Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 07-11-2010, 09:11 PM   #1
Impreza541
Member#: 160822
2007 Forester XT
Beige
Default Cylinder 3 misfire after injector install
Yesterday I had my tuner drop in 1000cc modded injectors into my car and also do a tune.
Today my car threw a cylinder 3 misfire code at me, at idle the motor shakes a little more than usual but on acceleration and boost I am hitting all of my numbers. When I clear the code the car starts and runs like it should, I cleared it earlier today and it came back right when I was in reverse feathering my clutch to turn around.
Either way I am visiting my tuner tomorrow after work but just wanted to get some opinions and thought before I walk into my tuners shop. My searching gave me some headway, could be a bad coilpack or a fouled plug? bad injector? To rich of a tune?
Edit: Mod list
HTA68
txs fmic
denzo pump
1000cc injectors
cobb short ram
gimmick inlet
catless exhaust
dyno tune done by PRE
Impreza541 is offline   Reply With Quote
Old 07-11-2010, 09:50 PM   #2
KpT KiM
Member#: 242422
One of my cylinders was misfiring awhile ago, and my engine and drivetrain is completely stock.
I just switched the coilpack from the misfiring cylinder with a coilpack from a different cylinder, and everything now runs great. I haven't had a misfire since.
I would do this and remember what cylinder coilpack you switched #3 with. Switch the #3 coilpack with the #1 coilpack (the cylinder in front of #4), and see how everything goes. If you #1 gets a misfire, you know it's the coilpack.
KpT KiM is offline   Reply With Quote
Old 07-11-2010, 10:32 PM   #3
englishguy3012
Member#: 147943
2004 Sti 2.5 XTR'd
372whp, Stock block 1yr+
also check the wires going into the injector, when i swapped out mine my number 1 cylinder was misfiring, and it was the positive wire going into the injector
englishguy3012 is offline   Reply With Quote
Old 08-01-2013, 01:50 PM   #4
taco_tom
Member#: 125498
2004 WRX STi
Java Black
Im glad I found this thread, I recently had my car tuned where my tuner modified my stock injectors to 850cc, and now I am having the same problem as you are. I was told by my tuner to change the plugs........... I did and gapped them as he said .022, still same issue. I called him back he said switch coilpacks and I did, still same issue. Each time after resetting the code it would come back on during idle. I have the same issue that you are having the car shake and shutters at idle, good numbers during boost although once check engine light is on and I hit boost the car feels as if there is a vacuum leak or boost leak by shuttering/hestitating slightly. I hope that all it is, is what Enlishguy is talking about, but I have a feeling that its the injector because there is a faint smell of gas during idle and from what a mechanic friend has told me.
I am subscibing to this thread to findout how it goes for you.
Tom
taco_tom is offline   Reply With Quote
first cylinder 1 misfire, after plugs, 1,3,4 misfire! DieselClown Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 32 08-26-2008 02:59 PM
Misfire in Cylinder 1 CEL after Flywheel install?? Scoobs2002 Engine Management & Tuning 19 05-13-2008 09:14 AM
1 & 3 Misfire after uppipe install Thumper23 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 09-07-2003 12:44 PM
Cylinder 3 misfire hokiewrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-04-2003 04:01 PM
p303 cylinder 3 misfire defduane Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-22-2002 09:45 AM
