Vancouver Impreza Club
Old 07-11-2010, 10:12 PM   #1
Wrgb
Member#: 169096
2009 DGM STi Hatch
2000 2.5RS *Gone*
Default Clutch Problem!
Hey Guys,
So at 96,000km i got my clutch replaced at Wolfe subaru (with an OEM clutch)
Im now at 116,000km and this morning (and all today) my clutch is acting very weird.
-Normal travel
-Normal freeplay
(so i dont think its a problem with the master/slave hydrolics)
But its almost impossible to get into gear, and i have to let the car roll a bit to engage.
Also, when it does engauge the clutch pedal must be pressed RIGHT to the floor (to shift)
What might be wrong?
The service was done 1.5years ago, 20,000km.
What can i do??
Wrgb is offline   Reply With Quote
Old 07-11-2010, 10:14 PM   #2
tora
Member#: 5851
09 Forester XT
+ NA Miata
Could it be gear/synchro issues? Is it the same for all gears or only certain ones? Did you see the parts they used prior to installation? Was it a refurbished clutch or new?
tora is offline   Reply With Quote
Old 07-11-2010, 11:39 PM   #3
Wrgb
Member#: 169096
2009 DGM STi Hatch
2000 2.5RS *Gone*
It happens for every gear 1-5 and R.
It shifts, i just have to really force it in, and the clutch has to be pushed all the way to the floor.
no, I didnt see the parts before they installed them.
The invoice says:
"Replaced clutch and used updated bearing"
SCI560001 Reman clutch ASSY-19 Type: CCTR 243$
SE1011 Bearing Repair Kit Type: CRO 179$
Old 07-11-2010, 11:54 PM   #4
bender
Member#: 1839
without looking at it, I say it's a clutch master cylinder. it's so common that I keep a spare at the shop just in case mine goes out again
bender is offline   Reply With Quote
Old 07-12-2010, 12:08 AM   #5
Loomin
Member#: 118113
98' Stagea 260RS
Autech Ver.
either that or a leak in the hydraulic system.
check the CMC resovoir and make sure its got fluid in it. if not, top it off with dot 3 brake fluid.
If its right out, you'll need to bleed the system. this is best done with a friend. pretty easy though. but first find out where the fluid went. cracked flex-hose? loose fitting? missing a copper washer on the banjo bolt? or buggered master like bender said.
Loomin is offline   Reply With Quote
Old 07-12-2010, 12:25 AM   #6
iht
Member#: 196742
2000 Impreza 2.5rs
just a question, when was the last time the transmission fluid was changed?
iht is offline   Reply With Quote
Old 07-12-2010, 02:09 AM   #7
Wrgb
Member#: 169096
2009 DGM STi Hatch
2000 2.5RS *Gone*
Im not 100% sure if the tranny fluid was was done, but the 96,000km tune up was done by the dealer at the same time as the clutch was replaced. so if it is included in that... then it was done then.
So weirdest thing.
Last night car drove fine.
8am, 4pm, 6pm, 8pm the clutch was messed up and had to be pushed to the floor to shift.
10pm tonight rolls around, and the thing works 100% fine as before, clutch shifting nice and high, super smooth!! WTF
im so confused!?!
Old 07-12-2010, 02:12 AM   #8
tora
Member#: 5851
09 Forester XT
+ NA Miata
They installed a Vampire Clutch, it only works at night.
Old 07-12-2010, 02:59 AM   #9
5 Zigen
Member#: 769
04 SoBaLo EsTea-ai
ZERO/SPORTS/99 GM6/05 BP6
sounds like a clutch slave and it doesn't work well when weather is hot, have seen that before (but usually along with weird travel or sound etc)
also make sure your clutch fluid is in good shape / level, have seen low / no clutch fluid at the reservoir if the cap is removed ~ black dirty marks makes ppl think there is fluid in there, but there isn't....
5 Zigen is offline   Reply With Quote
Old 07-12-2010, 03:47 AM   #10
Subaru_Salesman
Member#: 241382
It should be Clutch Cylinder...
Subaru_Salesman is offline   Reply With Quote
Old 07-12-2010, 04:52 AM   #11
6th gear
Member#: 126860
2004 STi Aspen White
1971 Corolla Racecar
Subaru Stars
^^ Huh?
Who's this?
6th gear is offline   Reply With Quote
Old 07-12-2010, 05:44 AM   #12
Jeff54
Member#: 129503
2002 It's resting
6 > 4?
i believe he sells subarus
Jeff54 is offline   Reply With Quote
Old 07-12-2010, 12:20 PM   #13
tora
Member#: 5851
09 Forester XT
+ NA Miata
Or he's a Subaru who sells MENz.....
