Old 07-11-2010, 03:45 AM   #1
chickencherryaki
Member#: 240580
Default 05 sti grimmspeed aos w/ perrin inlet
i'm trying to figure out the correct way to route the lines on an 05 sti with a perrin inlet + gs aos. i've spent over 3 hours studying every post i could find regarding pcv lines, catch cans, etc. i've read and re-read the instructions for the aos, checked the gs web site, and watched the gs install videos on youtube, etc.
my trouble is with understanding how to install the gs aos correctly since they only provide instructions for people with the stock lines in place and mine are all run differently due to the prior install of the inlet. i created a diagram in an attempt to help myself understand stock vs inlet vs inlet+aos. i want to make sure i hook it up right as i don't want the aos to malfunction, or to blow out seals on the engine, etc. i am hoping some of the gurus would chime in and let me know if i'm on the right track or if i did something wrong.
thanks in advance.
note: the purple circles on the diagram represents the crank case/head/block ports and the light blue represents the stock black metal pipe that goes under the manifold.
edit: http://forums.nasioc.com/forums/atta...1&d=1067969162 another diagram i found that looks similar to mine and the gs install video if that helps.
chickencherryaki is offline   Reply With Quote
Old 07-11-2010, 11:36 PM   #2
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
That looks correct. The AoS keeps the stock PCV system (which dumps into the inlet), allowing it to dump into to the AOS as your orange line illustrates. You've got it all figured out from what I can see.
With the Perrin inlet, you were plumbed into the breather off of the passenger side valve cover, which just made the PCV gases take a long route through the stock breather "Y" back into the intake. The AoS eliminates dirty PCV dumping into the inlet, using the green line to dump clean stuff back in.
OrbitalEllipses is offline   Reply With Quote
Old 07-12-2010, 12:53 AM   #3
chickencherryaki
Member#: 240580
cool thanks a lot for the confirmation. got the aos hooked up today. w00t!
Old 07-12-2010, 04:12 PM   #4
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
So you got it all figured out eh? Shoot, wish I could have seen this earlier, well let us know if you need any other help, and shoot us a pm with how its going!
Will
GrimmSpeed is offline   Reply With Quote
[WA] FS: VF48, 05 sti tmic, bnib APS turbo inlet, + more fraktal NWIC Private Classifieds 8 04-14-2010 02:11 AM
FS: STi TMIC, 05 STi hood scoop, splitter, Perrin i/c hoses WRX-Traterrestrial NWIC Private Classifieds 16 01-16-2009 01:03 AM
FS: DFW Tons of 05 STI parts for sale -perrin, cobb, header, pulley jichoe Engine/Power/Exhaust 35 02-11-2008 03:31 PM
FS: DFW Tons of 05 STI parts for sale -perrin, tbe, fue, cobb, header, pulley jichoe TXIC Private Classifieds 34 01-10-2008 04:19 PM
FS: DFW Tons of 05 STI parts for sale -perrin, coilover, endlinks jichoe Suspension/Brakes/Handling 33 01-10-2008 05:57 AM
