Old 07-09-2010, 10:10 PM   #1
renob123
Member#: 41986
'06 STI/'85 Brat
Default VIDEO: Has your EJ22 smoked like this?
This is a shameless crosspost from the USMB. Below is a video of my EJ-swapped Brat. It's smoking like crazy. I use it pretty much only for rallyx. Have you seen one smoke this bad? If so, what did it end up being? Rings? Valves? Your mom?
Thanks.
Jacob
renob123 is offline   Reply With Quote
Old 07-09-2010, 11:02 PM   #2
thegonz
Member#: 180208
2008 DGM 2.5i sedan
96 leggy wagon ls
nope only when i clean out the throttle body with the spray
maybe its burning off carbon deposits?
thegonz is offline   Reply With Quote
Old 07-09-2010, 11:06 PM   #3
renob123
Member#: 41986
'06 STI/'85 Brat
Let's hope so. I was thinking about a Seafoam treatment, but I don't want to dislodge something. There could be some loadbearing crud in there:-)
Jacob
Old 07-09-2010, 11:12 PM   #4
Jessekrs123
Member#: 236927
2015 BRZ, 93 Legacy,
1984 BRAT
If you just dropped the engine in, its normal. On my first start after I overhauled my 22 it smoked even worse, and I was scared I thought the headgaskets might have failed, but it was only burning off leftover cleaning crap that was still in the engine.
Jessekrs123 is offline   Reply With Quote
Old 07-09-2010, 11:29 PM   #5
renob123
Member#: 41986
'06 STI/'85 Brat
Originally Posted by Jessekrs123 View Post
If you just dropped the engine in, its normal. On my first start after I overhauled my 22 it smoked even worse, and I was scared I thought the head gaskets might have failed, but it was only burning off leftover cleaning crap that was still in the engine.
Well, I finished the swap in March, so this isn't new startup smoke. It's seen its fair share of heat/abuse over the 5,000 miles since then. It started eating some oil, but that seemed sporadic.
Jacob
Old 07-09-2010, 11:55 PM   #6
emsmap
Member#: 159334
02 WRX, 99RS, 96L
AP3,PPG, BW S256
When I seafoamed my 2.2L impreza, It smoked really bad like it should. Yours might be coolant or carbon deposits
emsmap is offline   Reply With Quote
Old 07-10-2010, 12:00 AM   #7
renob123
Member#: 41986
'06 STI/'85 Brat
I don't think it's coolant because the coolant looks fine and plentiful. How could I find out if it's carbon deposits?
Jacob
Old 07-11-2010, 05:46 PM   #8
greekster
Member#: 220867
Does the smoke smell sweet? or like oil? If it's sweet, check you plugs and at least one should be super clean from coolant, although if it smoked like that for 5000 miles, it's probably not that. If it smells like oil, my bet would be rings. Had an old Civic one time that smoked like that, and most of the rings were lined up.
greekster is offline   Reply With Quote
Old 07-12-2010, 12:31 PM   #9
renob123
Member#: 41986
'06 STI/'85 Brat
It's oil. The plugs look normal, and my coolant level/color has been fine the whole time.
I'm picking up another EJ22 in a couple weeks. Aside from a two-day rallyx event, the Brat can just sit where it is. I guess I'll just check the oil every time I stop.
Jacob
Has anyone ever died like this? aerostar Off-Topic 33 11-10-2008 05:33 PM
Like hight Def? Your really gonna like this! 4wdrift Off-Topic 49 02-13-2006 05:48 PM
Warning: dont drive if you have partying and your gauges look like this! Rich L Tri-State Area Forum 5 08-09-2002 03:52 PM
If I see another... thread that has.... a stupid title.... like this I will go... twiztid Off-Topic 19 08-05-2002 01:41 PM
"Attn all passengers, does your car sound like this???" Subie Gal North West Impreza Club Forum -- NWIC 1 04-08-2002 09:34 AM
