Welcome to the North American Subaru Impreza Owners Club Friday September 4, 2015
Texas Impreza Club
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC
Old 07-12-2010, 04:44 PM   #1
Gillman Subaru
Member#: 120219
Default Gillman Subaru The Big Event 2: Shop Day Registration and info
The Biggest Big Event! You don't want to miss this one!
The shop will be open at 8am on August 21st.
There is so much going on on August 21st we can't list it all here, see the Big Event thread for info on the other stuff happening that day.
Main "Gillman Big Event 2" Thread here: http://forums.nasioc.com/forums/show....php?t=2020491
If you want to bring your car in and work on it post here so I can add your name to the list. Please give the following information:
1. Name and user-name on forum
2. Car year and model
3. Work to be done
- There will be a required $20 payment to Gillman for using their bays. With this fee you will get two bands and one t-shirt. One band is for you and one for a passenger.
- If you are going to be in the shop you are required to have a band.
- If you are not working on a car, but want to be in the shop you will need to pay $5 for a band.
- No one under 13 will be allowed in the shop area.
- We are doing this to keep the shop area a little less congested for everyone’s safety.
- No open toed shoes, flip flops, or sandals.
- There is a 2 hour maximum per car per shop bay. If you run over the 2 hour maximum, you will be charged an additional $20, plan your time accordingly.
- The money collected for working on your car, and entry into the shop will help to offset the additional required safety equipment, and other needs for the day.
If you have questions please let me know and I will answer them to the best of my extent.
With each arm band you will get a raffle ticket and be entered to win some really cool Subaru prizes!
Also please tip the techs for their time, they are coming in on a day off and are not getting paid for this.
As a guide for what you should expect to be able to do at the shop day, things such as downpipe, springs, swaybars, turboback, basic services, interior stuff, shifter bushings, CV joints/boots (we did a few of these last time) should be things you plan on doing at the shop day. Obviously other jobs can be done too, but expect to run over the allotted 2 hours and have to pay the additional $20 for 2 more hours.
If anyone has any questions on how much money you should be prepared to tip for the help of the technicians, please feel free to ask!
There will be 20% off parts and Subaru merchandise for this event! Just contact the parts department for help.
Come on out and have some fun, work on your car and meet some of your fellow Subaru enthusiasts!!!!!
I can almost promise you that The Big Event 2 will be the biggest event yet, and you won't want to miss it!
Thanks,
Sam (samagon) I LOVE POOP
Gillman Subaru is offline   Reply With Quote
Old 07-12-2010, 04:44 PM   #2
samagon
Member#: 26859
of TXIC
I also like (oYo)!!!!
All, please try to be specific about what you plan to do as we would like to be as prepared as possible in the shop.
Additionally, some of the things you may want to do will be too difficult to accomplish at the shop day, lower control arms, clutch swap, rear main seal, these are examples of things that are going to be too difficult to accomplish, so it will be good to know what you want to do so that we can let you know ahead of time that this may be more than we can tackle at the shop day. thanks very much for your understanding!
See the first post for a list of things that are good ideas for the shop day, I've just talked to Amir and he says that timing belts should be okay, but keep in mind that if you run over the 2 hour limit, it will be another $20. and remember the alignment rack is also available, and Ding Lifters will be on site as well!
List of Shop Day Entrants:
1. Mary - AWD Tuning
Legacy GT?
Stuff?
2. TurdFerguson
WRX
air sucking valve
3. Tom, taco_tom
2004 Sti
Stuff?
4. Daniel, CRAZYFOOL999
2007 WRX
Oil Change, tranny and coolant flush, maybe alignment?
5. Kauve - KauvSTi
2007 STi
Sway Bars, springs maybe Downpipe?
6. Emilio - omnithreat
2008 WRX
Oil Change, Air Filter, Rear Diff Fluid, Transaxle Fluid
7. Vince V - iconone
2005 wrx
alignment and brake check.
8. John Paul - jp102895
2005 WRX
Valve Cover Gaskets replacement and oil cooler seal replacement.
9. dzywrx
2004 WRX
Engine and Trans Mounts.
10. Tharun - Brownboy
2005 Subaru Legacy
Fluids/Belts
11. Tuan - WRXTuan
2004 Subarx WRX
Replace busted CV b00t... probably something else, like using the restroom.
