Old 07-10-2010, 09:46 PM   #1
XenoWolf
Member#: 64029
1999 Impreza L Wagon
Sun Bleach Red
Default 3 slipped teeth = valve damage?
I'm currently replacing my timing belt after some slippage. I believe that it skipped 2-3 teeth.
Should I be worried about belt valves?
Edit: Some more info would be useful. It's a '99 SOHC EJ22.
XenoWolf is offline   Reply With Quote
Old 07-10-2010, 10:24 PM   #2
69subaru360
Member#: 159682
1995 WRX
2015 F150
In my experience it will probably be fine if it's only 2-3 teeth off. I've had a lot like that and none bent valves.
Old 07-10-2010, 10:42 PM   #3
XenoWolf
Member#: 64029
Sun Bleach Red
Thank you, that's what I wanted to hear.
Old 07-10-2010, 10:53 PM   #4
mbtech
Member#: 215510
2001 2.5 RS
I highly doubt there bent but it depends which way it slipped. I had a 4g63 that skipped 8 teeth and didnt bend and those are the most nitorouis for valve damage that was the first time I had seen a 4g63 slip without valve damage but I think your ok. Good luck
mbtech is offline   Reply With Quote
Old 07-11-2010, 12:52 AM   #5
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
do a compression test to be sure.
Old 07-11-2010, 12:57 AM   #6
jakedademon
Member#: 157764
2002 '02 SZ55 hyb
2002 v9 EJ207 VF22 wagon
Compression and a leakdown.
jakedademon is offline   Reply With Quote
Old 07-12-2010, 09:25 PM   #7
Supraru
Member#: 23313
99' 2.5Rs
black
I don't know what you guys are talking about. I've seen a couple bent valves from skipping one tooth. Then again I've seen two teeth with no damage. Generally for me at work (subaru dealer) if a car is off two teeth expect bent valves. But I have seen some lucky people. And comparing other cars and how many teeth they had timing belts skip is pretty retarded. We're talking about a subaru engine. They run **** really tight.
Supraru is offline   Reply With Quote
04 STi PCV Valve Damage from FPgreen HELP! SubaruBen Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 16 08-13-2008 06:02 PM
Foot slipped off clutch... damage? Mike37 Newbies & FAQs 21 01-07-2007 08:53 AM
Canister Purge Valve damaged?? alwrxwu Newbies & FAQs 1 02-22-2005 01:56 PM
Canister Purge Valve damaged? alwrxwu Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 02-22-2005 01:29 PM
Timing belt/valve damage Roswellj07 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 11-03-2003 07:22 AM
