Old 07-12-2010, 08:58 AM   #1
sjgharib
Member#: 231194
Default Timing Belt Part Number Cross reference?
Does anyone know a good way to cross reference a JDM Subaru part number?
I have a JDM DOHC EJ25. I want to change the timing belt before I put it in my kit car. The belt part number (right off the part) is 13028AA220.
However, when I search for that number, it doesn't show up. The dealer couldn't help me much either, since I don't know the actual year or vehicle from which the motor came.
It is a DOHC EJ25, with the variable valve cam-sprockets (the ones that are continuously variable, not the dual cam lobes. I think it's called AVCS).
Any thoughts? Typically the belts are about $80-100, so I'm hesitant to just buy one and try it...
I was hoping there was someone here with a good parts source or connection...
Thanks!
Simon
sjgharib is offline   Reply With Quote
IAC part number cross reference... POSBUTAWD Normally Aspirated Powertrain 2 05-25-2009 01:39 AM
Engine number cross reference to history? wobbletop Factory 2.0L Turbo Powertrain 2 10-17-2008 10:53 AM
Advice on timing belt parts, i.e. belt tensioners on EJ22 SubarNoober Normally Aspirated Powertrain 1 02-21-2008 05:10 PM
Timing belt part numbers UniqueTII Factory 2.0L Turbo Powertrain 1 12-18-2007 06:28 AM
Timing Belt Part Number alfabc Factory 2.0L Turbo Powertrain 4 11-14-2007 02:50 AM
Message Board Statistics All times are GMT -4. The time now is 03:51 AM.
