Old 07-11-2010, 12:05 PM   #1
gooder77
Member#: 32922
2002 WRX sedan
Default Advice needed for temp fix on peeling/cracked clear coat
Here's the short version: bird crap stayed on the roof too long and destroyed the clear coat.
The first pic shows the clear coat actually peeling. The total affected area is about the size of my thumbnail. The part that's peeling is the size of my pinky nail.
The second pic shows the clear coat all cracked and nasty looking. Total affected area is about the size of a half dollar.
I've read that the only way to really fix is to repaint. Can shops just repaint the affected area or would they typically have to repaint the whole roof?
I have a little bottle of clear coat that came with my rim touch-up paint. Can I use that as a temp fix to try to stop the clear coat from peeling for the first pic?
gooder77 is offline   Reply With Quote
Old 07-11-2010, 12:19 PM   #2
STimedic
Member#: 104765
02 STi :D
2011 PRP FXT T
Better/cheaper solution? Vinyl wrap....it's what I'm doing. Subaru paint sucks ass and I don't feel like shelling out 2k+ for a decent paint job when I can dole out half that for vinyl.
STimedic is offline   Reply With Quote
Old 07-11-2010, 08:09 PM   #3
gooder77
Member#: 32922
2002 WRX sedan
You wrapping the whole car? I suppose that might be another option for the roof.
Old 07-14-2010, 12:27 AM   #4
TXwrxWagon
Member#: 191557
2004 WRX Wagon
WRB not so minty fresh
if the area is between the black roof/side seam "drip moldings" I would have a semi-gloss or flat vinyl wrap done. its trendy, but it will cost little.
That said... in a controled area like the main roof panel, or a trunk, hood, single door, or fender, they can usually carefully sand the clear & then reclear... its an '02 that , from the looks of it, hasn't had much in the way of proper care, sorry... just sayin' . the trick with OE paint is staying AHEAD of it instead of trying to fix problems after they pop up.
If a bird cut loose on my wife's '04 Mountaineer or my just returned home today, freshly painted, '04 WRX Wagon, I would use anything handy... bottled water, soda from the gas station... ANY liquid.. the sticky will do less, the carbonation will do less than the stomach acid & plant acids from bird poop & acid rain...
anyway... can you take a wider shot of where exactly the 2 areas are? are they on the same panel?
That can help make a better low-cost recommendation.
Rob
TXwrxWagon is offline   Reply With Quote
Old 07-14-2010, 01:43 AM   #5
gooder77
Member#: 32922
2002 WRX sedan
Rob - yup, it's an 02 and yes, the paint has seen better days. I tried to be vigilant on bird bombs, but these two got me real good.
This pic isn't my car, but I marked where the cracking/peeling is happening. The cracking is happening on the mark on the passenger side. The peeling is happening on the mark in the middle.
I actually don't mind the look of a gloss black roof. It would definitely be a lot cheaper than painting even if the shop could spot treat.
Old 07-16-2010, 11:36 AM   #6
slo5oh
Member#: 43608
If your paint is peeling/cracking there already, be sure to clean and wax your hood scoop. The plastic parts were the first to peel on my '98.
an after thought... if you're going to try to DIY, having mangled my own hood scoop trying to fix a spot that looked very similar to yours, I'd say you should start with a new coat of clear or 2, let it dry then sand it down. I found out REALLY fast that the clear coat is #1 much thicker and #2 much harder than the actual colored paint. I had sanded through the color paint within seconds using only 1000 grit and water, long before I had managed to "round" down the edges of the peeled clear coat.
slo5oh is offline   Reply With Quote
oe turbo for temp use on my 04 sti (cheaper/better) must work KB'izzle Private 'Wanted' Classifieds 3 01-04-2010 11:42 PM
L.A. welder needed for Header fix klhbeetle Southern California Impreza Club Forum -- SCIC 8 05-03-2008 06:52 PM
wheels needed for temp purposes SubeSTIle South West Impreza Club Forum -- SWIC 2 03-18-2007 06:20 PM
peeled off clear coat on bbs gold rims Rumble_Stealths_King Newbies & FAQs 5 03-17-2007 10:28 AM
Any comment on Turtle Wax Clear Coat? au112 Interior & Exterior Modification 0 01-13-2002 03:42 AM
