Go Back   NASIOC > NASIOC Classifieds > Vendor Storefront Forums > RavSpec
Old 07-10-2010, 10:54 AM   #1
RavSpec
NASIOC Storefront Vendor
Vendor Sales Rating: (88)
Member#: 26854
2002 Impreza
WRX
Default WEDSSPORT Lightweight JDM Wheel *** In Stock Special ***
Quick Menu: ***** || RAYS TE37SL || ADVAN RGD 5x100 || WORK Emotion Special || ADVAN TCIII Spec || 5x100 Zone -WRX Special ||
WEDSSPORT TC105N - 17x8.0 42mm offset 5x114.3, Bronze (05+ STI Brembo) ** 14.9 lbs
WEDSSPORT TC105N - 17x9.0 49mm offset 5x114.3, Bronze (05+ STI Brembo) ** 15.7 lbs
WEDSSPORT TC105N - 18x9.5 35mm offset 5x114.3 Bronze (05+ STI Brembo) ** 17.6 lbs
WEDSSPORT SA55M - 18x8.0 45mm offset, 5x114.3 GM or Blue/Black Machine (05+ STI Brembo) ** 18.5 lbs
WEDSSPORT SA55M - 18x9.0 36mm offset, 5x114.3, GM or Blue/Black Machine (05+ STI Brembo) ** 19.5 lbs
WEDSSPORT SA55M - 18x10.0 36mm offset, 5x114.3, Gun Metal (08+ STI Brembo) ** 19.5 lbs
WEDSSPORT SA67R - 18x9.0 36mm offset, 5x114.3, Gun Metal (05+ STI Brembo) ** 19.2 lbs
WEDSSPORT SA67R - 19x9.0 +35mm offset, 5x114, Gun Metal (05+ STI Brembo) ** 20.9 lbs
Hey All:
Weds Japan - one of the top wheel manufacturer in the world. Their wheels line up included lightweight tuning wheels that are being use in JGTC and many racing circuit and luxury sport wheels that are popular on the street of Tokyo. Their newest lightweight tuning wheel series "Wedssport" series included SA55m, TC105N, SA67R and SA70. Using the newest AMF flow form casting technology, Weds Japan bring you the lightest tuning wheel in the market. (see below for AMF definition)
(AMF Technology)
AMF (Advanced Metal Forming) is one variation of rotation forming process that rotates a metal pipe axis and casts the material on the roller.
Casting and Forging
Generally, the advantage of casting is that it melts aluminum alloy at high temperature and pours into a mold to form as one so the designing flexibility on the disc is pretty high thus it’s easy to mass produce and cost effective. On the other hand, from technical stand point, it’s hard to reduce weight since it’s difficult to form into thin metal. Also what was formed through casting is often uneven and particles are not cohesive therefore its strength is not good enough. On the other side, forged wheels are made by running a lump of aluminum or alloy into high-pressure pressing machine thus aluminum particles spread and formed according to wheel shape and it is stronger (Fiber Flow). Because of the way they are produced, forged wheels can be made light-weight. It seems like it’s perfect but there is a definite weakness of “It’s not flexible from design perspective. It has already been explained, forging process uses high rate of weight to form the shape consequently, it is not suitable for complicated cosmetic face design. Forging also has a disadvantage of being more expensive due to multi-processing.
"New method of manufacturing process" to make up for the weakness is born.
In AMF, first of all, simultaneously cast rim and disc. Secondary, cast disc (= rim material) is to be put through wheel-only spinning processor and roll the rim. It realizes more flexible and tenacious strength by having aluminum material’s crystal and macro formation get further detailed through being forged in this process. As a result, high-strength rim with “stretch strength,” “durability,” and “spread” which are basic characters required for aluminum wheels, is born. Now it is possible to create high-precision rim that is seamless tube as compared to the type that forms a sheet material into a ring through welding. AMF on disc surface is normally casted, it keeps design-flexibility, but it contributes to reduction of under spring load because the rim-part is spread thin as much as possible by spinning machine. Such new method of manufacturing process method is AMF which has the merit of both casting and forging. AMF was newly created the WedsSport brand concept “Faster, Safer.” New generation technology improved in motor sports enters the scene with superb performance.
