Old 07-11-2010, 08:49 PM   #1
MikeC5
Member#: 104702
95 Legacy
Green
Default 2.5 L (phase 2) SOHC Timing/HG Q
Um. Newb question here- I'm doing head gaskets on my 2002 Forester L and ran into something a little weird. I've got the crack sprocket timing mark lined up on the TDC mark but when I pulled the heads #1 piston was not at TDC... maybe 1/2 way up the bore. Any other non-Subie engine I've ever worked on the timing mark and piston position agree... Please tell me this is normal...
I'm doing the HG with motor in the car and although I was able to (just barely) get the heads out without jacking the engine, it appears it would help. My question is should you unbolt both motor mounts and raise up the engine as far as possible or is it better to just unbolt one side at a time and let the engine 'rotate'?
Anyone tried an impact wrench to get the plastic cam sprocket off? (head removed from engine). I may have to fabricate something to hold onto that thing...
MikeC5 is offline   Reply With Quote
Old 07-11-2010, 10:22 PM   #2
flstffxe
Member#: 155358
2008 Forester
Steel Silver
The piston position is normal. This location is known as a service position. there is a separate mark for tdc.
Try this thread, it is for a '98 DOHC but other then being dohc the rest of the steps are virtually the same.
http://www.subaruforester.org/vbulle...-engine-57335/
flstffxe is offline   Reply With Quote
Old 07-12-2010, 09:15 PM   #3
MikeC5
Member#: 104702
95 Legacy
Green
Thanks flst. Good thread. I tried registering on subaruforester.org but it keeps saying "you did not answer anti-spam question correctly" even though I triple checked and am sure it was correct. Anyone else run into this?
That plastic cam gear is a B*&$#@* to get off. Too bad you can't use heat on it. The impact wrench didn't work but it's just a cheapie.
Old 07-12-2010, 10:42 PM   #4
BruceD_500
Member#: 233041
BruceD_500 is offline   Reply With Quote
Feeler EJ22T block and phase 1 2.5 crank for 2.35 stroker 69subaru360 Engine/Power/Exhaust 8 03-24-2010 03:01 PM
2.5 L Phase 2 HG Life? Hayes Normally Aspirated Powertrain 13 10-19-2006 03:57 PM
2.5 DOHC --> 2.5 SOHC swap. Please Help! spdracr00 Subaru Conversions 13 03-02-2006 04:49 PM
2.5 DOHC --> 2.5 SOHC swap. Please Help! spdracr00 Legacy Forum 3 02-26-2006 08:38 PM
SOHC 2.5 vs. DOHC 2.0 happy2bhardcore Newbies & FAQs 10 10-03-2002 03:40 PM
