Vancouver Impreza Club
Old 07-10-2010, 08:00 PM   #1
J-Chow
Member#: 104722
2006 2.5i - SOLD
Gray
Exclamation Recommendations for new summer tires
What up peeps.
It's that time of the year again, and I'm due for new summer tires. Got about 10-15% left on my Kumho SPT's.
I"m probably going to order through tirerack and ship to point roberts to save at least $50-60 on shipping costs.
I've narrowed my selection on two choices:
Hankook Ventus V12 Evo - 225/45/17 - $368
Sidewall Style: Blackwall
Serv. Desc: 94YLoad Index 94 = 1477lbs (670kg) per tire
Speed Rating "Y" = 186mph (300kph)
Load Range: XL
UTQG: Treadwear: 280
Traction: AA
Temperature: A
280 AA A
Rating: 8.4
or
General Exclaim UHP - 225/45/17 - $384
Serv. Desc: 91WLoad Index 91 = 1356lbs (615kg) per tire
Speed Rating "W" = 168mph (270kph)
UTQG: Treadwear: 380
Traction: A
Temperature: A
380 A A
Rating: 8.3
Shipping to pt roberts: $58.
I've viewed the specs and have compared both of them according to tirerack's comparo charts. Pretty similar. Hankook has the slight advantage in cornering but GE has the advantage on treadwear.
Just wanted to see if any of you suby enthusiasts have used either or of the above tires and what you thought about them. Also, I'm contemplating if I should go for a 225 or a 215 size.
Your opinions are greatly appreciated.
- J.Chow
J-Chow is offline   Reply With Quote
Old 07-10-2010, 09:17 PM   #2
Whistlerfish
Member#: 229646
I have the Hankooks V12's in the 225/45/17 size and love them but to be fair I haven't tried anything else on my as a comparison.
Whistlerfish is offline   Reply With Quote
Old 07-10-2010, 09:41 PM   #3
timbits
Member#: 166183
2007 2.5i SE
Newport Blue
I just went through this very choice. Replacing my SPT's...
Was also looking at Exclaims, but settled on Potenza RE760. I like asymetric for rotatability, and they ranked higher on the reviews. Was more money though ($520), but I think they'll last longer than the others.
If you're gonna pay $385 for exclaims, you might as well pay $400 for another set of SPT's.. I think they're a better tire.
timbits is offline   Reply With Quote
Old 07-10-2010, 09:57 PM   #4
Whistlerfish
Member#: 229646
Here's the Car and Driver test of these tires. The Hankooks came in 2nd, the 760's 4th. The Exclaims weren't included in the test.
http://www.caranddriver.com/reviews/...mparison_tests
Old 07-11-2010, 12:58 PM   #5
Linkseal
Member#: 102329
05 AW Piggy Gone
11 SP TOM'S IS-F
Linkseal is offline   Reply With Quote
Old 07-11-2010, 01:16 PM   #6
Penphoe
Friendly Neighbourhood
Member#: 269
2005 ABP LGT LTD BP6
00 Impreza RS GM6 RIP
I've got a set of UHPs running 225/45R17's on my Legacy. I find that the sidewalls are soft (not that that's a bad thing) compared to my old snow tires that were previously mounted on my wheels (Yokohama AVS Wintersports). I haven't pushed them at all, but they seem to be fairly comfortable and quiet. Do make note that they are rated as "M+S" tires and some people run them through the winters of Vancouver but the tread pattern pretty well has no siping for any cold traction! YIKES! Even though they are "M+S" marked, General themselves do not recommend them for mud and snow use.
LaterZ!
Darren!!
Penphoe is offline   Reply With Quote
Old 07-11-2010, 01:51 PM   #7
timbits
Member#: 166183
2007 2.5i SE
Newport Blue
Originally Posted by Penphoe View Post
Do make note that they are rated as "M+S" tires and some people run them through the winters of Vancouver but the tread pattern pretty well has no siping for any cold traction! YIKES! Even though they are "M+S" marked, General themselves do not recommend them for mud and snow use...
The M+S rating granted to tires is based on the its ratio of tread voids to tread blocks. Actual winter or mud performance testing is not required.
Old 07-11-2010, 02:10 PM   #8
alvinli217
Member#: 133236
2010 TR GTI
04 WRB STi-GONE
Yokohama S.Drive
alvinli217 is offline   Reply With Quote
Old 07-11-2010, 03:32 PM   #9
NorthVanWRXOwner2be
Member#: 220761
2015 WRX
I have a set of the Hankook's you're considering and I'm not liking them all that much.....You get what you pay for!!