__________________
[ WORK WHEELS ] [ RAYS WHEELS ] [ YOKOHAMA WHEELS ] [ WEDSSPORT WHEELS] [ FERODO ] [ BC RACING ] [ KW ] [ DBA ROTORS ] and many more!
TEL: 631-586-3520
EMAIL:
RavSpec is offline   Reply With Quote
Old 07-10-2010, 10:57 AM   #2
RavSpec
Member#: 26854
2002 Impreza
WRX
WEDSSPORT SA55M MGM Color - 18x9.0 +36mm offset
WEDSSPORT SA55M BBM Color - 18x9.0 +36mm offset
WEDSSPORT SA55M Matte Black Color - 18x10.0 +18mm offset
__________________
TEL: 631-586-3520
EMAIL:
Old 07-13-2010, 12:38 PM   #3
RavSpec
Member#: 26854
2002 Impreza
WRX
WEDSSPORT SA55M in BRM (Black Red Machining) *** Production Wheel ***
Just got the sample wheel from Japan. / Enjoy
__________________
TEL: 631-586-3520
EMAIL:
Old 07-13-2010, 01:08 PM   #4
alwazsidwaz
Member Sales Rating: (5)
Member#: 133454
2004 Forester
AW
Please tell me the 18x9 +36 is in 5x100 bolt pattern.!?
alwazsidwaz is offline   Reply With Quote
Old 07-13-2010, 01:10 PM   #5
RavSpec
Member#: 26854
2002 Impreza
WRX
hahah, not going to happen .. unless we get 10 sets.
only 18x9.0 +20mm 5x114.3 and 18x10.0 +18, 5x114.3
__________________
TEL: 631-586-3520
EMAIL:
Old 07-13-2010, 02:39 PM   #6
Thran
Member Sales Rating: (57)
Member#: 63612
2004 dom 2.5 wrx
Rally Blue
i would be down ; (
but i was still hoping for 17 x 9 sa-70 ; (
Thran is offline   Reply With Quote
Old 07-14-2010, 07:55 PM   #7
stav05sti
Member#: 222771
2005 Impreza WRX STi
What is the price on a set of SA55M MGM color 18x9 +36 please? Also weight per wheel please.
stav05sti is offline   Reply With Quote
Old 07-14-2010, 08:01 PM   #8
RavSpec
Member#: 26854
2002 Impreza
WRX
19.5 lbs per wheel. Price PMed !
__________________
TEL: 631-586-3520
EMAIL:
Old 08-21-2010, 10:52 PM   #9
greddy90
Member Sales Rating: (-1)
Member#: 147065
Who else wants 5x100? He said we need 10 sets
greddy90 is offline   Reply With Quote
Old 09-02-2010, 10:55 PM   #10
bigSTIck7
Member Sales Rating: (3)
Member#: 206740
'04 STi
I'd be interested. 5x100 18x10
bigSTIck7 is offline   Reply With Quote
Old 09-02-2010, 11:40 PM   #11
RavSpec
Member#: 26854
2002 Impreza
WRX
My advice for those who wants wide width 5x100 is to go with
WORK Emotion series or any WORK wheels or WEDS 2 piece or 3 piece line up.
WEDS one piece cast wheels (WEDSSPORT series) required too high of a minimum to produce in 5x100.
__________________
TEL: 631-586-3520
EMAIL:
Old 09-02-2010, 11:43 PM   #12
JDM_OBP
Member Sales Rating: (9)
Member#: 105409
'05 HTA68'd WRX
327/310
got a link for the WEDS 2pc and 3pc line? would love a nice set of 18x10's in 5x100
JDM_OBP is offline   Reply With Quote
Old 09-03-2010, 12:45 AM   #13
RavSpec
Member#: 26854
2002 Impreza
WRX
main website: http://www.weds.co.jp/
my all time favorite: WEDS Bvillien TT7R
__________________
TEL: 631-586-3520
EMAIL:
Old 10-05-2010, 09:51 PM   #14
Markvonduke
Member Sales Rating: (1)
Member#: 252534
2011 WRX STI Hatch
PBP AWD stage 2 tuned
please tell me those WEDS Bvillien TT7R's fit 2011 sti!!!!