Old 07-12-2010, 12:30 PM   #14
timbits
Member#: 166183
2007 2.5i SE
Newport Blue
Yeah, sounds like inconsistent pressure at the slave. I would bleed the system and wait for symptons to come back...
timbits is offline   Reply With Quote
Old 07-12-2010, 08:02 PM   #15
Wrgb
Member#: 169096
2009 DGM STi Hatch
2000 2.5RS *Gone*
Thanks for all the great advice!
So i checked the clutch fluid, and its totally full.
Today it shifted normally, then one time i went to shift and it would go into ANY gear, it just grinded. I eventually let the car roll and got it into 1st. After that the car Drove totally normally.
What would bleeding+refilling the clutch fluid do?
How hard is it to replace the slave? (cost?)
Any recommendations on where to go?
Old 07-12-2010, 08:27 PM   #16
Ricewagon
Member#: 59703
2004 STi
always wrb
oem slave cost around $130. did they replace your clutch with an oem one or a jobber?
Ricewagon is offline   Reply With Quote
Old 07-12-2010, 09:17 PM   #17
Ken
Member#: 34
2005 WRX STi
World Rally Blue
I tried to bleed and refill mine on my old RS when the clutch dropped to the floor and it wouldn't pump back up so that's when I had to get it towed and get the clutch slave replaced.
Ken is online now   Reply With Quote
Old 07-12-2010, 09:29 PM   #18
Wrgb
Member#: 169096
2009 DGM STi Hatch
2000 2.5RS *Gone*
They replaced my clutch with a "new one"... that after it was installed turned out to be a "subaru factory referb"
130$ for a OEM slave... ok i can deal with that.
-Is there an upgraded one i should get?
How hard is it to install?
should i get a shop to do it? (Sounds from Ken, like i should get a shop to do it lol)
Old 07-12-2010, 09:34 PM   #19
minifreak
Member#: 116914
2006 WRX Wagon
Obsidian Black
Just make sure you get the right style of clutch slave cylinder (pull/push). I don't think there is an upgrade version but the newer style slave has a damper built in.
Installation is simple, the hard part is bleeding the slave
minifreak is offline   Reply With Quote
Old 07-12-2010, 09:35 PM   #20
Ricewagon
Member#: 59703
2004 STi
always wrb
Shops seems to try that. It makes a big difference whether it's a real oem one or jobber. When put side by side, the difference is really obvious.
I would get a shop to swap your slave just because I find it a pain to bleed the system.
Old 07-13-2010, 03:44 AM   #21
5 Zigen
Member#: 769
04 SoBaLo EsTea-ai
as far as i know subaru always goes with a factory remanufacturer one as the new one cost about 1.6x to 2x the price! some time they do cut corner by telling you it's new, but some do spend the time to explain why they used rebuilt; i have used both and subaru's reman ain't so bad (way better than jobber rebuilt, those are horrible).
bleeding the clutch system is hard, but u can probably have some fun and worse case is like Ken, have it towed and it will still be done :P
i will suggest you to replace the slave the earliest possible, it's better not to damage the tranny (synchro's) or shorten clutch's life just because of a faulty slave cylinder!
Old 07-14-2010, 11:22 PM   #22
Wrgb
Member#: 169096
2009 DGM STi Hatch
2000 2.5RS *Gone*
Weird Twist...
When the clutch wont disengage/engauge... if i turn off the engine, and release the clutch and brake. Then start the engine again... the clutch (most of the time) will then work perfectly!!???
WTF?!?!
Old 07-26-2010, 01:03 PM   #23
Wrgb
Member#: 169096
2009 DGM STi Hatch
2000 2.5RS *Gone*
****UPDATE****
So i went and got the clutch system bled, it seemed to fix almost everything (dont want to jynx it)
After i bled the system the pedal feel returned its now nice and firm, and shifting is smooth as ever.
Old 07-26-2010, 02:27 PM   #24
Horkus
Member#: 112667
2002 WRX wagon
Well you threw us all off when you said Travel was normal at first!!!
There is no way the travel of the pedal is normal if there is AIR in the system!!!
but glad you found out why.
Horkus is offline   Reply With Quote
clutch adjustment/ clutch problems CCTXRS Transmission (AT/MT) & Driveline 10 01-04-2010 11:18 PM
Clutch problem or turbo problem? Crow-sti07 Newbies & FAQs 3 07-06-2007 09:17 PM
Clutch problem or tuning problem? earlmale Transmission (AT/MT) & Driveline 3 02-21-2006 01:24 AM
Clutch problem/Decell problem? Beginner_Man Bay Area Impreza Club Forum -- BAIC 16 04-14-2003 11:00 PM
Clutch problem with new clutch Evaider Transmission (AT/MT) & Driveline 17 04-27-2002 06:58 PM