12. Brian - Spacepope
2004 WRX
stainless brake lines, brake fluid, gear oil
13. Omar aka slOwmar - sr20dehauler - (I might need about 3 hours)
2005 Forester XT
Front control arm bushings (2 hours tops -alignment), tranny/front/rear diff fluids, brake flush, alignment
14. Nancy - Frogspitt
2008 STI
Brake pads/rotors and maybe CBE
15. J Phillips - Tex-WReX
08 sti
Alignment
16. Jon - madspecvman
2004 sti
ss brakes and fluid flush; tranny and rear diff fluid; steering rack bushing; spark plugs; maybe front wheel bearings
17. Othniel - Letum001
2005 sti
springs installed
18. Donald-donnie25
2005 wrx
radiator flush and filll; tranny drain and fill; all differentials drain and fill; both front axel replaced
19. Luis Martinez (real and Forun Name)
Impreza WRX 2009
Replace Spark Plugs; Replace Brake Fluid and Inspection lines
20. glilly / Greg Lilly
08 STI
Cobb Heat shield & add negative camber to front. ...ohh, and maybe my 2nd oil change.
21. Butterz / Marshall
2008 Legacy GT
30k mile service and maybe spring/swaybar install
22. Ericsson - Juan
2008 STI
30k mile service or as much as possible
23. Armani - euclideanbell
2008 WRX SEDAN
Alignment check, Possible tire balance??
24. Stephen Duering/ PearlandSTi
2010 STi
Cobb downpipe and heat shield
25. Gonzo_TFTD
2005 FXT
Timing Belt
26. TJ Tran - junkb0y
Impreza WRX Wagon 2007
Install catback exhaust
27. Stephen Proctor
2007 STI
Downpipe
28. Jamil-Jamil7
97 Impreza
Motor and tranny oil change and coolant flush
29. Victor - Vlenhoff
2010 WRX
Re-grease sway bars, Trouble shoot Fog lamps, activate shock sensor
30. Brian - Blitzkrieg
2003 WRX
Change tranny fluids, flush radiator and a few radiator hoses, one running to the turbo is spongy and melting.
31. Tom (T-dub)
'07 WRX
Could i do my 60k mile service (w/ techs help)? I've been told it takes about 4 hours. Hell if I could just get the spark plugs replaced I'd be happy.
32. Shawn (shawns_sick_STi)
04 STi
check for bent front right suspension pieces and trouble shoot EDFC.
33. skuby
02 WRX
Alignment
Old 07-12-2010, 05:20 PM   #3
awdtuning.com
Member#: 183645
2007 STi & 09 SpecB
www.awdtuning.com
CAN'T WAIT! I just got off the phone with Scott about getting more goodies to hand out. Anything else that we can do, just let us know!
Not sure yet what we'll be doing yet, but I'm sure we'll find something to work on, so please go a head and put us down for a spot.
1. AWDTuning
2. TBD
j/k (I'll just have to remember to find our shoes and pack them up before we head to Houston)
~Mary
awdtuning.com is offline   Reply With Quote
Old 07-12-2010, 06:12 PM   #4
Turd Ferguson
Member#: 123142
2011 Subaru STi
Satin White Pearl
I'll be there. I will be in the shop too. Just don't know what I'm doing yet either.
Turd Ferguson is offline   Reply With Quote
Old 07-12-2010, 10:37 PM   #5
anthony_delprete84
Member#: 88254
I really need a clutch put on my wife's 02 wrx. Would the techs be helping me if I sign up or do I need to ask someone on the forum? I have no problem tipping, I just need the job done right. Im sure its much easier with the car on a lift opposed to in my garage. Any help would be greatly appreciated
anthony_delprete84 is offline   Reply With Quote
Old 07-12-2010, 10:47 PM   #6
Spider Pig
Member#: 82323
I'm a lead farmer,
mother****er!
I'm just curious, but why are there three threads, including two which are exactly the same?
Spider Pig is offline   Reply With Quote
Old 07-12-2010, 10:49 PM   #7
proBlur
Member#: 235609
2008 Stg 2 STi
Gillman Subaru The Big Event 2: Car Show Registration and info
proBlur is offline   Reply With Quote
Old 07-12-2010, 10:53 PM   #8
Spider Pig
Member#: 82323
I'm a lead farmer,
mother****er!
And that can't be done in one thread? Considering that over three quarters of the information in the two threads are identical? So go yourself there, jackwad.
Old 07-12-2010, 11:15 PM   #9
glilly
Magic 8 ball says Ban
Member#: 7245
13 BRZ
08 Avalanche
Your comment is in the wrong thread.
The main thread is general information and discussion. The car show thread is just that, the shop day thread is, ...see where this is going?
glilly is offline   Reply With Quote
Old 07-12-2010, 11:49 PM   #10
Spider Pig
Member#: 82323
I'm a lead farmer,
mother****er!
