#1 |
Member#: 64029
Vehicle:1999 Impreza L Wagon Sun Bleach Red |
Here's the story:
Tuesday - Drove the car to and from work (~70 mi) with no issues. Wednesday - Got up in the morning, started the car and let go of the ignition too quickly. It started, but was chugging like crazy and had NO power. I've reset the ECU. Didn't help I've checked the cats -- they're fine. I've replaced the timing belt -- it's fine and the car is timed correctly. I've replaced plugs and plug wires. The two front plugs had gas/oil all over them. Didn't help. Here's the thing. Twice the car has started up and worked PERFECTLY. Once immediately after I removed the cats, and once immediately after I replaced the timing belt. It doesn't last though. It went right back to chugging the next time I started it up. My next step is taking it to a garage to do a compression test. I suspect that it's something electrical since it has worked fine twice, but I want to be sure. Any ideas? Could this possibly be a bad alternator or bad CPS? Bad ECU? I'm getting really pissed off at this car teasing me. ![]() Oh, and I had one CEL that popped up, but after replacing the timing belt it went away. No more CELs are active. 1999 Impreza L 2.2L w/ 5-speed
#2 |
In the silly seat
Moderator Member#: 34935
Vehicle:SPB- 2013 Smugmobile |
Spark distribution block thing that the wires plug into? Swap yours with a friend's and check.
If the plugs really have oil on them you have some other issues but that shouldn't cause this. |
#3 |
Member#: 26658
South East
Vehicle:1 Love Grassroots NASA Rally Sport FTW! |
Is there an air idle control valve on that engine? They get sticky and stop working...
#4 | |
Member#: 64029
Jard: Maybe. I could probably grab one off of Andrew to test. I'm just baffled by the lack of a CEL though if it is electrical/ignition related. |
#5 |
Member#: 64029
Update: I believe that it may be the coilpack.
Cylinders 1 and 3 are both dumping fuel. They're also connected to the exact same coil. Can anyone verify if each coil uses a separate CPS? If so, I imagine that the CPS may also be a culprit. |
#6 |
In the silly seat
My '95 SOHC 2.2 would not spark at all with a bad cam sensor...
#7 |
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT QuickSilver Metallic |
CPS? Not familiar with that term.
#8 |
In the silly seat
#9 | |
Member#: 120
AKIC
Didn't really catch this before...
![]() I've had coils with both male and female terminals and they were all the same. Pat |
#10 |
Member#: 64029
Pat: You're right. I'm retarded and can't read apparently. I read it as 1 & 3 last night when I was looking at it for some reason.
Sorry about the vagueness of the CPS term. I was referring to the crank position sensor, not thinking about having a cam sensor. I've since found that I have one of each and where they're located. |
| Thread Tools | |
| Display Modes | |
| I've run out of time. | polvo | Subaru Conversions | 21 | 06-26-2007 01:49 PM |
| Because we have finally run out of ideas.... | TheButterGod2k5® | Texas Impreza Club Forum -- TXIC | 13 | 06-28-2005 04:11 PM |
| Uncontrollable shaking! Run out of ideas | motorswapsleeper | Brakes, Steering & Suspension | 6 | 10-02-2003 08:08 PM |
| Link plus problem, I'm running out of ideas. | Chav | Engine Management & Tuning | 11 | 04-05-2003 04:36 PM |