Markvonduke is offline   Reply With Quote
Old 10-08-2010, 07:47 PM   #15
RavSpec
Member#: 26854
2002 Impreza
WRX
sure, we can make the offset and bolt pattern to fit on 2011 STI.
__________________
TEL: 631-586-3520
EMAIL:
Old 10-10-2010, 10:41 PM   #16
FritoBandito
Member#: 96585
05 STI
could i get a price on 18x9 +36 5x114.3 sa55m gm and sa67r gm shipped to 87109?
FritoBandito is offline   Reply With Quote
Old 02-27-2011, 12:30 AM   #17
slidewayscoupe
Member Sales Rating: (17)
Member#: 186308
2004 Impreza WRX STi
Java Black Pearl
Can you PM me pricing on:
slidewayscoupe is offline   Reply With Quote
Old 03-01-2011, 10:37 PM   #18
scotheocelot
Member#: 254768
2011 STi Sedan
The STI pictured has a wide body. So if you think those exact wheels with the awesome lip on it will fit on your 2011, it will not. I have a set of Work VSXX's with serious lip for my Nissan and it was no where near fitting on my 2011 STI sedan. Keep that in mind if you are hyped up about the lip.
scotheocelot is offline   Reply With Quote
Old 03-01-2011, 11:42 PM   #19
RavSpec
Member#: 26854
2002 Impreza
WRX
well, it comes down to your meaning of "awesome lip".
These are two piece custom offset wheels. We can built them in alot of different spec.
For 2011 STI, we can built them with at least 3.5" lip. Remember that 2011 STI has a much the 2004~2007 STI.
In addition, camber adjustments, roll fenders will help fitting wheels with lower offset onto STI, "IF" that's the route you want to go with.
We have seen people fitting 18x10.0 +18mm offset on STI. It's ridiculous camber and super stretch tires.
__________________
TEL: 631-586-3520
EMAIL:
Old 03-07-2011, 01:25 AM   #20
slidewayscoupe
Member#: 186308
Java Black Pearl
still looking for those prices
Old 03-07-2011, 02:29 PM   #21
RavSpec
Member#: 26854
2002 Impreza
WRX
pm sent !
__________________
TEL: 631-586-3520
EMAIL:
Old 03-16-2011, 02:31 PM   #22
rodder
Member Sales Rating: (44)
Member#: 86128
2005 OBP STi 355 whp
RIP :(
Can I also get a price quote for a set of these? Thanks.
rodder is offline   Reply With Quote
Old 03-17-2011, 12:05 AM   #23
RavSpec
Member#: 26854
2002 Impreza
WRX
all PM replied !
__________________
TEL: 631-586-3520
EMAIL:
Old 03-25-2011, 02:27 PM   #24
sjs0433
Member Sales Rating: (29)
Member#: 86061
price on 17x9 +49 TC105N shipped to 23832 please! Please PM me
sjs0433 is offline   Reply With Quote
Old 03-25-2011, 02:37 PM   #25
RavSpec
Member#: 26854
2002 Impreza
WRX
PM Sent !
__________________
TEL: 631-586-3520
EMAIL:
Seibon Open Box Specials-JDM V-Limted In Stock-Rain Guards In Stock-Wagon Lips Gruppe-S Exterior/Styling 20 03-17-2009 05:32 PM
Seibon Open Box Specials-JDM V-Limted In Stock-Rain Guards In Stock-Wagon Lips Gruppe-S Exterior/Styling 55 02-09-2009 09:03 PM
Volk Wheel In stock Specials Fizz Autosports Wheels/Tires 48 03-10-2005 03:07 PM
Volk Wheel In stock Special low prices Fizz Autosports Wheels/Tires 31 12-15-2004 01:08 PM