Oh, I get it. I'm just looking at the content of the threads and wondering why they're so repetitive. Because they are.
Old 07-13-2010, 08:16 AM   #11
glilly
Member#: 7245
13 BRZ
08 Avalanche
Wanted to make sure people knew what the topic was, ...like that a mountain bike is not a car.
Old 07-13-2010, 10:48 AM   #12
Turd Ferguson
Member#: 123142
2011 Subaru STi
Satin White Pearl
Legacy GT?
Stuff?
2. TurdFerguson
WRX
Stuff?
For sure my air suction valve. It's F'n up on me and diff fluid change.
Old 07-13-2010, 11:36 AM   #13
taco_tom
Member#: 125498
2004 WRX STi
Java Black
I want some of this,
-Tom, taco_tom
-2004 Sti
-Stuff
taco_tom is offline   Reply With Quote
Old 07-13-2010, 11:40 AM   #14
YourMother'sLover
Member#: 76565
CLXX Stricta Parata
Neci!
I'm there to help whoever needs it. I'm broke and have no money to do work! LOL
YourMother'sLover is offline   Reply With Quote
Old 07-13-2010, 12:51 PM   #15
Crazyfool999
Member#: 120546
2007 WRX TR
Rudolph the Red Nose
-Daniel - CRAZYFOOL999
-2007 WRX
-Oil Change, tranny and coolant flush
Crazyfool999 is offline   Reply With Quote
Old 07-13-2010, 04:06 PM   #16
KauvSTi
Member#: 235128
W211 E55
- Kauve - KauvSTi
- 2007 STi
- Sway Bars & Downpipe
KauvSTi is offline   Reply With Quote
Old 07-13-2010, 04:59 PM   #17
samagon
Member#: 26859
of TXIC
sorry I missed this earlier, but a clutch job would be too long for the shop day.
Old 07-13-2010, 05:26 PM   #18
samsavell
Member#: 145747
2011 Mazda
Double with Cheese
I have an idea of something I need to do, but I need to figure out if it'll be feasible for shop day and if I'll have the funds for it right now.
samsavell is offline   Reply With Quote
Old 07-13-2010, 05:28 PM   #19
omnithreat
Member#: 163635
2008 Impreza WRX
Texas Fire Car
-Emilio
-2008 WRX
-Oil Change, Air Filter, Rear Diff Fluid, Transaxle Fluid
omnithreat is offline   Reply With Quote
Old 07-13-2010, 05:32 PM   #20
anthony_delprete84
Member#: 88254
dang, im still gonna show up on shop day even though I apparently can't get my clutch changed, possibly put my sti in the show. Can anyone help me with this on a dif day?
Old 07-13-2010, 05:33 PM   #21
samagon
Member#: 26859
of TXIC
downpipe, springs, swaybars, turboback, basic services, interior stuff, shifter bushings, CV joints/boots (we did a few of these last time), things of that nature are what you want to try to do on the shop day. If you have an older wagon, you can do the roof rail delete in under 2 hours.
Old 07-13-2010, 07:12 PM   #22
Turd Ferguson
Member#: 123142
2011 Subaru STi
Satin White Pearl
Lol @ Sam with my 'air sucking valve'
Old 07-13-2010, 08:04 PM   #23
Kurikaze
Member#: 174252
2014 BRZ
lol.. crap.. I want sways now..
Kurikaze is offline   Reply With Quote
Old 07-14-2010, 09:42 AM   #24
samsavell
Member#: 145747
2011 Mazda
Double with Cheese
On the normal occasion, putting my up-pipe in would be a pretty normal shop day job! But.. well.. damn downpipe bolt.
Old 07-14-2010, 11:48 AM   #25
iconone
Member#: 174883
135i 05 CGM WRX
2006 Yamaha R1
I hope I can get a alignment this time.
Vince V - iconone
2005 wrx
iconone is offline   Reply With Quote
Gillman Subaru presents: The BIG EVENT 2 with Dave Mirra - August 21, 2010 Gillman Subaru Texas Impreza Club Forum -- TXIC 235 08-28-2010 11:26 PM
The Big Event - Shop Day Pre-Registration Thread Turd Ferguson Texas Impreza Club Forum -- TXIC 130 02-05-2008 12:33 AM
Is everyone at the Big Event going to be drinking Snapple all day? AliBenn Texas Impreza Club Forum -- TXIC 17 02-04-2008 05:18 PM
The Big Event - Car Show Pre-Registration Thread glilly Texas Impreza Club Forum -- TXIC 91 02-02-2008 07:41 AM
