Old 07-10-2010, 10:19 AM   #1
whiterex19
Member#: 178073
06 wrx
white
Default tire fitment ?
just wondering if a 235/45 will fit my stock 06 wheels and will they rub on my car. Its lowered on tanabe gf10 springs. i was told all i needed to do was roll my fenders but i want to be sure before i order tires.
whiterex19 is offline   Reply With Quote
Old 07-10-2010, 01:27 PM   #2
rmarchigiani
Member#: 164584
2011 WRX STi
SSM
Assuming you are referring to the stock 17x7 with 215/45 on stock WRX, those tires will fit, but are going to be significantly taller than stock. Im not sure about what mods you will need if any. If I may ask, why are you set on that size?
225/45/17 would be better based on overall size (width/height).
http://www.1010tires.com/TireSizeCal...?action=submit
Hope this helps.
RM
rmarchigiani is offline   Reply With Quote
Old 07-10-2010, 01:31 PM   #3
whiterex19
Member#: 178073
06 wrx
white
i just wanted to go with a wider tire than stock and i didnt think 225 was gonna be much different
Old 07-10-2010, 03:35 PM   #4
rmarchigiani
Member#: 164584
2011 WRX STi
SSM
I see....I suppose the 235/45 would work....but its going to be much taller than stock and the 235 width is really not needed on a 7 inch wide wheel. You might get a bit of that muffin top look.
If you are stuck on doing that, then you can also look into 235/40, which will be a little shorter than stock. In my opinion a 225/45 is the best option for something a little wider, but the appropriate height and width for your wheels.
So in the end its up to you, but I would recommend a 225/45 or a 235/40 if you are stuck on a 235 and dont mind a tire thats going to be a bit "squishy". Or just get new wheels that will require a 235 or 245.
tire fitment question (getting no response in tire forum) Spooled Southern California Impreza Club Forum -- SCIC 7 05-17-2003 01:51 PM
tire fitment? newbie1 Brakes, Steering & Suspension 0 08-10-2002 01:33 AM
Q re Rim & Tire Fitment on WRX Wagon SC WRX Brakes, Steering & Suspension 2 07-22-2002 10:02 PM
Tire Fitment Calculator daytontp Brakes, Steering & Suspension 2 02-05-2002 10:10 PM