They aren't the best wet tires and when I push it hard around corners the sidewalls feel like their going to give in...
My favourite wet tire of all time are the Goodyear Eagle F1 GSD3 (something like that) and the Azenis RT615's had much stronger sidewalls than these things and the dry traction was much better.
Wanna buy mine? They only have about 1500 km's on them.
NorthVanWRXOwner2be is offline   Reply With Quote
Old 07-12-2010, 01:01 AM   #10
J-Chow
Member#: 104722
2006 2.5i - SOLD
Gray
LaterZ!
Darren!!
I've read a few more reviews, and other users have also claimed that the sidewalls were pretty soft and vulnerable, so that's something I have to consider thinking about
Originally Posted by alvinli217 View Post
Yokohama S.Drive
I have also considered these as well. So it's in the maybe pile.
Originally Posted by Linkseal View Post
Not a fan of the stock OEM sti tires
I did like the SPT's, but I was thinking if there was another set of tires that would be comparable but at a less expensive cost
You sir, have a PM.
Thanks for the input peeps,
I'm just wondering also if there were any "performance" differences between a 215 and 225 tire size? What I'm looking for is a DD performance tire, that does quite well in dry and wet surfaces, but also has good treadwear, so it won't **** out on me within the first 10-15k. I only do spirited driving, and I haven't autoxed in years, so that's out of the picture, and no tracking
Old 07-12-2010, 02:48 PM   #11
minifreak
Member#: 116914
2006 WRX Wagon
Obsidian Black
I am running the Hankook Ventus V12 EVO in 245/40/17 stretched on 17x9 rims and I really like them so far for daily driving. It is not very loud, tracks straight and has better wet traction than my RT615. I always run my tires slightly over inflated so I don't have problems with the soft sidewall.
But if you don't plan on doing autoX or track I wouldn't bother with this tires.
minifreak is offline   Reply With Quote
Old 08-16-2010, 07:27 PM   #12
J-Chow
Member#: 104722
2006 2.5i - SOLD
Gray
So... I ended up going with the hankooks and so far so good!
thanks for the advice peeps!
Old 08-16-2010, 08:21 PM   #13
minifreak
Member#: 116914
2006 WRX Wagon
Obsidian Black
Are you running the stock size? I am still unsure about the driveability of the tires in the wet yet... The once time I got to drive in the rain it felt slightly unnerving, but that could be due to it being the first real rain in a while or the high tire pressure/width I am running...
Old 08-16-2010, 08:31 PM   #14
J-Chow
Member#: 104722
2006 2.5i - SOLD
Gray
running 225/45/17. Currently at 32 psi for each tire.
Old 08-16-2010, 08:34 PM   #15
Ricewagon
Member#: 59703
2004 STi
always wrb
Yokohama AD08.
Ricewagon is offline   Reply With Quote
Old 02-09-2011, 11:46 PM   #16
thesniperz
Member#: 235744
2000 Forester STi
White - JDM yo!
old thread bump.
planning to get the Hankooks as well..
how are they holding up Justin?
-JC
thesniperz is offline   Reply With Quote
Old 02-10-2011, 05:17 AM   #17
J-Chow
Member#: 104722
2006 2.5i - SOLD
Gray
I've only used them a for a few months, and love em. Great in wet and dry conditions! Still have like 95% tread. Used for 4-5 months?
Old 02-10-2011, 11:27 AM   #18
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
I'm thinking Federal 595RS-R, haven't seen any locally
kgb is offline   Reply With Quote
Old 02-10-2011, 03:39 PM   #19
Scooby-King
Member#: 180499
2007 SRT8-Cherokee
2008 Sierra Denali
Just ordered the RS-3 from CRackrack. - delivered to Sumas today, so I'll shoot down and pick em up.
will post review once I get some miles on them though !
I believe they were 120ish / each ... cheap = good
Scooby-King is offline   Reply With Quote
Recommend a good summer tire please... bmw50021 Tire & Wheel 70 05-01-2009 04:29 AM
Please recommend a good summer tire for commuting ilara72 Tire & Wheel 11 04-19-2008 09:29 AM
New Summer Tire Recommendations soulbazz Tire & Wheel 19 03-07-2008 04:35 AM
Recommends for new summer set-up needed gregor2001 North West Impreza Club Forum -- NWIC 5 12-30-2006 01:54 PM
Any new summer tire recommendations? SVX Forester Forum 5 03-14-2006 03:54 AM
