Old 06-16-2002, 12:55 AM   #1
Chav
Member#: 3269
2001 2.5RS Sedan STM
RSTi
Default Maximum HP on stock RS fuel system with walboro fuel pump
Whats the max horsepower that can be made with the stock rs fuel system + walboro fuel pump and parallel fuel rail. Or what will the fuel pressure be with this combination at WOT?
edit: I also have a Link 2 ecu, but i dont think that makes a difference since 100% injector duty cycle is always 100% injector duty cycle.
Thanks
I'm trying to decide which size injectors I need to get. From the www.rceng.com fuel worksheet the max 440cc injectors will get me is 280 or so hp if the fuel pressure at WOT is 50psi. I'm not sure what the fuel pressure will be at WOT with a walboro fuel pump though.
-Chav
Chav is offline   Reply With Quote
Old 06-16-2002, 01:39 AM   #2
STiTuner
Member#: 5778
09 135i
Jet Black
are you using the stock fuel pressre regulator?
100% duty cycle is not always the same when you're changing the pressure.
Brad
STiTuner is offline   Reply With Quote
Old 06-16-2002, 02:11 AM   #3
Chav
Member#: 3269
RSTi
ya, stock fpr. I'm leaning towards 550cc injectors instead of 440cc because the 550cc will be good to 320hp or so. I dont want to buy the 440cc be good to 7 psi and then have to change them. I should also get the svx fpr since it flows more. Man this is gonna cost sooo much.
As per the worksheet from www.rceng.com the stock fuel system + 44psi from the uprated pump will yeild 173hp. 95% injector duty cycle .6 bsf and 44 psi. 173hp??? How can I even boost 1psi then?
Anyone know where to get 550cc high impedence injectors? I called rc engineering and they said that they only have 440cc injectors and they havent made sure they fit on a 2.5rs yet.
edit: There has gotta be something wrong with what I think I know about all this. Can someone school me please? Thanks
-Chav
Old 06-16-2002, 02:26 AM   #4
N/A
Member#: 133
TBA TBA
TBA
OK then to add another question can you post a pic of the Subaru fuel pump and bracket that goes into the tank? I want to see if the spare GTR fuel pump in my closest will work on the Subaru if so then it saves me the money for the Walboro unit.
N/A is offline   Reply With Quote
Old 06-16-2002, 02:30 AM   #5
Chav
Member#: 3269
RSTi
Oh ok, thanx for hijacking my thread N/A
j/k
-Chav
Old 06-16-2002, 05:36 AM   #6
N/A
Member#: 133
TBA TBA
TBA
Not really hijacking the thread since my next question was if you had the flow capacity info for the Walboro unit that you're going to use.
The 440's from RC are only good up to 7lbs of boost? I thought they were capable of more then that. Hell I've run the stock Silvia units to 12lbs with not a single problem so I would have thought that the 440's could take more then 7lbs.
Old 06-16-2002, 06:03 AM   #7
KillerTHC
Member#: 4942
01 SRP 2.5 RS-T
Ludespeed Stage 3 Link'd
i know skywalker is maxing out his 440's at 5 psi when he shifts.
KillerTHC is offline   Reply With Quote
Old 06-16-2002, 11:33 AM   #8
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
hmmm...interesting. I'm running stock injectors, with a Walbro 255 pump, and 7 pounds of boost. According to my Link, I hit 97%IDC at 6400 rpm. I would be comfortable saying that my car makes ~230 hp, since it dyno'd at ~220 at 5 pounds.
Impreza Rider is offline   Reply With Quote
Old 06-16-2002, 12:59 PM   #9
Delicious Tuning
Member#: 1990
Well I am also letting my boost spike to ~10 between shifts. He he...
Delicious Tuning is offline   Reply With Quote
Old 06-16-2002, 01:13 PM   #10
Chav
Member#: 3269
RSTi
Ya, the 255 walbro pump. I thought the stock injectors would hold more then 173hp and that the 440cc injectors would be past 7 psi as well, but as per rc engineering's flow rate work sheet they dont.
Impreza Rider: Is your fuel system set up like stock just with the walbro fuel pump?
Thanx,
-Chav
Old 06-16-2002, 04:21 PM   #11
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
Yes
Old 06-17-2002, 03:42 PM   #12
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Here's the sheet that RCEngineering sent me along with my 440's. It pretty much confirms what everybody is saying about 7-9lbs of boost being the limit for them.
wcbjr is offline   Reply With Quote
Fuel Pressure with Walbro 255lph HP pump on stock regulator JSarv Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 07-04-2008 01:05 PM
sti 816cc injectors with walbro fuel pump $320 shipped!!! chasechaseum06 Engine/Power/Exhaust 5 08-06-2007 01:44 PM
FS: sti 780 cc injectors with walbro fuel pump (florida) chasechaseum06 Engine/Power/Exhaust 2 08-02-2007 04:37 PM
Maximum HP on JDM EJ207 STI8U Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 02-24-2006 12:03 PM
Safe max fuel pressure on stock RS injectors? Trizzle Normally Aspirated with bolt-on Forced Induction Powertrain 8 07-21-2003 07:41 AM
