good Luck!
morrocco88 is offline   Reply With Quote
Old 07-09-2010, 09:50 PM   #3
MainFrame
Member#: 218739
2002 WRX hybrid
It's the amps you have to worry about, not the volts. You can run 12V through telephone wire as long as you're not drawing a lot of amps.
MainFrame is offline   Reply With Quote
Old 07-10-2010, 12:54 AM   #4
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
uh, no 2 10 gauge in parallel isn't enough.
Running 2 wires in parallel is same current capacity as a wire 3 AWG lower. So (2) 10 AWG wires in parallel is equivalent to 7 AWG.
I don't know the exact current when the starter is going, but I imagine it's close to 100 amps. If you go by the ultra conservative electrical code, that's about 2 AWG. I know people who have gotten away with 4 AWG under seat because the code is pretty conservative. I wouldn't go smaller than 4 AWG.
If you want to approximate 4 AWG with 10 AWG wires, you'd need (4) in parallel, and have a good solid connection joining them together.
Concillian is offline   Reply With Quote
Old 07-10-2010, 01:42 AM   #5
JesseL
Member#: 169556
07' OPB STi BW S256
01' 2.5rs GM6 w/leather!
I've done this on 3 of my personal cars, and a few racecars, and a few buddies cars.
I used to use 0/1 gauge, but that got spendy, did a buncha math one night, and for 20 feet @ 150amps (Cranking power) at 12v, 2 gauge was more then enough.
I usually go to napa, and its about 3 bucks a foot, comming out to about 60 bucks for the wire.
Also, if you ever plan on running at the track, there are alot of extra rules for running the battery in the trunk, check with IHRA or NHRA for specifics, but 1/2 all-thread mounts, battery isolation switch (THAT KILLS THE CAR, meaning you have to break the alternator wire too), battery box, and so on. I've never auto-xed so I'm not sure what their rules say about it.
JesseL is offline   Reply With Quote
Old 07-10-2010, 02:13 AM   #6
berdugo
Member#: 163108
07 EuroDM STi 2.5L
thanks for the help guys
I found a link for AWG sizes and amp capacity
http://www.powerstream.com/Wire_Size.htm
I just need to know the AMPs needed by the starter when cranking but I guess gauge 2 for the +12V plus another gauge 2 for the Bat ground will do.
I'll try to find nice gauge 2 wires here thanks again
Old 07-10-2010, 11:06 AM   #7
WRX 2002
Member#: 11211
2004 STi
Rally Blue
I used 2 gauge next time I would go with 4 gauge.
WRX 2002 is offline   Reply With Quote
Old 07-10-2010, 03:47 PM   #8
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
2ga or bigger is the way to go. As morocco said, the 0/1ga welding cable is good stuff due to the fine stranding and excellent flexibility. I used 2ga in my Mustang and have never had any problems cranking over a high compression 357ci engine. (Although now that I think about it, "high compression" is the same as the same as the stock CR for the N/A Subies. )
guys with CF trunks. What Torsion bars to use pulser9 Interior & Exterior Modification 14 01-05-2009 11:14 PM
any coments on putting the battery in the trunk billyr2.5 Newbies & FAQs 48 11-09-2004 07:44 AM
What happens when you put 75 Subarus on the Track at the same time? sponaugle Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 10-28-2002 05:05 PM
I'm putting on some 18's, but don't know what size tire to use Damon Brakes, Steering & Suspension 6 09-19-2002 11:08 AM
Imprezer - or anyone who has put a battery in their trunk alfriedesq Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 41 04-23-2002 02:11 PM
