Old 07-10-2010, 04:42 AM   #1
ryderx
Member#: 186044
2000 2.5rs w/ej205
Default 99LGT, new shortblock, tranny does not match anymore.HELP
well my engine went out on my 1999 Legacy gt 2.5. i bought a shortblock from Outfront motorsports everything went together great till it was time to put the engine back in the car.
Only the 4 main studs match from engine to tranny. the rest either have no hole or dont match up.
though it does snug up with the 4 studs, and only problem is i cant get a second bolt on the starter.
i though i researched throughly in getting right short block.. apparently not
MY question is, What are my options from here?
AND how many different bolt patterns are there for the EJ25?
-scot
ryderx is offline   Reply With Quote
Old 07-10-2010, 11:27 AM   #2
feint05
Member#: 152984
2004 jewbaru
jewbuilt, polish tuned
good question, have you called outfront yet?
feint05 is offline   Reply With Quote
Old 07-10-2010, 12:53 PM   #3
ryderx
Member#: 186044
2000 2.5rs w/ej205
Default not yet..
i have not, reason being is they never said this would bolt right into my car. and i was hoping that someone could fill me in on the different block patters, because every post i read said they were all like legos.
Old 07-10-2010, 01:21 PM   #4
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
How many bolts/studs did the original engine use? The older engine/tranny combos (like my '97) only used 4 (2 bolts up top and 2 studs at the bottom), so I'm curious if your '99 2.5GT used more than that. If it did, then you probably had one of the "hybrid" engines from the factory with the Phase II shortblock.
Anyway, there shouldn't be any issue whatsoever bolting things together. Which starter bolt do you think you don't have?
Pat Olsen
Old 07-10-2010, 01:57 PM   #5
ryderx
Member#: 186044
2000 2.5rs w/ej205
Old engine Phase II?
the starter bolt that i cant get in is the lower one that is not a stud. the hole is there but but it does not match up perfectly. there is a lip that i can feel when i slide a screw driver in there.
Old 07-10-2010, 04:35 PM   #6
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
You need to install a stud. Then you'll be fine. Everything else doesn't matter
Old 07-10-2010, 04:37 PM   #7
frankensubie
Member#: 220236
97 impreza obs
green
Subaru Stars
i dropped a 2000 forester trans into my 97 obs...there were a couple minor issues like you are describing...it bolted up ok , but i am currently only running with 1 bolt in the starter....the oem trans i took out had 1 stud one bolt...and there are two less bolt holes in the engine...however...the whole assembly tightened right up and has been working fine for the last 10k miles... the bolt pattern on the engines are the same EXCEPT for the fact there are two fewer bolts..i.e. 4 instead of 6
you should still be able to make it work...you may have to punch out the guide pins to line everything up for final torquing
frankensubie is offline   Reply With Quote
Old 07-10-2010, 07:34 PM   #8
frankensubie
Member#: 220236
97 impreza obs
green
in the trans that is
Old 07-10-2010, 09:28 PM   #9
69subaru360
Member#: 159682
1995 WRX
2015 F150
Easy fix. Take one of the long bolts. Grind about half of the head off so there is a flat side. Put it in through the bellhousing from the engine side so it sticks out like a stud. Put the starter on. Put a nut on the bolt. The flat you ground will contact the inside of the bellhousing letting you tighten it up. I do this all the time.
Old 07-10-2010, 11:36 PM   #10
ryderx
Member#: 186044
2000 2.5rs w/ej205
awesome you guys rock! thanks for the help i was worried!
Logged target boost does not match target table cava23 Engine Management & Tuning 16 06-01-2010 12:21 AM
Cigaret lighter does not work anymore. Pencils Electrical & Lighting 4 07-24-2009 09:52 PM
Logged target boost does not match map STIlin' Open Source Reflashes 1 04-15-2009 12:10 AM
Factory alarm not working anymore-Help Please!!! Noogin Car Audio, Video & Security 0 01-10-2006 08:37 PM
Omori North America does not exist anymore? imprezive one News & Rumors 21 01-30-2003 09:09 AM
